ashy7 Wrote:Change the folder name to plugin.video.iplayer
My install was successful, but the IPlayer fails with the script error.
Where can I find this folder ?
this build works great for me
There is a new 02-14 version on the first post. What are the changes? Just the ones until 02-12?
canman Wrote:My install was successful, but the IPlayer fails with the script error.
I don't know where the zip installs to. Unzip the folder on your computer, rename it to plugin.video.iplayer, then SSH to /private/var/mobile/Library/Preferences/XBMC/addons
Majestic Wrote:There is a new 02-14 version on the first post. What are the changes? Just the ones until 02-12?
Just the changes for github, but this build works with sound on HDMI
Eliah, were you getting static on your receiver over HDMI prior to this release?
I find the last nightly can play back higher quality XVID AVi files.
Not sure if it helps to but playback buffering of MKVs at 1080p over SMB has become more frequent on the 14th release.
Yes playing many Mkv's now over a wired connection they buffer a lot.
Buffering: Same as before for me.
LoneRebel Wrote:Eliah, were you getting static on your receiver over HDMI prior to this release?
I'm getting static on mine still...
What's up with sleep/standby on your atv2 devices? On mine it don't work, and on quitting xbmc the atv do a reboot.
