(2017-10-08, 23:27)ohmykod Wrote: [ -> ]I took the liberty to add settings in the addon to input the APIs directly from kodi and changed the tvdb.py, tmdb.py and fanarttv.py on lines 33-35 to let the addon read from them
for example:
Quote:import xbmcaddon
Settings = xbmcaddon.Addon().getSetting
API_KEY = Settings('tmdb.api')
The addon can be found here: https://www.dropbox.com/s/oeyyd9tcmvatq0...0.zip?dl=0
If it's against the rules feel free to delete this post, I dont want in any way cause any disrespect to the dev, it's just that my library needed this addon badly and I thought to share the fix here.
Does anyone still have this version somewhere? it is the only one I could get clear logos to work and I accidently deleted it. I would use artwork beef if Titan supported but sadly it doesn't.
****Edit please disregard I found a copy of 14.4 and it works.
can someone please tell me how to install Artwork Beef? I have a zip file but it seems to just be a txt file and im not sure how to install it like that. Please can someone give me the correct download file or source code to install the addon or program. Or if you know of any other program or addon i can use that will download extended artwork, not just posters or fanart. I am still using earlier Kodi version and Artwork Downloader no longer will scrape for extended artwork....such as banners and thumb16.9 Thank you
Is it possible to call the artwork downloader script from a linux command line?
I've had sucess calling a library update and clean but can't get calling the artwork downloader script.
Mike
Sorry to hear it's no more.
Thanks for the reply.
NeoDuck
read my post two posts up.
Notice to Members
Support for the Artwork Downloader add-on ended mid to late 2017. The add-on has been marked as Broken in the official Kodi Repository for all versions.
If you are still using this add-on, there is no support available. Many members have switched over to
Artwork Beef.
This note from the add-on developer will explain the reasons for the end of this add-on...
https://forum.kodi.tv/showthread.php?tid=327035
Thread Closed
