i can install this corected version of pvr.1.8.1 on Gotham 13 (alpha6) but still can`t testing if dvd player works better with ffmpeg streams or not....This Gotham 13 (alpha6) is crashing nonstop....here is a log of playing one chanell with pvr.1.8.1:
14:34:42 T:2976 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:34:42 T:2976 NOTICE: -----------------------------------------------------------------------
14:34:42 T:2976 NOTICE: Starting XBMC (13.0-ALPHA6 Git:20130731-30f4a79), Built on Aug 2 2013 (MSVC version 1600). Platform: Windows 7 SP1 32-bit, build 7601
14:34:42 T:2976 NOTICE: AMD Turion(tm)X2 Dual Core Mobile RM-70
14:34:42 T:2976 NOTICE: Desktop Resolution: 1280x800 32Bit at 60Hz
14:34:42 T:2976 NOTICE: Running with administrator rights
14:34:42 T:2976 NOTICE: Aero is disabled
14:34:42 T:2976 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
14:34:42 T:2976 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\XBMC
14:34:42 T:2976 NOTICE: special://masterprofile/ is mapped to: C:\Users\Bayern\AppData\Roaming\XBMC\userdata
14:34:42 T:2976 NOTICE: special://home/ is mapped to: C:\Users\Bayern\AppData\Roaming\XBMC\
14:34:42 T:2976 NOTICE: special://temp/ is mapped to: C:\Users\Bayern\AppData\Roaming\XBMC\cache
14:34:42 T:2976 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
14:34:42 T:2976 NOTICE: Local hostname: Bayern-PC
14:34:42 T:2976 NOTICE: Log File is located: C:\Users\Bayern\AppData\Roaming\XBMC\xbmc.log
14:34:42 T:2976 NOTICE: Found 2 Lists of Devices
14:34:42 T:2976 NOTICE: Enumerated DirectSound devices:
14:34:42 T:2976 NOTICE: Device 1
14:34:42 T:2976 NOTICE: m_deviceName : {1BBF5CAA-64BE-4340-A07C-AF8B26C6C97A}
14:34:42 T:2976 NOTICE: m_displayName : Speakers - Speakers (High Definition Audio Device)
14:34:42 T:2976 NOTICE: m_displayNameExtra: DirectSound: Speakers (High Definition Audio Device)
14:34:42 T:2976 NOTICE: m_deviceType : AE_DEVTYPE_PCM
14:34:42 T:2976 NOTICE: m_channels : FL,FR
14:34:42 T:2976 NOTICE: m_sampleRates : 44100
14:34:42 T:2976 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
14:34:42 T:2976 NOTICE: Enumerated WASAPI devices:
14:34:42 T:2976 NOTICE: m_displayNameExtra: WASAPI: Speakers (High Definition Audio Device)
14:34:42 T:2976 NOTICE: m_sampleRates : 192000,176400,96000,88200,48000,44100,32000,22050,11025
14:34:42 T:2976 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
14:34:42 T:2976 NOTICE: load settings...
14:34:42 T:2976 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
14:34:42 T:2976 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
14:34:42 T:2976 NOTICE: Default DVD Player: dvdplayer
14:34:42 T:2976 NOTICE: Default Video Player: dvdplayer
14:34:42 T:2976 NOTICE: Default Audio Player: paplayer
14:34:42 T:2976 NOTICE: Disabled debug logging due to GUI setting. Level 0.
14:34:42 T:2976 NOTICE: Log level changed to 0
14:34:42 T:2976 NOTICE: CWakeOnAccess::LoadFromXML - unable to load:C:\Users\Bayern\AppData\Roaming\XBMC\userdata\wakeonlan.xml
14:34:42 T:2976 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:34:42 T:2976 NOTICE: Loaded playercorefactory configuration
14:34:42 T:2976 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:34:42 T:2976 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:34:42 T:804 NOTICE: Thread SoftAE start, auto delete: false
14:34:42 T:2976 NOTICE: Running database version Addons15
14:34:42 T:3484 NOTICE: Thread PeripBusCEC start, auto delete: false
14:34:42 T:856 NOTICE: Thread RemoteControl start, auto delete: false
14:34:42 T:3672 NOTICE: Thread PeripBusUSB start, auto delete: false
14:34:42 T:2976 NOTICE: Found screen: Generic PnP Monitor on ATI Radeon HD 3200 Graphics , adapter 0.
14:34:42 T:2976 NOTICE: Primary mode: 1280x800 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Previous line repeats 2 times.
14:34:42 T:2976 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 720x576 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 800x480 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
14:34:42 T:804 NOTICE: Previous line repeats 2 times.
14:34:42 T:804 ERROR: CSoftAE::WriteSink - sink blocked- reinit flagged
14:34:42 T:2976 NOTICE: Additional mode: 848x480 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 1024x480 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 1024x600 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 1280x600 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
14:34:42 T:2976 NOTICE: Checking resolution 16
14:34:44 T:2976 NOTICE: Running database version Addons15
14:34:44 T:2976 NOTICE: Running database version ViewModes5
14:34:44 T:2976 NOTICE: Running database version Textures13
14:34:44 T:2976 NOTICE: Running database version MyMusic37
14:34:44 T:2976 NOTICE: Running database version MyVideos75
14:34:44 T:2976 NOTICE: Running database version TV22
14:34:44 T:2976 NOTICE: Running database version Epg7
14:34:44 T:2976 NOTICE: initializing playlistplayer
14:34:44 T:2976 NOTICE: DONE initializing playlistplayer
14:34:45 T:3652 NOTICE: Thread LanguageInvoker start, auto delete: false
14:34:45 T:2976 NOTICE: initialize done
14:34:45 T:2976 NOTICE: Running the application...
14:34:45 T:2340 NOTICE: Thread JobWorker start, auto delete: true
14:34:45 T:3652 NOTICE: -->Python Interpreter Initialized<--
14:34:45 T:2468 NOTICE: Thread JobWorker start, auto delete: true
14:34:45 T:2976 NOTICE: ES: Starting event server
14:34:45 T:2356 NOTICE: Thread EventServer start, auto delete: false
14:34:45 T:2356 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
14:34:45 T:3936 NOTICE: Thread TCPServer start, auto delete: false
14:34:45 T:2356 NOTICE: UDP: Listening on port 9777
14:34:45 T:3216 NOTICE: Thread AlarmClock start, auto delete: false
14:34:45 T:2196 NOTICE: Thread RSSReader start, auto delete: false
14:34:45 T:2340 NOTICE: EPG::CEpgContainer::Start - EPG thread started
14:34:45 T:2340 NOTICE: PVRManager - starting up
14:34:45 T:1984 NOTICE: Thread EPGUpdater start, auto delete: false
14:34:45 T:2416 NOTICE: Thread PVRManager start, auto delete: false
14:34:45 T:1680 NOTICE: Thread PVRClient start, auto delete: false
14:34:45 T:1680 NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 249 channels.
14:34:45 T:1576 NOTICE: Thread PVRGUIInfo start, auto delete: false
14:34:45 T:1984 NOTICE: AddOnLog: PVR IPTV Simple Client: EPG file path is not configured. EPG not loaded.
14:35:02 T:2976 NOTICE: Previous line repeats 248 times.
14:35:02 T:2976 NOTICE: DVDPlayer: Opening: pvr://channels/tv/All TV channels/23.pvr
14:35:02 T:2976 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
14:35:02 T:896 NOTICE: Thread DVDPlayer start, auto delete: false
14:35:02 T:896 NOTICE: Creating InputStream
14:35:04 T:896 NOTICE: Creating Demuxer
14:35:04 T:2628 NOTICE: Thread FileCache start, auto delete: false
14:35:04 T:896 NOTICE: Opening video stream: 0 source: 256
14:35:04 T:896 NOTICE: Creating video codec with codec id: 28
14:35:04 T:896 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
14:35:04 T:896 NOTICE: Creating video thread
14:35:04 T:896 NOTICE: Opening audio stream: 1 source: 256
14:35:04 T:896 NOTICE: Finding audio codec for: 86018
14:35:04 T:2480 NOTICE: Thread DVDPlayerVideo start, auto delete: false
14:35:04 T:2480 NOTICE: running thread: video_thread
14:35:04 T:896 NOTICE: Creating audio thread
14:35:04 T:964 NOTICE: Thread DVDPlayerAudio start, auto delete: false
14:35:04 T:964 NOTICE: running thread: CDVDPlayerAudio::Process()
14:35:04 T:964 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
14:35:04 T:2480 ERROR: DXVA - failed executing m_service->CreateVideoDecoder(m_input, &m_format , m_context->cfg , m_context->surface , m_context->surface_count , &m_decoder) at line 864 with error 80004005
14:35:04 T:2480 ERROR: Unhandled exception in Process : Access violation at 0x0b9caa7e: Writing location 0x00000000
14:35:05 T:804 ERROR: CSoftAE::WriteSink - sink blocked- reinit flagged
14:35:05 T:2480 ERROR: Previous line repeats 4 times.
14:35:05 T:2480 NOTICE: thread end: video_thread
14:35:12 T:964 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
14:35:15 T:1008 NOTICE: Thread LanguageInvoker start, auto delete: false
14:35:15 T:1008 NOTICE: -->Python Interpreter Initialized<--)[/color]
14:35:31 T:2628 ERROR: CCurlFile::FillBuffer - Failed: Failure when receiving data from the peer(56)
14:35:31 T:2628 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
14:35:33 T:2628 ERROR: CCurlFile::FillBuffer - Failed: Requested range was not delivered by the server(33)
14:36:02 T:2976 NOTICE: CDVDPlayer::CloseFile()
14:36:02 T:2976 NOTICE: DVDPlayer: waiting for threads to exit
14:36:02 T:896 NOTICE: CDVDPlayer::OnExit()
14:36:02 T:896 NOTICE: DVDPlayer: closing audio stream
14:36:02 T:896 NOTICE: Closing audio stream
14:36:02 T:896 NOTICE: Waiting for audio thread to exit
14:36:02 T:964 NOTICE: thread end: CDVDPlayerAudio::OnExit()
14:36:02 T:896 NOTICE: Closing audio device
14:36:02 T:896 NOTICE: Deleting audio codec
14:36:02 T:896 NOTICE: DVDPlayer: closing video stream
14:36:02 T:896 NOTICE: Closing video stream
14:36:02 T:896 NOTICE: waiting for video thread to exit
14:36:02 T:896 NOTICE: deleting video codec
14:36:02 T:896 ERROR: CDVDPlayer::OnExit - Exception thrown when trying to close down player, memory leak will follow
14:36:02 T:2976 NOTICE: DVDPlayer: finished waiting
14:36:03 T:804 ERROR: CSoftAE::WriteSink - sink bloc[/colked- reinit flagged
14:36:03 T:3192 ERROR: Previous line repeats 1 times
14:36:03 T:3192 NOTICE: Thread JobWorker start, auto delete: true
14:36:06 T:2976 NOTICE: CDVDPlayer::CloseFile()
14:36:06 T:2976 NOTICE: DVDPlayer: waiting for threads to exit
14:36:06 T:2976 NOTICE: DVDPlayer: finished waiting
14:36:09 T:804 ERROR: CSoftAE::WriteSink - sink blocked- reinit flagged
