That actually doesn't work for me. Here are some screenshots showing the attempt. I'm thinking there has got to be something on my machine that is conflicting, but there are no logs to look at and see what the problem could be. Is there some way to turn on debug logs for the ceton server to get more information??
You are testing on the same machine where remoteceton is installed?
This is what mine is showing:
[9.4.2012.13:19:10]: Tuner[4]: Changing channel number to 173
[9.4.2012.13:19:10]: Tuner[4]: Program number is 2
[9.4.2012.13:19:10]: Tuner[4]: Channel name is ESPN HDTV
[9.4.2012.13:19:11]: Tuner[4]: rtsp://192.168.1.53:8554/cetonmpeg3
[9.4.2012.13:19:11]: Tuner[4]: Starting video stream
[9.4.2012.13:19:11]: VLC[4]: Starting VLC instance with remoteVLC plugin
[9.4.2012.13:19:11]: VLC[4]: Transcode settings [type=ts,vb=1500,res=480]
[9.4.2012.13:19:11]: VLC[4]: Streaming to http://localhost:8559
[9.4.2012.13:19:11]: VLC[4]: Setting stream program id using remoteVLC
[9.4.2012.13:19:12]: Error: connect() returned error 10061.
[9.4.2012.13:19:12]: VLC[4]: Attempt 1 of 3 failed...
[9.4.2012.13:19:12]: Tuner[4]: rtsp://192.168.1.53:8554/cetonmpeg3
[9.4.2012.13:19:12]: Tuner[4]: Starting video stream
[9.4.2012.13:19:12]: VLC[4]: Starting VLC instance with remoteVLC plugin
[9.4.2012.13:19:12]: VLC[4]: Transcode settings [type=ts,vb=1500,res=480]
[9.4.2012.13:19:12]: VLC[4]: Streaming to http://localhost:8559
[9.4.2012.13:19:12]: VLC[4]: Setting stream program id using remoteVLC
[9.4.2012.13:19:14]: Scheduler: Sleeping 90 seconds until next task
Did you install the VLC control plugins? They are listed in INSTALL.txt.
Also make sure you have latest VLC installed (v2.0.3).
Yes the vlc plugin has been installed already. I am testing locally on the same pc as where the ceton server is installed and I am using the latest version of VLC.
I'm new to the PC version of XBMC (only been using 3 weeks, 2 of those weeks I've spent trying to set this up, I havent used XBMC since I modded my old XBOX, and used it as the dash.
I'm having problems getting my channels to show up on LiveTV.
My setup
Windows 7 (x64)
Ceton Infinitv pci card
XBMC Eden-11.0 rev.8 (pulse eight)
I have all the ports, plus extras open (8555-8565)
I moved all the files to the addon folders
I have affiliates, logos, settings, and xmltv .xml files in userdate/addon_data/resources and
addons/pvr.ceton/resources
What works
I can stream from VLC
I can use the web side streamer (also on my android phone)
The video plugin CetonTV that uses Pseudo also works
My channels.csv are in this format:
169,NFL HD,2
171,AMC HD,20
172,TV One (digital),4
173,ESPN HDTV,2
My log
PHP Code:
05:13:46 T:5144 NOTICE: PVRManager - starting up
05:13:46 T:5144 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
05:13:46 T:5144 NOTICE: initialize done
05:13:46 T:5144 NOTICE: Running the application...
05:13:46 T:5160 NOTICE: VideoInfoScanner: Starting scan ..
05:13:46 T:1772 NOTICE: -->Python Interpreter Initialized<--
05:13:46 T:5144 NOTICE: Webserver: Starting...
05:13:46 T:5144 NOTICE: WebServer: Started the webserver
05:13:46 T:5144 NOTICE: starting upnp server
05:13:46 T:5144 NOTICE: starting upnp renderer
05:13:46 T:5144 NOTICE: ES: Starting event server
05:13:46 T:3028 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
05:13:46 T:3028 NOTICE: UDP: Listening on port 9777
05:13:46 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: ADDON_Create - Creating the PVR demo add-on
05:13:46 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: ADDON_SetSetting()
05:13:46 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: ADDON_SetSetting - 720
05:13:46 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: LoadChannelMap()
05:13:46 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: Downloading channelmap from server...
05:13:46 T:3064 ERROR: CRemoteControl::Connect - failed to connect
05:13:47 T:5160 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
05:13:47 T:5776 NOTICE: -->Python Interpreter Initialized<--
05:13:47 T:4032 NOTICE: -->Python Interpreter Initialized<--
05:13:47 T:264 NOTICE: -->Python Interpreter Initialized<--
05:13:47 T:3664 NOTICE: -->Python Interpreter Initialized<--
05:13:47 T:6280 NOTICE: -->Python Interpreter Initialized<--
05:13:47 T:2344 NOTICE: -->Python Interpreter Initialized<--
05:13:47 T:7052 NOTICE: -->Python Interpreter Initialized<--
05:13:47 T:4908 NOTICE: -->Python Interpreter Initialized<--
05:13:47 T:1468 NOTICE: -->Python Interpreter Initialized<--
05:13:47 T:4032 NOTICE: RCB Service: Start
05:13:47 T:4032 NOTICE: RCB Service: launch RCB on startup =
05:13:47 T:4032 NOTICE: RCB Service: scrape games on startup = false
05:13:47 T:4032 NOTICE: RCB Service: Done
05:13:47 T:5776 NOTICE: Settings changed: False
05:13:47 T:5776 NOTICE: [script.tvguide] Caching XMLTV file...
05:13:47 T:4908 NOTICE: StorageServer Module loaded RUN
05:13:47 T:4908 NOTICE: StorageClient-1.1.0 Starting server
05:13:47 T:4908 NOTICE: StorageServer-1.1.0 Storage Server starting C:\Users\ezcape68\AppData\Roaming\XBMC\userdata\Database\commoncache.db
05:13:47 T:5776 NOTICE: [script.tvguide] Scheduling notifications
05:13:47 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: Parsing channelmap data...
05:13:47 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: GetTunerStreamUrl()
05:13:48 T:1468 NOTICE: SKIN == True
05:13:48 T:3664 NOTICE: Artwork Downloader: ## Service - Run at startup: False
05:13:48 T:3664 NOTICE: Artwork Downloader: ## Service - Delayed startup: -- minutes
05:13:48 T:3664 NOTICE: Artwork Downloader: ## Service - Run as service: False
05:13:48 T:3664 NOTICE: Artwork Downloader: ## Service - Time: 00:00
05:13:48 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: Tuner streams to url:
05:13:48 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: GetAddonCapabilities()
05:13:48 T:5284 NOTICE: AddOnLog: CetonTV: PVRCLIENT: GetConnectionString()
05:13:48 T:2816 NOTICE: AddOnLog: CetonTV: PVRCLIENT: GetChannels()
05:13:48 T:2816 NOTICE: EPG::CEpgContainer::Start - EPG thread started
05:13:48 T:156 NOTICE: AddOnLog: CetonTV: PVRCLIENT: GetChannelsAmount()
05:13:48 T:156 NOTICE: AddOnLog: CetonTV: PVRCLIENT: GetBackendName()
05:13:48 T:156 NOTICE: AddOnLog: CetonTV: PVRCLIENT: GetBackendVersion()
05:13:48 T:156 NOTICE: AddOnLog: CetonTV: PVRCLIENT: GetConnectionString()
05:13:53 T:3148 NOTICE: -->Python Interpreter Initialized<--
05:14:08 T:5564 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
05:14:16 T:5144 ERROR: Control 20 in window 10605 has been asked to focus, but it can't
05:14:30 T:5144 ERROR: Previous line repeats 2 times.
05:14:30 T:5144 NOTICE: Storing total System Uptime
05:14:30 T:5144 NOTICE: Saving settings
05:14:30 T:5144 NOTICE: stop all
05:14:30 T:5144 NOTICE: PVRManager - stopping
When I go to LiveTV I can't see any channels
When I go to settings/LiveTV there are no channels in the manager
Am I missing something?
Looking at the code for this, what does the VLC plugin do?
I understand remoteCeton is talking to VLC to get it to play and transcode the video from the ceton.
What part does the VLC plugin play?
I see in the thread there is a link to a GitHub for the plugin, but it is empty.
I have a question about the Program Guide.... I can get it work on my iPhone and on my wireless laptop but for some reason it does not work on my bedroom PC. Any thoughts?
(2012-09-09, 22:52)emann Wrote: [ -> ]Looking at the code for this, what does the VLC plugin do?
It acts as a filter for the program id. I could use the program-id command option, but I saw that that didnt seem to work 100% of the time. So, I'm using the plugin to filter the program id and check that the stream is correct (has the program id).
I'll upload the code for the plugin this week.
Gonna try to put some more time back into this proj
. Busy with other stuff right now
Have some tweaks I want to make... and then I want to see if its possible to connect this to Plex
(2012-09-04, 19:42)angrycamel Wrote: [ -> ]That actually doesn't work for me. Here are some screenshots showing the attempt. I'm thinking there has got to be something on my machine that is conflicting, but there are no logs to look at and see what the problem could be. Is there some way to turn on debug logs for the ceton server to get more information??
so far, it looks like gman3042 is the only one who has hdhomerun working... I dont really have one to test but I guess I can start by adding more logs
ezcape
Did you modify the url out? or was it always like this?
ezcape Did you modify the url out? or was it always like this? CetonTV: PVRCLIENT: Tuner streams to url:
DIdn't modify, must have been like that
Is there a way to connect to the Remote Ceton through Iphone or Android Phone?
(2012-09-12, 03:13)dsherley9 Wrote: [ -> ]Is there a way to connect to the Remote Ceton through Iphone or Android Phone?
http:// <IP address> :8555/m/iphone.html
OK eliminated this problem
I guess the problem I'm having is in the GLOBAL CONFIGS
Not sure how to set everything
this is what I have
SERVER_CONTROL_PORT=8555
SERVER_SECURED=true
SERVER_USERNAME=admin
SERVER_PASSWORD=admin
VLC_PROCESS=C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
#VLC PORTS are for the first tuner.
#For each port besides the first, the port = tuner 1 port + the tuner number - 1.
#Example: If VLC_STREAM_CTRL is 2386 for tuner 1, tuner 2 is 2387, etc.
VLC_STREAM_CTRL=8080
VLC_STREAM_PORT=8566
#Allow downloading of programming guide data
#Valid values are true or false
EPG_ENABLED=true
#Sets the hour of day to download the epg. This is downloaded daily
#Values are from 0 to 23.
EPG_HOUR_OF_DAY=3
I am also having a trouble gathering EPG data. When using the guide I have "No Program Info" for any channel. My epgdata file is only 6kb. When viewing it using the web interface, it also displays "No Program Info". I'm stumped as to why it is not gathering any data and I'm not certain what to try to resolve it.
By the way, thank you for creating this, its fantastic.
I have a Raspberry Pi and the Ceton TV program works great for streaming from my Windows 7 PC to the Pi. Just wondering if it would be possible for it to show up in the "Live TV" section rather than the Programs section? When I turn on the Pi it says no compatible PVR clients installed and asks me to select one, but nothing shows up.
Keep up the great work!
does rasberry pi have a pvr build? you need a pvr build.
or wait for frodo, pvr is merged into the mainline
Yes, raspmbc has a PVR build if you install the nightly version. The only thing I see as a problem is that the ceton.dll file needs to be adapted and compiled for linux.
On another note. I tried the PVR option in a frodo alpha release on my Windows 7 machine. It finds the plugin fine, but won't add any channels. How do I go about auto adding channels, or do I have to add them each individually?
