(2023-10-31, 12:10)satdx62 Wrote: [ -> ] (2023-10-31, 11:56)nayef Wrote: [ -> ] (2023-10-31, 09:22)satdx62 Wrote: [ -> ]Oh, then you need to upload your kodi.log to
https://paste.kodi.tv/ so I can take a look.
https://paste.kodi.tv/jugujixuxe.kodi
https://paste.kodi.tv/luvojidiqa.kodi
i think "inputstream.adaptive" is v3.2.0
and pvr.dvbviewer need v3.3.0
Yes that's right. The problem is that with this build "before-rebase - org.xbmc.kodi_20.90.101_arm - 20230617000 acb-rebasedD", the sources are no longer updated, and are out of date.
Unzip the file kodi.binary.instance.inputstream.zip and replace in /media/developer/apps/usr/palm/applications/org.xbmc.kodi/addons/
kodi.binary.inputstream
this way not fix issue
i have error when try install pvr.dvbviewer: "invalid instruction"
can try old v from pvr.dvbviewer for v3.2.0 ?
(2023-10-31, 13:59)nayef Wrote: [ -> ] (2023-10-31, 12:10)satdx62 Wrote: [ -> ] (2023-10-31, 11:56)nayef Wrote: [ -> ]https://paste.kodi.tv/jugujixuxe.kodi
I did that, but it still asks for kodi.binary.inputstream v3.3.0. I wonder about that too. So I provided them kodi.binary.inputstream v3.3.0 from newer build. I have replaced the folders on my TV and pvr.dvbviewer was installed.
(2023-10-30, 17:29)wsnipex Wrote: [ -> ]yes and yes
Sadly kodi cant be installed via homebrewchannel.
i get an error that the certificate has expired.
My tv is rooted
(2023-10-31, 15:19)satdx62 Wrote: [ -> ] (2023-10-31, 15:16)Pienoet Wrote: [ -> ] (2023-10-30, 17:29)wsnipex Wrote: [ -> ]yes and yes
My tv is rooted
Here could be the solution: https://github.com/webosbrew/apps-repo/issues/91
thnx i installed it via homebrewchannel on the WEBos devmanager app on my pc.
That worked also
With Beta 1 the auido/video is out of sync.
I have no option to enable AC3 transcoding where is it?
It's only available when passthrough audio is enabled. That said, I don't think passthrough works at all right now on 4.x
(2023-10-31, 18:10)sundermann Wrote: [ -> ]It's only available when passthrough audio is enabled. That said, I don't think passthrough works at all right now on 4.x
Thats the point its enabled in kodi.
Its weird that the setting isnt there when passtrough is enabled.
BTW Whitelist isnt working also the list only show 1920x1080p 0.00hz.
So live tv is 60hz wich is juddery
(2023-10-31, 18:33)Pienoet Wrote: [ -> ] (2023-10-31, 18:10)sundermann Wrote: [ -> ]It's only available when passthrough audio is enabled. That said, I don't think passthrough works at all right now on 4.x
Try setting channels to 2.0 and see if it shows up for you then.
Why is so difficult obtain a version of Kodi for LG able to avoid audio out of sync by default? This is an issue present from the beginning and never solved
(2023-10-31, 15:01)satdx62 Wrote: [ -> ] (2023-10-31, 13:59)nayef Wrote: [ -> ] (2023-10-31, 12:10)satdx62 Wrote: [ -> ]Yes that's right. The problem is that with this build "before-rebase - org.xbmc.kodi_20.90.101_arm - 20230617000 acb-rebasedD", the sources are no longer updated, and are out of date.
OK Now
i remove kodi & clean install again
then install:
1-kodi.binary.instance.inputstream
2-install pvr.dvbviewer = OK!
3-install inputstream.adaptive after change 3.2.0 to 3.3.0 in addon.xml
4-install pvr.hts after change 3.2.0 to 3.3.0 in addon.xml
Now all working
Thanks for help
i hope don't stop developer for webOS 3.x
(2023-10-31, 19:12)SoulReaver Wrote: [ -> ] (2023-10-31, 18:33)Pienoet Wrote: [ -> ] (2023-10-31, 18:10)sundermann Wrote: [ -> ]It's only available when passthrough audio is enabled. That said, I don't think passthrough works at all right now on 4.x
Yes that does the trick but sadly still audio out of sync
Are there any builds wich has a fix fotr this?
And is the whitelist gonna be fixed in next beta?
(2023-10-31, 20:28)Pienoet Wrote: [ -> ] (2023-10-31, 19:12)SoulReaver Wrote: [ -> ] (2023-10-31, 18:33)Pienoet Wrote: [ -> ]Its weird that the setting isnt there when passtrough is enabled.
i set "ALSA: Default" and "7.1" and don't have issue sync
https://streamable.com/yiy8xn
