Mine looks like that aswell on the xbox, but im running in HD
Just checked it in SD (480i) & the image thats behind the home menu doesnt reach all the way to the RHS of the screen & the pop up menu when you push up is just slighty visible all the time.
kautious Wrote:So Im the only one with a home screen not looking like this Funny
SlaveUnit what is the build number you are using? I have build 21559
I am running SVN21589. But I update almost every day so the version hasnt been an issue. I dont run this on my xbox. I havent updated that one in about 2 years since it is barely used. I run this on winxp and it looks fine on it.
I was just thinking if it's possible to made the plot's text size configurable from the skin settings (actualy i've tried to implement it myself but without much success, since i can't get the hang of how to implement something that is similar to a combobox).
The idea is simple:
use conditional includes to change the font size for plot and configure the condition within skin settings.
Something like normal, big, huge for font size would be perfect, i think.
Also, just to be clear, If you could point me or just explain how to obtain a combobox (or something like that) i will implement it myself,i'm not asking you to do job
The wiki has a lot of information for controls, but without some pics to show the basic appearence of them, it's dificult to choose wich one to use.
ZIOLele
BlastActionHero.
From looking at your screenshot, I would imagine that you are not running 720, or 1080 and if I was to be so bold, may not even be running a widescreen?
If this is the case then I would guess a resolution specific home page is required for you. Let us know what the resolution is and then maybe just maybe someone may be able to help.? kautious? You appear to be running widescreen what resolution are you running?
kautious Wrote:720p on the xbox
Had this problem myself, i fixed it by going into the screen configuration and adjust the big square box in the middle. I did this and mine is perfect now i am also running xbox in 720p
Graves Wrote:Had this problem myself, i fixed it by going into the screen configuration and adjust the big square box in the middle. I did this and mine is perfect now i am also running xbox in 720p
Cool
I'll Try that out!! Thanks for the tip Graves
Hot diggity dog!!
That did it
Changed the box a little smaller and
Presto Change-O Home screen fully functional!!!
Thanks Graves for the tip!!
Very nice mod pack
kautious Wrote:Hot diggity dog!! That did it Changed the box a little smaller and
Very nice mod pack
Glad you got it fixed Kautious, I was afraid I was gonna have to drive down there and fix it (I'm in Riverside
New update posted on the first post. It should fix any issues that existed before plus allow for some major customization of the menus.
Let me know if there are any issues or requests.
Your home window options screen is a little funky. When you push down it gets locked into 3 settings. Just go to HOME WINDOW OPTIONS and start going down on the list and you'll see. (Sorry that sounded nasty).
SlaveUnit Wrote:Your home window options screen is a little funky. When you push down it gets locked into 3 settings. Just go to HOME WINDOW OPTIONS and start going down on the list and you'll see. (Sorry that sounded nasty).
Damn man I thought I had tested everything and you go and find a bug
....it's fixed now. Just go ahead and d/l the pack again from the first post.
Aenima99x Wrote:Glad you got it fixed Kautious, I was afraid I was gonna have to drive down there and fix it (I'm in Riverside )
Thanks for the Update Aenima99x
Not a far drive, I'm in North Park
I'm about 3mins from the Zoo
Heya kautious Im in Mira Mesa and my GF works at the zoo. Small world.
Hell I work on Coronado. Still not too far
AND...I was actually in North Park all day a buddies house on 32nd street. Ok I will stop now.
