10.0-6 is out for atv2 and ios
keith
Quote:Visualizer is not working
this doesn't need to be tested anymore ... it is broken for iOs and needs an OpenGL guru for fixing. Same for screensaver ... so this issue can be moved down to the "shitlist"
Thanks amet! Is there a change log or build info somewhere? I updated but I'm curious what was rolled out with this one.
one800higgins Wrote:Thanks amet! Is there a change log or build info somewhere? I updated but I'm curious what was rolled out with this one.
The change log is here -
https://github.com/xbmc/atv2/commits/atv2
This latest update can play back higher quality XVID still not perfect but much better. SSA/ASS subtitles still down't work.
amet Wrote:10.0-6 is out for atv2 and ios
It seems there is a verification issue with the latest build? It prevents NitoTV from performing a correct ' update all' and it has to be done manually from the CL.
The following packages will be upgraded:
org.xbmc.xbmc-atv2
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 39.9MB of archives.
After this operation, 0B of additional disk space will be used.
Do you want to continue [Y/n]? y
WARNING: The following packages cannot be authenticated!
org.xbmc.xbmc-atv2
Install these packages without verification [y/N]?
I updated xbmc from NitoTV and all went well.
updated to 10.0-6, 720p XViD with AC3 is much better, although not playable yet, buffering now every minute (before was every 20 seconds), is skipping less frames, great improvement
Thanks Memphiz! I have updated my 1st thread.
pooh Wrote:It seems there is a verification issue with the latest build? It prevents NitoTV from performing a correct ' update all' and it has to be done manually from the CL.
org.xbmc.xbmc-atv2
org.xbmc.xbmc-atv2
You didn't install the key for that repo.
How do I update from the last Nightly build (17-2) by Keith to the new 10.0-6?
From Davilla:
Official xbmc build for atv2/ios 10.0-7 has been pushed out.
Main fix is for missing net on 1st launch after boot/reboot, big thanks to Memphiz for that one.
As usual, 'apt-get update && apt-get upgrade' should fix you right up. I had to ctrl-c on awkwardtv.dyndns.org when doing the update since their repo seems to be down, but apt-get upgrade works fine after that still.
can you add a date to the first post? So we can determine if we have the newest nightly
