So you are saying yourself that this is not a bug report? Well then I will definitely not look at it.
So while it is mentioned in the settings it supports poster and fanart and you say it doesn't is then blatantly a lie and i will remove it at once.
A lot of assumptions were made (and mostly wrong) before i had time to look at and since no one even cared to share a logfile of what was happening or whatever i couldn't even care less any more about it.
Besides what do you think i added this to the OP
Quote: ONLY use http://pastebin.com/ or http://paste.ubuntu.com/ and post the link together with a description of the problem.
just for it to be ignored it seemed.
See here
http://forum.xbmc.org/showthread.php?tid...pid1493894
he posted the issue
INCLUDING a
Debug Log and guess what, i saw what the problem was and can fix it.
But i guess those rules don't apply to you then.
Good luck figuring it out
(2013-08-28, 17:54)Martijn Wrote: [ -> ]So you are saying yourself that this is not a bug report? Well then I will definitely not look at it.
See here
he posted the issue INCLUDING a debug log and guess what, i saw what the problem was and can fix it.
(2013-08-28, 17:51)tinybutstrong Wrote: [ -> ]...Our question isn't a bug report, since poster/fanart download seems to be unsupported by your add-on...
http://dictionary.reference.com/browse/seem
Yes, I'm not reporting a bug because as I said before, it
seems to be an unsupported feature¹. Who can confirm that is (may be) a bug is only you. Be careful before to claim a lie.
[1] download/save the poster image to the movie folder.
The poster load fine on XBMC cache, just not copied/saved/downloaded to the movie folder.
don't try to lecture me on English!
ok then i will just ignore it completely in that case. i wish you happy hunting
(2013-08-28, 18:24)Martijn Wrote: [ -> ]don't try to lecture me on English!
You have peace for now, at least from me. This is my last message about this question.
Good luck with all other users asking the same thing....
Please can someone help. I have been trying to get fanart backdrops working for Actors but even though downloading fanart images themselves isnt a problem, I seem to be stuck with the default backdrop unlike the movie and tv show screens which work absolutely fine with fanart working as it should. Below are pictures to maybe better show what I mean..
tv fanart fine
select fanart for actor
selected fanart in place
no background fanart for actor - option set correctly?
not sure whats wrong but any help would be great!
thanks
David
That is not within support of this addon. Start a new thread in help section
Martijn, something I've noticed since the recent update. whenever I attempt to download Art, I get a script error. Prior to the update I had no problems.
I uninstalled and re-installed but the issue remains.
(2013-08-29, 23:10)PatOso Wrote: [ -> ] (2013-08-29, 22:57)hoopsdavis Wrote: [ -> ]Martijn, something I've noticed since the recent update. whenever I attempt to download Art, I get a script error. Prior to the update I had no problems.
Not work for me.
And such posts are utter useless.
I have to go to work, tomorrow I upload the log. Thanks Martijn.
Strange thread title, what's that all about?
(2013-08-30, 00:50)MilhouseVH Wrote: [ -> ]Strange thread title, what's that all about?
Tapatalk screwed it up. Thx
Hi
I´m having the same issue while trying to download new art. Below you can see the Error in my XBMC log, Thanks.
---removed log spam---
