is there a way to kill xbmc over ssh when it freezes on atv2 (Do not see the process using ps -fxe)? I do not want everytime to do a tethered boot..
yep, with the command "killall AppleTV"
meshuga Wrote:Nope, but you might be able to setup remote library w/ mysql for it.
How do I do this? I have another xbmc on Xbox that has correctly indexed them...
First of all massive improvement, great work!
can't seem to get the remote web gui working though, i get the page but when i click remote nothing happens?
meshuga Wrote:Disable 'Generate Thumbnails' under Settings > File Types
I know everyone keeps saying this on the forums, but i dont see the sub category file types - and can find disable generate thumbnails anywhere.
It says in the first post. Settings>Video>file lists
ashy7 Wrote:It says in the first post. Settings>Video>file lists
For those that are still having problems after the unhelpful comment above..
System > Video > File Lists > Extract thumbnails and video information
Turn that off.
Oh, and by the way..
FANTASTIC WORK!!! major improvement over the standard build available at the moment. Just literally unboxed, jailbroken and installed your copy (although had a couple of problems with the whitelist and seatbeltunlock dependancies.. but once i'd got them manually it was perfect. Will definately be using your builds atleast until the merge with the Dharma tree.
cheers again.
danmedhurst Wrote:For those that are still having problems after the unhelpful comment above..
Turn that off.
How was my comment unhelpful? You posting the same information I did is unhelpful.
piotr Wrote:Holding the menu-key for longer than 3 seconds crashes (or exits ?) XBMC. Is this by design ?
Pretty sure it's by design (i.e. it's an exit not a crash) since it only happens at the home screen and it makes sense.
Generally the Menu key press is to go back one level. However, in the home screen that key press brings up Favorites so I guess they decided to take the next best choice and assign the Menu key hold to the exit function... which is fairly intuitive once you know it's there.
ashy7 Wrote:How was my comment unhelpful? You posting the same information I did is unhelpful.
I think he is pointing out that your directions were not completely accurate (same problem with meshuga's similar directions). Thats all. I don't think he meant anything more. I had to hunt a minute looking for it.
Design.
Turn that off.
ahh ok, I did this. I was just looking for exactly what he posted..thnx.. still problems for me with hd vids.. thanks
Looks like davilla is looking into the issue where XBMC crashes on it's 1st launch when coming out of sleep mode (2nd launch always successful).
http://forum.xbmc.org/showthread.php?tid=92038
Meshuga, maybe you can add it to the list of issues being tested and awaiting confirmation?
