(2014-05-12, 18:20)XBL. Wrote: [ -> ]I'm curious if there's an easy way to "clean" central directories. I've removed a couple of TV shows that I don't watch anymore, but the fanart is still in that directory.
I'm having the same issue. I have cleaned the library, but no luck. Any information would be greatly appreciated.
[RELEASE] Texture Cache maintenance utility
http://forum.xbmc.org/showthread.php?tid=158373
(2014-05-18, 09:16)CaptainKen Wrote: [ -> ] (2014-05-12, 18:20)XBL. Wrote: [ -> ]I'm curious if there's an easy way to "clean" central directories. I've removed a couple of TV shows that I don't watch anymore, but the fanart is still in that directory.
Thanks for the quick reply. I've read through the Texture Cache maintenance utility (a tad complicated for my tech experience level). Will this clean the extrafanart folder?
What do you mean by "clean" - do you mean will it physically delete the artwork you've created somewhere on your file system now that you've removed the show from the library? No, it won't do that, apart from the risk involved (of automating the physical removal), it doesn't seem like a particularly difficult task to accomplish manually.
It will however automatically remove associated artwork from your texture cache if you run the "P" (prune) option. If you're using extrafanart, enable extrafanart support with cache.extra=yes in texturecache.cfg.
is there a problem with fanart.tv or with AD ? I could not get extrathumbs.
I know you want complete logfiles but i hope this is enough to say something.
Movie is 12 years a slave
22:43:10 T:140163757889280 NOTICE: Artwork Downloader: ######## Artwork Downloader: Initializing...............................
22:43:10 T:140163757889280 NOTICE: Artwork Downloader: ## Add-on Name = Artwork Downloader
22:43:10 T:140163757889280 NOTICE: Artwork Downloader: ## Version = 12.0.25
22:43:10 T:140163757889280 ERROR: Artwork Downloader: Download timed out: u'http://d3gtl9l2a4fn1j.cloudfront.net/t/p/w780/xnRPoFI7wzOYviw3PmoG94X2Lnc.jpg'
22:43:10 T:140163757889280 ERROR: Artwork Downloader: Download timed out: u'http://d3gtl9l2a4fn1j.cloudfront.net/t/p/w780/i3y1iT9E3P9ort62F0seZFVSuPa.jpg'
22:43:10 T:140163757889280 ERROR: Artwork Downloader: Download timed out: u'http://d3gtl9l2a4fn1j.cloudfront.net/t/p/w780/eRBVfONVhcVuueJ5ksKvPuCLLvy.jpg'
22:43:10 T:140163757889280 ERROR: Artwork Downloader: Download timed out: u'http://d3gtl9l2a4fn1j.cloudfront.net/t/p/w780/kQffwFRnvc7WSzwAlKaLF5aePzH.jpg'
22:43:12 T:140163757889280 NOTICE: Artwork Downloader: script stopped
(2014-05-19, 22:50)Eisi2005 Wrote: [ -> ]Hi,
I had some kindda problem yesterday too, AD was not downloading art, in the pop up window i could not even see the thumbnails to chose from.
(2014-05-18, 17:47)MilhouseVH Wrote: [ -> ]What do you mean by "clean" - do you mean will it physically delete the artwork you've created somewhere on your file system now that you've removed the show from the library? No, it won't do that, apart from the risk involved (of automating the physical removal), it doesn't seem like a particularly difficult task to accomplish manually.
Thanks for your reply. And yes, by clean I actually mean physically removing the fanart of movies and tvshows that are no longer in my library.
I don't see an easy way of doing it manually (sorting through 100s of files) and would end up automating it anyway. I was just wondering if somebody already made a script for this or if there's someway this can be done with the add-on.
(2014-05-20, 09:07)XBL. Wrote: [ -> ]Thanks for your reply. And yes, by clean I actually mean physically removing the fanart of movies and tvshows that are no longer in my library.
It wouldn't be difficult to write a script that walks your source directories comparing every file against the contents of your media library, and remove any file that isn't present in the media library. You can dump your media library using the aforementioned script (jd movies/jd tvshows/jd songs). You can even get a list of files in your source directories with "rdirectory <path>". Then compare the results. You do of course run the risk of deleting a file you wanted to keep, it all depends what else you have stashed alongside your sources.
Hey all,
Artwork Downloader doesn't seem to be working in Gotham, it wont scrape any artwork (error Downloading File) Movies and TV shows
Anyone have any insight?
(2014-05-20, 18:35)Buzniak Wrote: [ -> ]Hey all,
Will be fixed shortly.
Also thx for not posting a
Debug Log which could have helped resolve the issue.
(2014-05-20, 19:39)Martijn Wrote: [ -> ] (2014-05-20, 18:35)Buzniak Wrote: [ -> ]Hey all,
Also thx for not posting a Debug Log which could have helped resolve the issue.
I don't know where the DUBUG log is (I set the debug option to on, but cannot find the log) sorry I don't know how to; But thanks for your Patronization.
PasteBin was down so i used speedyshare, just DL the log
I found the log, here it is:
http://speedy.sh/q2FvJ/xbmc.log
<a href="http://speedy.sh/q2FvJ/xbmc.log">Download at SpeedyShare</a>
All working now, thanks for the fix
I'm also getting errors while scraping movies. The previous poster said "all working now, thanks for the fix". I downloaded from GIT but it's still doing the same thing.
Edit for clarification...I don't get errors until I manually try to grab a poster or disc art, it seems to find items but there are no thumbnails for them and only then do I get an error if I try to download something.
(2014-05-22, 06:38)Martijn Wrote: [ -> ]Don't use git
Ok, then what do I use? I have 12.0.26 installed. Should I uninstall and reinstall from repo?
