Nothing to see here folks, answered my own question by RTFM-ing
Actually I do have a question. I've entered the apt.get install wget line and I'm sitting on:
0% [Connecting to cache.saurik.com]
It's been like that for several minutes. What's the safest way to get out of Terminal and start over, as it's obviously not connecting right now?
to give a small review of my tests....
720p tv
connected to a wireless G network
with Feb-01 build
everything I tested works perfectly. Subtitles, 1080p videos play without lag or buffering once it's started. My SMB shares work (Openfiler/Samba NAS).
the only thing that could be a little better would be faster menus but this is not a big thing.
I bought an ATV2 just for XBMC two days ago and I don't regret it !
Thank you !
edit : i'm only using tv speakers...so I didn't test AC3 passthrough or any other setup than stereo
all of my vids are laggy and buffer every 30sec. I haven't messed around with it too much. Will take a look into it today and see whats up. SD avi SD mkv and 1080p mkv All of which weren't playing fluidly.
Wireless, but the vids play fine on my xbox and my netbook which are all wireless as well.
Android remote works perfectly though.
is the webserver disabled in the latest build?
i thought that, it gets turned off...you just have to re-enable it in the settings
I couldnt find it in the settings on the 2/1 build..
kevron Wrote:all of my vids are laggy and buffer every 30sec. I haven't messed around with it too much. Will take a look into it today and see whats up. SD avi SD mkv and 1080p mkv All of which weren't playing fluidly.
Disable 'Generate Thumbnails' under Settings > File Types
im having a simillar experience as Dentifrice playback is so much better now, but the menu's are slow to respond and sometimes freeze up for a limited time. I'm very gratefull for these unofficial builds!
Anyone have an idea when the music library might be fixed?
root2 Wrote:Here you can get the newest Version for Apple TV 2:
https://85.31.189.247/atv2/
user:xbmc
pw:atv2
including the Git-Hub Commit d4fc223 from 02. February 2011. Thanks @
gimli for his great work!
meshuga Wrote:Disable 'Generate Thumbnails' under Settings > File Types
Pretty sure I did, I haven't been on it yet today. The kids are hogging it with netflix.
root2 Wrote:Here you can get the newest Version for iPad / iPhone4 / iPodTouch4G:
https://85.31.189.247/ios/
user:xbmc
pw:ios
landwomble Wrote:Anyone have an idea when the music library might be fixed?
Nope, but you might be able to setup remote library w/ mysql for it.
meshuga Wrote:Nope, but you might be able to setup remote library w/ mysql for it.
I con confirm that music does indeed work utilizing this method. However, the music is slow loading, but the complete library is there, in library mode even.
