Yomis - the forum language is English only please.
Use of services such as Google Translate is fine if required, although from the rogue font tags above I think you're maybe also which doesn't work so well on this forum.
(2022-12-06, 03:21)Yomis Wrote: [ -> ]Hola. Primero da las gracias por el gran trabajo que estás haciendo. Estoy usando Tidal2 en Kodi instalado en Windows 10. Funciona perfectamente pero cuando escucho canciones de Dolby Atmos el volumen es muy bajo. ¿No le pasa a nadie más? He probado a cambiar de dispositivo pero en todos pasa lo mismo
Hi @
Yomis
The tracks marked as "Dolby Atmos" are played as "Dolby Digital 5.1" because the "real" Dolby Atmos uses the Dolby-AC4 codec which is not playable with Kodi yet.
The sound level of this Dolby Digital streams is very low.
OK, thanks for the answer and sorry for the previous message, I did something wrong when copying the translation
Hello sir. I thin I had gapless before, but I have gaps now, on RPi4 and Tidal. Any advice pleaseM
(2022-12-11, 11:23)Adriano93 Wrote: [ -> ]Hello
Kodi is crashing after a few tracks and i dont know why.
Can someone help me? Here are the logs https://paste.kodi.tv/izanipoqum.kodi
Thank you
Hi @
Adriano93,
the inputstream.ffmpegdirect is the default player in your settings. But the log shows that you get normal http streams. Please try to deactivate the setting "Use inputstream.ffmpegdirect as default player".
see
post #673
(2022-12-12, 23:03)jaybee01 Wrote: [ -> ]Hello sir. I thin I had gapless before, but I have gaps now, on RPi4 and Tidal. Any advice pleaseM
Hi @
jaybee01 ,
On my github repository are some tips to solve gapless playback problems:
https://github.com/arnesongit/plugin.aud...2/issues/5
Also the deactivatation of the setting "Use inputstream.ffmpegdirect as default player" can solve this, because the inputstream addons are handled as video playback addons.
There is no gapless playback in video mode.
Hello there!
I’m using the addon with CoreELEC 19.5 in a Odroid N2+.
In the first time I opened it was able to see some tracks being played at 24bit but then something happened and now it plays only at 16bit.
Using Tv Dolby Atmos device type. Music quality is set to MQA.
What might have changed?
(2022-12-17, 14:48)encryptedbr Wrote: [ -> ]Hello there!
Hi @
encryptedbr,
not all MQA songs are payed with 24bit. Some are 16bit and some 24bit. It can also depend on the selected device type.
A good way to check the bit depth of a stream is to enable the setting "Use inputstream.ffmpegdirect as default player" and check the kod log file.
The inputstream.ffmpegdirect addon logs the codec details like this:
Example for 24bit:
AddOnLog: inputstream.ffmpegdirect: ffmpeg[AB8D011]: Duration: 00:03:14.21, start: 0.000000, bitrate: 1658 kb/s
AddOnLog: inputstream.ffmpegdirect: ffmpeg[AB8D011]: Stream #0:0: Audio: flac, 48000 Hz, stereo, s32 (24 bit)
Example for 16bit:
AddOnLog: inputstream.ffmpegdirect: ffmpeg[AB8D011]: Duration: 00:03:20.00, start: 0.000000, bitrate: 0 kb/s
AddOnLog: inputstream.ffmpegdirect: ffmpeg[AB8D011]: Stream #0:0: Audio: flac (fLaC / 0x43614C66), 44100 Hz, stereo, s16, 550 kb/s (default)
Hi @
arneson, thanks for your support.
I has able to play 24 bit streams by disabling passthrough.
But there's another problem happening with more than 50% of the tracks I try to play.
They simply won't play and fail with the message to verify the log to more information.
In the log I can see the following when trying to play these tracks:
xml:
2022-12-18 12:04:19.221 T:3611 INFO <general>: VideoPlayer::OpenFile: plugin://plugin.audio.tidal2/play_track/12070154/12070149
2022-12-18 12:04:19.222 T:4818 INFO <general>: Creating InputStream
2022-12-18 12:04:19.224 T:4818 INFO <general>: AddOnLog: inputstream.ffmpegdirect: inputstream.ffmpegdirect: OpenStream() - Num Props: 2
2022-12-18 12:04:19.224 T:4818 INFO <general>: AddOnLog: inputstream.ffmpegdirect: inputstream.ffmpegdirect property: inputstream.ffmpegdirect.manifest_type = hls
2022-12-18 12:04:19.224 T:4818 INFO <general>: AddOnLog: inputstream.ffmpegdirect: inputstream.ffmpegdirect property: inputstream.ffmpegdirect.open_mode = ffmpeg
2022-12-18 12:04:19.224 T:4818 INFO <general>: AddOnLog: inputstream.ffmpegdirect: Stream mimetype: application/vnd.apple.mpegurl
2022-12-18 12:04:19.228 T:4818 INFO <general>: AddOnLog: inputstream.ffmpegdirect: OpenWithFFmpeg - IO handled by FFmpeg's AVFormat
2022-12-18 12:04:19.441 T:4813 INFO <general>: Python interpreter stopped
2022-12-18 12:04:24.641 T:4818 ERROR <general>: CVideoPlayer::OpenInputStream - error opening [plugin://plugin.audio.tidal2/play_track/12070154/12070149]
2022-12-18 12:04:24.641 T:4818 INFO <general>: CVideoPlayer::OnExit()
2022-12-18 12:04:24.641 T:4818 INFO <general>: ADDON: Dll Destroyed - Inputstream FFmpeg Direct
2022-12-18 12:04:24.657 T:3611 INFO <general>: CVideoPlayer::CloseFile()
2022-12-18 12:04:24.660 T:3611 INFO <general>: VideoPlayer: waiting for threads to exit
2022-12-18 12:04:24.660 T:3611 INFO <general>: VideoPlayer: finished waiting
Still couldn't solve it.
verbose log
xml:
2022-12-18 12:17:41.432 T:6388 INFO <general>: initializing python engine.
2022-12-18 12:17:42.279 T:6388 INFO <general>: [TIDAL2] GET https://api.tidal.com/v1/tracks/12070154...7ea734ff5f
2022-12-18 12:17:42.280 T:6388 INFO <general>: [TIDAL2] Got stream with soundQuality:LOSSLESS, codec:FLAC
2022-12-18 12:17:42.295 T:6388 INFO <general>: [TIDAL2] Got Dash stream with MimeType: audio/x-flac
2022-12-18 12:17:42.328 T:6388 INFO <general>: [TIDAL2] Using inputstream.ffmpegdirect for HLS playback
2022-12-18 12:17:42.345 T:6388 INFO <general>: [TIDAL2] Playing: http://localhost:5555/manifest.m3u8?data...BEPg%3D%3D with MimeType: audio/x-flac
2022-12-18 12:17:42.349 T:6388 INFO <general>: CPythonInvoker(11, /storage/.kodi/addons/plugin.audio.tidal2/addon.py): script successfully run
2022-12-18 12:17:42.549 T:5937 INFO <general>: ADDON: Dll Destroyed - Spectrum
2022-12-18 12:17:42.558 T:5937 INFO <general>: VideoPlayer::OpenFile: plugin://plugin.audio.tidal2/play_track/12070154/12070149
2022-12-18 12:17:42.561 T:6393 INFO <general>: Creating InputStream
2022-12-18 12:17:42.562 T:6393 INFO <general>: AddOnLog: inputstream.ffmpegdirect: inputstream.ffmpegdirect: OpenStream() - Num Props: 2
2022-12-18 12:17:42.562 T:6393 INFO <general>: AddOnLog: inputstream.ffmpegdirect: inputstream.ffmpegdirect property: inputstream.ffmpegdirect.manifest_type = hls
2022-12-18 12:17:42.562 T:6393 INFO <general>: AddOnLog: inputstream.ffmpegdirect: inputstream.ffmpegdirect property: inputstream.ffmpegdirect.open_mode = ffmpeg
2022-12-18 12:17:42.562 T:6393 INFO <general>: AddOnLog: inputstream.ffmpegdirect: Stream mimetype: application/vnd.apple.mpegurl
2022-12-18 12:17:42.563 T:6393 INFO <general>: AddOnLog: inputstream.ffmpegdirect: OpenWithFFmpeg - IO handled by FFmpeg's AVFormat
2022-12-18 12:17:42.574 T:6388 INFO <general>: Python interpreter stopped
2022-12-18 12:17:47.750 T:6393 ERROR <general>: CVideoPlayer::OpenInputStream - error opening [plugin://plugin.audio.tidal2/play_track/12070154/12070149]
2022-12-18 12:17:47.750 T:6393 INFO <general>: CVideoPlayer::OnExit()
2022-12-18 12:17:47.750 T:6393 INFO <general>: ADDON: Dll Destroyed - Inputstream FFmpeg Direct
2022-12-18 12:17:47.762 T:5937 INFO <general>: CVideoPlayer::CloseFile()
2022-12-18 12:17:47.765 T:5937 INFO <general>: VideoPlayer: waiting for threads to exit
2022-12-18 12:17:47.765 T:5937 INFO <general>: VideoPlayer: finished waiting
encryptedbr please stop posting logs directly into the thread.
Did you not see the big red text above the "post reply" that states "Do not post logs in the forum. Use
https://paste.kodi.tv/ instead." ?
Many thanks.
Sorry, haven't seen.
Will stop and use paste.kodi from now on
arneson had to change the decive type to automotive dolby atmos and now everything is working.
Hello everyone,
I'm new here and in my search for the best way to use Tidal, after a lot of trying and reading I ended up on this forum.
Now I have installed Tidal on Coreelec - Matrix 19.5 as described here and it works so far - even with Premium plus registration.
My problem is, that on my IFI Zen DAC V2 all songs that arrived under Android Tidal App as Original Sample Rate (purple) or USB Audio Player Pro (MQA Studio - blue) now arrive as PCM 44.1/48kHz (yellow). As I write this, one song was recognized as MQA (green) and another (not MQA) could not be played - but others that weren't MQA's were. I think I'm on the right track, but the finer points are still missing. Hope there is a solution and someone to show me the way.
I'm really excited about the support here
