root2 Wrote:ffmpeg now uses "neon" http://en.wikipedia.org/wiki/ARM_archite....28NEON.29
which should boost the video playback performance.
So, does that mean that all the effort I have made converting my whole library to h264 has been unnecessary? I still have a few (200) films left to code, and Handbrake is getting a little weary...
Fantastic work, by the way!
don't want to jinx myself, but initial testing seems to show that my buffering issues have gone away. A 2 gig/2 hour standard def xvid was giving me tons of buffering the past two days is going fine right now. curious to hear if it's fixing the buffering issues that others were having that didn't seem to be related to decoding (cpu was never spiking, yet it buffered a lot even when there should have been sufficient bandwidth..the file streams to other devices just fine.)
edit: still seeing some (though reduced) buffering on a higher bitrate 720p mkv [high profile 4.1, 10.8 mbs avg bitrate, spikes up to 17 or 18]. I'm not sure if there's some still wonky bottleneck with smb shares on mac, or if it's running up against the limitations of the hardware. Watching cpu usage on the OSD it tends to hang around 80% on that file so while a bit taxing, it's not dropping frames or anything until a handful when it buffers. still..some definitely improvements on this build. thanks to everyone involved.
davecas48 Wrote:So, does that mean that all the effort I have made converting my whole library to h264 has been unnecessary? I still have a few (200) films left to code, and Handbrake is getting a little weary...
Of course not, the hardware decoder for mpeg4 AVC stuff is superior to the ffmpeg software decoding. He's just making is better.
Hey guys,
Been installing all of the nightly builds and then just got an error trying to install the 02/01 build.
during the deb package install i get a dependency error for xbmc.iconpack.
Unpacking replacement org.xbmc.xbmc-ios ...
dpkg: dependency problems prevent configuration of org.xbmc.xbmc-ios:
org.xbmc.xbmc-ios depends on org.xbmc.xbmc-iconpack; however:
Package org.xbmc.xbmc-iconpack is not installed.
dpkg: error processing org.xbmc.xbmc-ios (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
org.xbmc.xbmc-ios
Is there somewhere I should be installing the iconpack from? I tried an apt-get upgrade but couldn't find it in a repo.
Still getting slight stuttering/frame drops in my 1080p Avatar x264 mkv (wired), watchable but slightly annoying.
It's in 16:9 format not sure if this is the issue as my other 1080 BD rips are widescreen and play smoothly.
nothingcool Wrote:Hey guys,
org.xbmc.xbmc-ios
Strange. I will look into this when I get home in an hour or two.
Has anyone else been able to use the iOS .dep package?
I got the same error when I installed the 1-29 build via SSH and iFile. I just installed the iconpack via Cydia, and it was all good after that.
Thanks for this fantastic work! The rotation bug on the iPad had been really uh ... bugging me. Haven't tried this build yet, but will shortly.
meshuga Wrote:Strange. I will look into this when I get home in an hour or two.
Seems OK here
Nolans-iPad:/private/var/tmp root# dpkg -i org.xbmc-020111_ios-arm.deb
(Reading database ... 3176 files and directories currently installed.)
Preparing to replace org.xbmc.xbmc-ios 10.0-0 (using org.xbmc-020111_ios-arm.deb ) ...
Setting up org.xbmc.xbmc-ios (10.0-0) ...
Nolans-iPad:/private/var/tmp root# dpkg -l | grep -i xbmc
ii org.xbmc.xbmc-iconpack 1.0-0 XBMC Icon Pack
ii org.xbmc.xbmc-ios 10.0-0 XBMC Multimedia Center for 4.x iOS
chad473 Wrote:Xbmc remote (by collect3) has been working great for me, and is highly customizable.
xbmc remote will not work inside Apple Tv to my knowledge. But i will try it out.
like the shutdown tweak... saves me an extra click
The newest .deb worked fine for me, though I already had the iconpack installed this time.
ChipsAhoy Wrote:The newest .deb worked fine for me, though I already had the iconpack installed this time.
not working for me but i dont have the icon pack not sure how to get it.
zachishi Wrote:xbmc remote will not work inside Apple Tv to my knowledge. But i will try it out.
it works on the atv nightly build after configuring the webserver in network settings. keyboard input is a bit wonky (individual commands work, but you can't use it to fill in forms)
