thebigsneakus Wrote:Ok, you've just about made my year. I'm sitting in my hotel room 1500 miles away from home, watching live streaming HDTV from my house on my iPad. This is truly an incredible piece of work. I have a lot of feature requests but I'll sit on them for now just so I can play with this thing. I got pretty frustrated last weekend trying to get it working well before this trip (glimmers of hope, then it would screw up). Just loaded up 1.7 on the home computer (god bless LogMeIn) and it suddenly works like a freaking champ. Thanks for all your hard work. Truly impressive.
Sorry for the previous versions! Glad you like 1.7!
Uploading pic of iphone interface
Note: this is a web app...
TODO: quality/resolution
Let me know what you guys think!
That's a really good start. Don't forget about the iPad.
So what time are we going to sleep tonight?
the only problem i could see just by looking at that interface in terms of the hdhomerun prime is that tuners are automatically given via a "pool".. i dont believe they are statically mapped like the ceton.. i could be wrong tho.
uspino Wrote:That's a really good start. Don't forget about the iPad.
Not sure... hopefully it will be quick
Resolutions: 720, 576, 480, 320, 240
Three qualities: Low Medium High (Need to figure out bitrates for iPhone <-- need help on this)
gman3042 Wrote:the only problem i could see just by looking at that interface in terms of the hdhomerun prime is that tuners are automatically given via a "pool".. i dont believe they are statically mapped like the ceton.. i could be wrong tho.
It does have pooling but it will prob be easier to start off with static tuners for me.
mcheng89 Wrote:Not sure... hopefully it will be quick
To be on the safe side (iPad 3) throw in 1080 for the iPad (although iPhone+1080+Airplay looks like a dream combination....)
What are you thinking for channel listing? Pages with previous/next are very inconvenient for today's large channel lists. Maybe three options: "Input Channel", "EPG", "Favourites"?
uspino Wrote:To be on the safe side (iPad 3) throw in 1080 for the iPad (although iPhone+1080+Airplay looks like a dream combination....)
Input channel + Settings done....
Todo: Channel list + favorites + bitrate+resolution still hardcoded
For anyone who wants to try it:
http://www.mediafire.com/?70qv52abx7c4yyl
uspino Wrote:This is what I get at http://localhost:8555/m/
Weird... works fine for me. Did you replace your entire webfiles folder? Did you refresh? I see the new site fine.
You need to replace remoteCeton also.
Safari doesn't like CSS files unless I set the content type too
mcheng89 Wrote:You need to replace remoteCeton also.
Now we are talking! It's really nice. It looks like it is a lot of work to make it work right with rotation, video, etc. When I input channel number I get this pop-up:
When I click ok video starts normally.
EDIT: I'm guessing Fovorites is the harder to implement because it requires user input. At this point, maybe you could just explain users how and where to add the code line for a specific channel/logo.
uspino Wrote:Now we are talking! It's really nice. It looks like it is a lot of work to make it work right with rotation, video, etc. When I input channel number I get this pop-up:
Favorites isn't too big of an issue. The layout still might change.
I think I have a decent way of showing channels with pages
Not too sure how I feel about the channel input tab. Maybe a popup instead?..
This layout was made for the iPhone screen size. if I made a iPad one it would look different
Also if anyone has an Android honeycomb device, I think the video should also work!
One thing I noticed, on channels with a scrolling ticker (usually sports & news), if you look at the text there's a noticeable little jump on the video every half a second. It only happens on iOS devies. I'm assuming it has to do with FPS or interlacing, but maybe someone with video econding knowledge can shed some light about it.
gman3042 Wrote:http://pastebin.com/reV04BRn
tehre you go
here's hoping
Todo: figure out how to read this file :|
^Should be easy... There's a lot of hdhomerun strm generators
I have been been following this thread but havent had much time to give any input lately.. I started working on parsing epg data on my webpage so my brother can watch tv from the marine base in okinawa, japan. It would be much easier to handle this data if it was sent by the remoteceton api in xml format, that way simple javascript xml handling can be used.. For now I probably just parse the xml file that is downloaded by mc2xml. Just a thought!
