(2017-12-04, 14:41)Bitter Wrote: [ -> ]Here is my log
https://pastebin.com/CXASucP4
I think there are a lot of "garbage", but you could find what you want
It's strange, it seems that the Artwork.Download stop or crash during your log, but I don't know why. And this is hard to know from the log if it stop while kodi startup or when you open the dialog or just when you try to search something. I need a log after kodi finish its startup, after open the Artwork Downloader dialog, and after pressing 'Fanart' for searching.
By the way, what is your OS, Kodi version and skin that you are using?
(2017-12-04, 15:57)burekas Wrote: [ -> ]By the way, what is your OS, Kodi version and skin that you are using?
Kodi 17.6
OS Windows 10 64bits
Artwork downloader - Your version with my keys
Skin - Aeon MQ7 2.0.7.5
As i told before, there is some interaction with other script or something like that wich mades artworkdownloader don't work
Two computer, same version os Kodi, same version of OS, same version of artworkdownloader in one doens'r work neither movies and tvshows and in one works with tv shows but not movies.
Booth cases the same error ID NOT FOUND
This is the last error log, after delete all and start again
18:30:23.663 T:1228 NOTICE: Artwork Downloader: ######## Artwork Downloader: Initializing...............................
18:30:23.663 T:1228 NOTICE: Artwork Downloader: ## Add-on Name = Artwork Downloader
18:30:23.663 T:1228 NOTICE: Artwork Downloader: ## Version = 14.2.0.0
18:30:25.611 T:1228 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('rating',)
File "C:\Users\Kodi\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py", line 824, in <module>
Main()
File "C:\Users\Kodi\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py", line 140, in __init__
self.download_artwork(mediaList, providers['movie_providers'])
File "C:\Users\Kodi\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py", line 409, in download_artwork
self._download_process(currentmedia)
File "C:\Users\Kodi\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py", line 433, in _download_process
self._download_art(currentmedia, art_type, currentmedia['artworkdir'])
File "C:\Users\Kodi\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py", line 543, in _download_art
pref_language)
File "C:\Users\Kodi\AppData\Roaming\Kodi\addons\script.artwork.downloader\lib\apply_filters.py", line 34, in filter
return fanart(data)
File "C:\Users\Kodi\AppData\Roaming\Kodi\addons\script.artwork.downloader\lib\apply_filters.py", line 90, in fanart
elif limit.get('limit_artwork') and data.get('artwork')['rating'] < limit.get('limit_extrafanart_rating'):
KeyError: ('rating',)
This error appears when I go to addons - artworkdownloader - execute
Bitter
Are you sure you check it like this: Library -> Movie -> Movie information -> choose art -> Artwork download dialog opened -> Fanart?
This is how the log should be: (Checked on 'Wonder Woman')
https://pastebin.com/UAxV4MCy
Your Artwork Downloader addon is terminated for an unknown reason.
I saw that there are a lot of messages regarding the Extrafanart that I don't use I think, maybe it relate to it.
I don't like to do the 'execute' operation, because it change all the fanarts in the library sometime, and some of them I chose manually.
By the way what is your skin? because the OS, Kodi and the addon version are the same.
(2017-12-04, 21:01)burekas Wrote: [ -> ]Are you sure you check it like this: Library -> Movie -> Movie information -> choose art -> Artwork download dialog opened -> Fanart?
I don't know what do you mean....Can you post a picture?
(2017-12-04, 21:01)burekas Wrote: [ -> ]By the way what is your skin? because the OS, Kodi and the addon version are the same.
I use Aeon MQ7 2.0.7.5. I also ask into the Aeon MQ forum trying to solve the problem, but at this moment no solution yet
Since the releaser of the artwork downloader has abandoned the plugin has progressively worked ever worse ... until it no longer works ....
I will have to settle for the posters only .... goodbye clearart, logos and discart
As long as it was enough to place the pvt API keys in the two .py files was still acceptable, but now it seems to me that there is a new problem always lurking at every slightest variation....
I don't have any problem anymore with Artwork Downloader (With the version I have created and fixed 14.2.0.0 =>
Post #2971 )
I'm using Titan skin. Try to switch to another skin and check again.
Manually searching with Artwork Downloader.
Choose 'Fanart' for example
Here are the results (Came from Fanart.tv + themoviedb.org)
(2017-12-04, 23:26)burekas Wrote: [ -> ]I don't have any problem anymore with Artwork Downloader (With the version I have created and fixed 14.2.0.0 => Post #2971 )
https://s33.postimg.org/6dq4c26bz/screenshot019.png
https://s33.postimg.org/lz7fw0akf/screenshot018.png
I downloaded and tried to install your zip file and give me error when I try to import it from the "install from zip" add-on menu with 17.6 krypton and Aeon mq7 skin.
(2017-12-04, 23:35)marci0 Wrote: [ -> ]I downloaded and tried to install your zip file and give me error when I try to import it from the "install from zip" add-on menu with 17.6 krypton and Aeon mq7 skin.
This could happen if the folder of the addon is open, or one of the files there is in use.
Close all the explorer windows.
Try to uninstall it first. Close and open kodi, try install it from the zip again (Don't forger to enter your own api keys after that)
(2017-12-04, 23:39)burekas Wrote: [ -> ] (2017-12-04, 23:35)marci0 Wrote: [ -> ]I downloaded and tried to install your zip file and give me error when I try to import it from the "install from zip" add-on menu with 17.6 krypton and Aeon mq7 skin.
I put it manually on OSX (do not use windows), the plugin is now updated ... I replaced the keys ... "111111111111111".
"2222222222222"
... but .....
no way .... Provider ID error ....
Noooooooope.
