2013-04-01, 04:53
(2013-04-01, 04:02)mcheng89 Wrote: [ -> ]@jfoley, dbqbbq: can you try this one? http://www.mediafire.com/?dtxn3w5bem4h09j
Seems like that works.
(2013-04-01, 04:53)jfoley Wrote: [ -> ](2013-04-01, 04:02)mcheng89 Wrote: [ -> ]@jfoley, dbqbbq: can you try this one? http://www.mediafire.com/?dtxn3w5bem4h09j
(2013-04-03, 02:40)Wuping Wrote: [ -> ]Hey guys I'm trying to get through this setup, I followed the directions that are in the install.txt file. The problem I'm having is when I go to Programs in XBMC and select tv:erver I get Unable to download the channel listings, so im kinda stuck at step 4 of the SETUP XBMC python addon. anyone know why I'm getting this error?
(2013-04-03, 03:40)mcheng89 Wrote: [ -> ](2013-04-03, 02:40)Wuping Wrote: [ -> ]Hey guys I'm trying to get through this setup, I followed the directions that are in the install.txt file. The problem I'm having is when I go to Programs in XBMC and select tv:erver I get Unable to download the channel listings, so im kinda stuck at step 4 of the SETUP XBMC python addon. anyone know why I'm getting this error?
Actually I think the error I have is kind of misleading (I should fix it). I didnt notice it, but it should actually say that it wasnt able to write the channel list to a cache file. Do you have write permission for the <addon folder>/resources/tv_server folder? Is this windows/linux?
Does the web interface work for you? http://<server ip>:8888/m/
v0.5.8: Plex plugin release
http://www.mediafire.com/?ky2chaxj476xalb
Known issues:
- transcode settings is hardcoded
- only tested to work on iphone/ipad so far
- no icon/background images
- server port is hardcoded to 8888
(2013-04-03, 04:06)Wuping Wrote: [ -> ]thanks for the reply yes I have write permissions to the folder, it is a windows 7 machine. When I go the the ip address it brings up the tv guide but then says can not load channel list
(2013-04-03, 04:10)mcheng89 Wrote: [ -> ](2013-04-03, 04:06)Wuping Wrote: [ -> ]thanks for the reply yes I have write permissions to the folder, it is a windows 7 machine. When I go the the ip address it brings up the tv guide but then says can not load channel list
Ok, I just double checked. I was wrong; the error was correct. For some reason the server didnt give you any channels back.
Are you using ceton or hdhomerun? If you go to http://<ip address>:8888/getChannels do you get any data? Is there any data in the resources/ChannelMap-*.csv file (* would be replaced with the device type)?
(2013-04-03, 04:27)Wuping Wrote: [ -> ]I'm using a hdhomerun prime, when I type it in nothing comes up just a white screen. the ChannelMap-HDHomeRunPrime.csv file is there but it's showing 0kb in the file size
(2013-04-03, 04:36)mcheng89 Wrote: [ -> ](2013-04-03, 04:27)Wuping Wrote: [ -> ]I'm using a hdhomerun prime, when I type it in nothing comes up just a white screen. the ChannelMap-HDHomeRunPrime.csv file is there but it's showing 0kb in the file size
Are you on the latest firmware? After updating, does http://<hdhomerun ip>/lineup.json?show=unprotected return anything?
If not, can you go to http://<hdhomerun ip>/lineup.html and click detect channels.
Then can you delete the ChannelMap-HDHomeRunPrime.csv and reload the app?
Todo: Throw some kind of error when channel map is empty.
(2013-04-03, 04:48)Wuping Wrote: [ -> ]Yes I have the latest firmware installed *20130328*, I get a lineup.json file when I run http://<hdhomerun ip>/lineup.json?show=unprotected. I deleted the ChannelMap-HDHomeRunPrime.csv and opened the mc2xml but still getting the can not load channel list error
(2013-04-03, 15:58)jfoley Wrote: [ -> ]Quick question... When I add my HD Homerun Prime device, there are two options. One with HTTP and one without. Which should I chose or what is the difference?
