sh0x Wrote:I have ATV2 with XBMC (from yesterdays build 2/3), but I don't feel like the Confluence skin is very 'fluid'. I loaded PM3.HD and it's pretty good. But the Confluence skin is pretty slow compared to my little Zotac build. Huge difference.
Does this sound normal? Anyone else having sluggish performance navigating XBMC?
Using an Android phone for control shows how responsive it really is. Its really quick. I normally use a harmony remote for everything but for this I'm using my phone at the moment.
I installed new build 2 days a go...
itunes daap share (on mac I use firefly server) does not work and crash reboot system automatically.
Music library works! Yay! Just need visualizations now and it'll be perfect.
Q: the Facebook plugins launch a browser to sign in.
How do you quit out of this?
Please someone help me!!
I cant install it.
The step 7 said to me that there are not such file file ir directory
I think that i dont do it good
Library mode in Music is greyed out, but remote library w/ mysql works
Confirm. Music library works with remote mysql db.
I've moved to using reFocus + weather fanart and I'm happy with it.
http://forum.xbmc.org/showthread.php?tid=76954
...also needs some script.image.bigpictures support added as well - google it.
Anyone not having buffer issues on 720P in the 03/04 builds? Never had it before, but now i got buffering issues every 15 min. 03 was worse than 04 but it's still not good.. Btw its over cable from a WHS with SMB
Eliah Wrote:Anyone not having buffer issues on 720P in the 03/04 builds? Never had it before, but now i got buffering issues every 15 min. 03 was worse than 04 but it's still not good.. Btw its over cable from a WHS with SMB
Jup same here, 720p over SMB from a Drobo FS. No problem before the 04 update now buffering around every 10-15 minutes. Maybe it has something to do with the changes made to SMB showin in the
Commit History.
zirbio Wrote:Please someone help me!!
I cant install it.
Best if you can copy/paste the command you're using and the error that you're seeing. It's pretty hard for people to help without the details of the issue.
If I was to guess, I assume you mean step 7 of the install/update instructions, where you run the dpkg command. If it says no such file or dir then you probably made a typo in the .deb file name or in the wget command so the .deb file actually didn't download and isn't in that directory.
Long story short, try the install/uninstall steps again and before typing the dpkg command do an "ls" in the directory to see if the file is there. Make 100% sure you type the right name into the dpkg command. That being said, no offense but if you aren't comfortable working at the command line these unofficial builds may not be for you.
jd2157 Wrote:you probably made a typo in the .deb file name or in the wget command
I'll second that, and add a couple of extra pointers.
1) Make sure you copy the full name for the wget command; the URL pointed to be the forum post is intact, but the text displayed in your browser is usually a shortened version (with ".." stuck in the middle). If copy and pasting the URL from the forum, choose "copy link" (or similiar, dependending on your browser) rather plain old "copy".
2) The wget command needs the full path/url, but the dpkg and rm commands only require the
filename part at the end of the url.
Cyzor Wrote:Jup same here, 720p over SMB from a Drobo FS. No problem before the 04 update now buffering around every 10-15 minutes. Maybe it has something to do with the changes made to SMB showin in the Commit History.
Has anyone found a fix for this? I tried downgrading, but strangely the older builds also seems to have a buffer issue now..
