meshuga Wrote:Worked for me. Try again?
I renamed a directory wrong for like 30 seconds. Apparently you guys tried this in that 30 seconds.
I wasn't having trouble. I was just posting a fixed link for that guy...
No worries.
I got the new build to work and it's great how do you delete xbmc.frappliance.old
trying to delete it but won't let me
sorry I know it's a noob question
Wonkamas Wrote:I got the new build to work and it's great how do you delete xbmc.frappliance.old
I have the same question - I validated the new build and looks and works great for my basic needs. But how do you delete xbmc.frappliance.old
Thanks for the great work!
You can delete the old one by ssh'ing back into the device and doing a 'rm -rf xbmc.frappliance' in /private/var/stash/appliances.
Just wanted to pop in and say, brilliant job!
I'm running the build from the 24th, haven't had a chance to update to the 26th version yet (that's tonights job), but so far it's been great!
Definietly a lot smoother / quicker.
I haven't noticed any problems but will keep playing around tonight.
I also managed to get the Aeon65 skin installed, and that is also running brilliantly with your build!
Keep up the great work
meshuga Wrote:You can delete the old one by ssh'ing back into the device and doing a 'rm -rf xbmc.frappliance' in /private/var/stash/appliances.
Thank you. Should it be 'rm -rf xbmc.frappliance.old'?
meshuga Wrote:Yup, that is correct.
Cool thanks. Hopefully I didn't delete the xbmc.frappliance. How can I check if I still have it lol?
RoarinRow Wrote:Cool thanks. Hopefully I didn't delete the xbmc.frappliance. How can I check if I still have it lol?
Answered my own question.
From the command line I did:
ls
Then this is what came back:
AppleTV.app/ XBMC-ARM.atv2.012411.zip XBMC.frappliance.old/
Cydia.app/ XBMC.frappliance/
So then I did this:
rm -rf XBMC.frappliance.old/
Then did this again:
ls
Now this is what returns:
AppleTV.app/ Cydia.app/ XBMC-ARM.atv2.012411.zip XBMC.frappliance/
Hopefully I did the right thing
This is why I said this isn't for the non cmd line friendly.
I have added to the photos section on my ATV2 xbmc and it displays the preview thumbnails but when you select a photo the screen is just blank, has anyone else had this issue.
but other than that it works great all music is there by album and movies and tv shows its just the photos section.
plus Iplayer2 plugin works great.
Ok tried the latest testing build and everything smooth apart from the static on ac3. The guisettings file has vanished. Also by turning off surround the inlayer seems to work properly... Fast running video and static over hdmi without it. Don't know if the hdmi issue is linked to librmtp in any way...
nikc0069 Wrote:Ok tried the latest testing build and everything smooth apart from the static on ac3. The guisettings file has vanished. Also by turning off surround the inlayer seems to work properly... Fast running video and static over hdmi without it. Don't know if the hdmi issue is linked to librmtp in any way...
Wait, not only do you have static w/ ac3 enabled you also have fast running video when its enabled?
guisettings.xml is at: /mobile/Library/Preferences/XBMC/userdata/guisettings.xml
just like before.
I do not believe the 'hdmi issue' which I assume you mean is the ac3 problem of static and 'fast running video (which only you have ever reported) and librmtp have anything to do with each other.
OwNeD162 Wrote:Just wanted to pop in and say, brilliant job!
Keep up the great work !
Thanks! I'll definitely have to check out Aeon65 skin.
