Guys,
I have installed all night builds on my Apple TV. The last build gave me troubles and I had to jailbreak Apple TV again and reinstall everything.
When trying to install the latest build (Feb,01) I got the following error:
Unpacking replacement org.xbmc.xbmc-atv2 ...
dpkg: dependency problems prevent configuration of org.xbmc.xbmc-atv2:
org.xbmc.xbmc-atv2 depends on org.xbmc.xbmc-seatbeltunlock; however:
Package org.xbmc.xbmc-seatbeltunlock is not installed.
dpkg: error processing org.xbmc.xbmc-atv2 (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
org.xbmc.xbmc-atv2
I didn't have "org.xbmc.xbmc-seatbeltunlock" before on the previous build and it worked. Do I need to install this file first? Where do I get it?
Thanks!!!
positiv
meshuga Wrote:The problem is we're getting users that didn't already install it normally.
This is an update, so follow:
http://wiki.xbmc.org/index.php?title=Ins...MC_on_ATV2
for ATV2
http://wiki.xbmc.org/index.php?title=Ins...Phone/iPad
for iOS.
then:
apt-get remove org.xbmc.xbmc-atv2
or
apt-get remove xbmc-ios on iOS
then proceed to do 'dpkg -i' on one of my .debs.
That worked! Thanks
I'm having a couple issues.
1) First, after XBMC is installed frontrow keeps rebooting in a loop. It does not stop until I remove my ethernet card from the AppleTV. Then the frontrow screen stays stable and I can reconnect the ethernet cable. It works normally after that.
2) Connecting using SMB with an IP address causes errors during scrapping movies. It starts scrapping a couple movies and then stops asking me yes or no to continue. This has not been a problem in my Mac Mini and PC running Dharma.
getting some buffering issues with a 720p mkv file with this new build, didn't seem to have issues yesterday on another mkv file.
for ATV2
for iOS.
then:
or
It'd probably remove some confusion if the original post had some of the following sections:
- 'Install Official XBMC' (using links you list above)
- 'Install Unofficial XBMC Build' (listing the Install XBMC section as a step, then lists other steps)
- 'Uninstall XBMC'
- 'Update Unofficial XBMC Build'
- 'What to do in case of trouble', i.e. uninstall XBMC > Install Official > Install Unofficial
Personally, I'm not sure what to do if I run into probs, i.e. remove XBMC and install the unofficial .deb or install the official XBMC first then install the unofficial .deb. When I get to that bridge I'll try both, but putting the info in the original post might answer a few questions before they're asked.
FWIW, and I don't mean to be a jackass so feel free to ignore, but the install/uninstall instructions might be easier to follow if they matched the formatting in the official build install instructions from the wiki (i.e. prefixed with a '$', and comments underneath).
jd2157 Wrote:It'd probably remove some confusion if the original post had some of the following sections:
- 'Uninstall XBMC'
Definitely. I will actually just post up the instructions to setup the repos so my build should just pull that stuff down and then you don't need to install the official XBMC repo. I wrote my other post in a rush and wasn't thinking.
Hope that's more clear. I didn't get as in-depth as you suggested, but if they can't understand that.. I really don't feel they should be trying this build.
meshuga Wrote:Definitely. I will actually just post up the instructions to setup the repos so my build should just pull that stuff down and then you don't need to install the official XBMC repo. I wrote my other post in a rush and wasn't thinking.
Oh ya, it's definitely more clear. If people can't follow that then ya I agree, move along folks, nothing to see here.
I prolly would've put only the links in for the preinstalls (to save some space, and avoid duplication) and used bullets (or nothing) rather than numbers in front of the $'s but I tend to obsess over documentation... left over psychological scars from a few years too many on the helpdesk back in the day
I've been testing latest build -020111- and xvid seems to be faster although not enough to be able to reproduce 720p xvid ac3 movies, a lot of buffering and evidently the software decoding is trying to catch up, using "sync playback to display: off, allow hardware acceleration: on, audio: optical, speaker configuration: 2.0, DTS and AC3 passthrough: on, no postprocessing and default bilinear scaling"
meshuga Wrote:Of course not, the hardware decoder for mpeg4 AVC stuff is superior to the ffmpeg software decoding. He's just making is better.
I've just answered my own question: all my mpegs and avis play flawlessly!! Off to order my next atv2!! Cannot thank you guys enough....
carcaussa Wrote:I've been testing latest build -020111- and xvid seems to be faster although not enough to be able to reproduce 720p xvid ac3 movies, a lot of buffering and evidently the software decoding is trying to catch up, using "sync playback to display: off, allow hardware acceleration: on, audio: optical, speaker configuration: 2.0, DTS and AC3 passthrough: on, no postprocessing and default bilinear scaling"
That is correct, xvid and other codecs that aren't h264 based (mpeg4 avc) are decoded in software and past SD resolutions isn't optimized yet. I will mention that in 1st post.
I am using ATV2 (4.2.1) and I have also some bugs to report:
- HDMI problem using philips 42pfl5604 LCD. It takes about 30 minutes that the display switches first to a green screen for about 1 second. After that the screen looks like there is a magenta and cyan filter overlayed. Then after 5 minutes screen is normal and the cycle starts again. Observed lately that times vary
- Problems when scraping and watching videos. XBMC wants to buffer video all the time while it is scraping. Would be better if all scraping actions are paused while playing video.
- BluRay Videos (m2ts) seem not to work flawlessly. Maybe Hardware is not powerful enough
- It is not possible to select deinterlacing. Maybe also due to missing hardware capabilities. Would it not be possible to give out interlaced video interlaced to the display? Then the deinterlacer of the device could do the job
- Live TV using UPNP (DVBViewer) is not working flawlessly (SD) or not working (HD)
- It is nearly impossible to handle pictures at the moment. XBMC is loading very long in picture folders. After loading a picture it is not displaying it. But pictures are displayed as thumbnail. Maybe it is in my case a little bit too much for the hardware because in the folders are many pictures from a DSLR.
- Sometimes xbmc crashes
But despite of this remaining bugs in the ATV version I want to say that XBMC is a great piece of software. I used it a long time on the XBOX and lately I came back to it using the windows version. Using PC it is nearly perfect (If some bugs are fixed and Live TV capabilities like in DVBViewer would be added it would be the ultimate HTPC software) and my reference. I hope it goes like this (surely considering the hardware capabilities) also for ATV.
Holding the menu-key for longer than 3 seconds crashes (or exits ?) XBMC. Is this by design ?
milchkuh Wrote:I am using ATV2 (4.2.1) and I have also some bugs to report:
This is probably not a XBMC issue but a problem with a few Philips and Sony TVs connected to the ATV2 in general. Looks like all Philips xxPFLxx04 Models are affected. AFAIK is Philips working on a Firmware update for this bug. See here for the official Apple Forum Thread regarding your problem:
http://discussions.apple.com/thread.jspa...5&tstart=0
EDIT: Just read that FW 4.3b for ATV2 will solve this problem.
1080p files have out of sync audio and the video skips frames. Using 020111 iOS build on my ipad.
