Just downloaded the latest build. Unfortunately still can't get music library mode to import correctly. Still freezes on the m4v's I presume. Anyone know if there is a fix coming for this in the official update or if there is an alternate way to import itunes music?
Just use the Apple TV UI for music, much better.
Sorry guys, I spoke too soon. Official coming soon.
latest build does no longer starts -
http://forum.xbmc.org/showthread.php?tid=93269
in addition, why does it have a such a build number, couldnt it have the same as the official build so cydia doesnt always want to upgrade it?
regards
r4n
r4nd0m Wrote:latest build does no longer starts - http://forum.xbmc.org/showthread.php?tid=93269
regards
r4n
do not cross post, we heard you the first time. post a debug log and syslog
tested 04 build seems good as are all the other builds
good work
was there a way to put the icons in place for the weather
demminal Wrote:Does the "Official Build" contain all the stuff from the unofficial build??
plus whats changing that we need to move over to that version
It will, but I spoke too soon. Can you edit your post and remove my inaccurate info? Thx!
Edited on Meshugas instructions
demminal Wrote:will the unofficial builds continue. as i am happy to keep using them
Yes, they will, in a little different format. You'll see.
Doombelly Wrote:Hmm i followed the ATV2 instruction. Now i got a XBMC PRE-10.5 rUnkown from the 17 january 2011. This seems like the first version.
If i installed the latest version correctly what should it say?
Any input on what i did wrong?
Thx in advance
They reverted back, my apologies. I'll update with a new unofficial to hold off everyone until the official actually comes out.
changed my posts for you mate
Is it normal for the next episode of my smb media to begin playing automatically when the previous episode ends?
I installed the unofficial build earlier today and other than this one question everything else has worked perfectly.
