I can confirm CetonTV will not stream encrypted channels, through XBMC directly or iPhone/iPad. This, of course, totally sucks because Time Warner Cable has all channels marked as such except the basics of the basic (only local like fox, nbc, etc, in sd or hd).
Is there a way to stop VLC when I'm done watching remote TV?
Once someone connects and starts watching TV VLC is always running and encoding in the background, taking almost a whole CPU. Is there a way to stop VLC from running until I watch next time? The pause button doesn't stop VLC from encoding non-stop either.
Otherwise, great job, this is amazing stuff!!!
mcheng89 Wrote:Just pass in the direct stream url I guess...
Use this to get the url: http://localhost:8555/getStreamUrl?tuner=4
Then start the stream by doing a play api call without the redirect.
Then play the direct url.
I'll update it for you when I get home.
EDIT: v1.9.2
Added more info (episode title, episode description) to the epg api
Notes: DELETE RESOURCES/EPGDATA.DB
Since the program requires the new fields, it will crash if you try to get the epg data without forcing a update
I'm using 1.9.2, did a clean install, and have authentication set to false in the settings.conf, but when I go to the iphone.html page on my iphone, I am presented with a login page and can't get around it! Any chance you can update the iphone.html page to not show a login page if authentication is disabled? Your work continues to just be simply incredible! (now just can't wait for that ipad3 to arrive!)
shpitz461 Wrote:Is there a way to stop VLC when I'm done watching remote TV?
It doesnt shutdown in 90 seconds?
LehighBri Wrote:I'm using 1.9.2, did a clean install, and have authentication set to false in the settings.conf, but when I go to the iphone.html page on my iphone, I am presented with a login page and can't get around it! Any chance you can update the iphone.html page to not show a login page if authentication is disabled? Your work continues to just be simply incredible! (now just can't wait for that ipad3 to arrive!)
I might have broken it. I forgot to test without auth... Will fix it tonight
mcheng89 Wrote:It doesnt shutdown in 90 seconds?
Sorry, my bad! It does kill itself after a timeout. Can the timeout be controlled? or is it fixed on 90 seconds in code?
shpitz461 Wrote:Sorry, my bad! It does kill itself after a timeout. Can the timeout be controlled? or is it fixed on 90 seconds in code?
It's fixed to 90 seconds in the code.
I can reduce it though.
Since vlc handles the streaming I don't know if a client disconnects.
I run a netstat and parse the output, so setting it too low might not be good too
@Lunatixz: Have dual tuner support, but its not tested.
Finishing up my logo mapping utility
.. will be back later tonight...
mcheng89 Wrote:@Lunatixz: Have dual tuner support, but its not tested.
was it pushed to v.1.9.2?
Lunatixz Wrote:was it pushed to v.1.9.2?
Try this one: will upload one when I get home - v1.9.3
Going to upload soon... fixed iOS
finished logos mapping!
Download v1.9.4:
http://www.mediafire.com/?4c6h5fe3izinctx
Download logomapper:
http://www.mediafire.com/?e4e46c0sjpz0dbg
Requires v1.9.4 epgdata.db update
LehighBri
- Deinterlace (Does this work on iOS?)
FULL TODO: taking requests if you guys have any ideas
Todo:
- XBMC PVR - looks like a good starting place:
https://github.com/opdenkamp/xbmc/tree/m...s/pvr-demo
- hdhomerun fixes?... (pm me if you have time to test
- Airplay iOS streaming
Other Todo:
- Add adobe flash support to Web interface
- iPad Inteface
- Channels filter list
- Record TV
- Tuner pooling!
Dynamic tuner selection? Auto play on next available tuner?...
- Tuner sharing. Multiple users watching the same channel?
- minimize to Tray icon.
- Clean web interface for setup instead of settings.conf modification.
I'm having trouble running remoteCeton I get an error connecting to ceton server, but I have the settings setup for hdhomerun? I've double checked firewall, IP and path settings...
any ideas?
Lunatixz Wrote:I'm having trouble running remoteCeton I get an error connecting to ceton server, but I have the settings setup for hdhomerun? I've double checked firewall, IP and path settings...
any ideas?
sending you pm...
Delete your old settings file
Try this one: removed...
v2:
http://www.mediafire.com/?kevq9ub6s2e9kf2
Downloading XBMC pvr
http://xbmc.opdenkamp.eu/
EDIT: COMPILED demo PVR
Will continue later tonight.... or tomorrow...
v1.9.5
Fixed iOS streaming issue.... Stops if stream longer than 1000 seconds
Making good progress on XBMC PVR
(2012-03-10, 21:51)mcheng89 Wrote: [ -> ]v1.9.5
Great. What PVR-related features should we expect? And where (e.g. what will be in iOS vs. XBMC client)?
Also, I still have authentication turned off (as I just use while on my home wifi) but periodically get the login screen appearing. I'll see if I can replicate somehow.
(2012-03-12, 15:10)LehighBri Wrote: [ -> ]Great. What PVR-related features should we expect? And where (e.g. what will be in iOS vs. XBMC client)?
Live tv and epg data for now using XBMC PVR build. The purpose is to use something that's more integrated with xbmc vs the pseudotv plugin. Also, so you can get your own skins for pvr
(2012-03-12, 16:14)mcheng89 Wrote: [ -> ] (2012-03-12, 15:10)LehighBri Wrote: [ -> ]Great. What PVR-related features should we expect? And where (e.g. what will be in iOS vs. XBMC client)?
Great... and makes sense to not re-invent the wheel for sure. Yes it's more work to learn the PVR API, etc, but is the right thing in the long-term.
Also, I don't know if i missed it, but any update on the following?
-1080p iOS support (I know how to change it myself, but can you include in your master code so it gets included in the build)
-Deinterlace in iOS
-iPad interface
(2012-03-12, 16:34)LehighBri Wrote: [ -> ] (2012-03-12, 16:14)mcheng89 Wrote: [ -> ] (2012-03-12, 15:10)LehighBri Wrote: [ -> ]Great. What PVR-related features should we expect? And where (e.g. what will be in iOS vs. XBMC client)?
-Deinterlace in iOS
-iPad interface
1. Will do
2. Does it still not work?
3. I can only work on one thing at a time
