Hey guys nice thread and some very helpful info.
Will the fritschfiretv build on the first post work for me if i am not using 7.1 audio? to fix the audio delay in kodi.
I just have the firestick connected to tv and use tv speakers for audio.
(2020-04-06, 19:03)fritsch Wrote: [ -> ] (2020-04-06, 15:58)Avds Wrote: [ -> ]Hey guys nice thread and some very helpful info.
Yes.
Brilliant I will try it in a bit. Thanks for all your hard work.
(2020-04-06, 19:40)jubilex Wrote: [ -> ] (2020-04-06, 17:08)peak3d Wrote: [ -> ]@jubilex can you pls. check this version: http://mirrors.kodi.tv/test-builds/andro...bi-v7a.apk ?
If this still works, we can merge the PR for kodi 18.7
Yes, I should be able to do this tonight. Do you need a log or just checking various files and reporting back?
Just looking if it works is fine, the backport was not that easy and could be not working.
(2020-04-06, 21:55)peak3d Wrote: [ -> ] (2020-04-06, 19:40)jubilex Wrote: [ -> ] (2020-04-06, 17:08)peak3d Wrote: [ -> ]@jubilex can you pls. check this version: http://mirrors.kodi.tv/test-builds/andro...bi-v7a.apk ?
All files I tried with this version displayed correctly -- 4:3, 16:9, 2.40:1, mkv, mov, Avi, mp4. Was I only checking for correct aspect ratios? I noticed no issues at all but I only spent a few moments on each video.
is there a method to read ntfs formatted hard drives and watch hd movies (without root)?
(2020-04-07, 13:14)peak3d Wrote: [ -> ] (2020-04-07, 12:45)jubilex Wrote: [ -> ] (2020-04-06, 21:55)peak3d Wrote: [ -> ]Just looking if it works is fine, the backport was not that easy and could be not working.
Thx much!
I picked this official backport up and rebased on top.
Tried h264, mpeg2, h265 8 bit, h265 10 bit including yellifish and HDR. Everything works fine with Mediacodec Surface. Therefore: It's your personal issue for now. As you did not bother posting your
Debug Log, it might stay that way :-)
So just to make sure I understand, the aspect ratio fix is now in the main Kodi, but the audio delay fix will always only be in your Fire TV builds?
Audio-Delay fix is in Matrix (upcoming v19) and ported in my fritschfiretv version.
Aspect-Ratio is in Leia (will be in 18.7 and in Matrix)
Audio-Delay won't be in official Leia, because it breaks workarounds for non-standard firmware that we still support in Leia. Concrete example: if you install fritschfiretv build on an older AMLogic device, passthrough would be broken.
Ok, thanks! So I'll stick with your fire TV builds until I'm ready for Matrix.
Thanks for all your work.
