In my case it was an issue with the smb cache.
After changing the smb chunk size setting from 256 to 64 in the latest nightly, Dolby Vision played fine.(Profile 7 failed to play)
However, HDR doesn't play on the latest nightly and it immediately hangs when I try to play it.
requa3r0 Just remap the scroll button
kimpg89 Weird stuff. We'd still need a debug log with video component logging turned on though
Here is the dovi profile7 playback failure log
erowelugat.kodi (paste)
(dolby vision compatibility mode on)
jovinelexa.kodi (paste)
(dolby vision compatibility mode off)
sundermann
Seems to be a debug log kinda day
here's one - DV 5 profile, settings are DV off so it should pass through the HDR10 base layer, but instead it does not send the HDR trigger/TV does not go into HDR mode so the picture is green and purple.
https://paste.kodi.tv/pawituzaqi.kodi
UPDATE - Ignore the above...was having a blonde moment.
(2024-04-04, 10:59)oldpainless Wrote: [ -> ]@sundermann
DV Profile 5 doesn't have a fallback layer. It will either play correctly as DV or with the purple/green tint you observed.
Ah, forgot about that...good catch. (will edit post). Either way, DV does not work for me.
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Hey guys this is my first time posting so please ignore any mistakes.
So the thing is I have installed kodi on LG tv using the guide after installing when opening for the first time there are many popups showing to add add-ons should I install all and one more thing there are add-ons which are giving error after clicking yes to the popups so please I would appreciate every help anyone could give me
Ignore my English
Is it just me or is basically all media slightly out of sync with Kodi? It just feels off somehow. I tried the latest nightly and the sync just doesn't feel right.
(2024-04-05, 15:33)manas Wrote: [ -> ]Hey guys this is my first time posting so please ignore any mistakes.
Ignore my English
Kodi is asking if you want to enable some addons, that are included. It's asking you only on first start, to make you aware of their existence. If you don't know what an addon is for you can safely just say "no".
The error popups might show, because you enabled addons that you don't use and haven't configured. You can disable them in the addon settings -> my addons.
Last build nightly no dolby vision, i Guess its not bad hdr10 fallback on mkvs.
Continue your great work, maybe os the chipset off the TV .
