Hey Hitcher. Mod looks great. Still thinking of making the "Curtain" option separate for movies/tvshows? In my opinion the theater curtain makes sense for movies, ie in a movie theater, but for TvShows, it just seems odd.
Rand
Hitcher, Auto Info panel doesn't work, if I set it to Auto nothing happens.
Hitcher, in TV section, "mark as watched" doesn't work.
If you set mark as watched either on Show, or Season level, nothing happens, if you do it on episode level it sets the flag correctly.
nekrosoft13 Wrote:Hitcher, Auto Info panel doesn't work, if I set it to Auto nothing happens.
Still not tracked that problem down.
nekrosoft13 Wrote:Hitcher, in TV section, "mark as watched" doesn't work.
Works fine for me, anyone else get this?
RodrigoG Wrote:No
Maybe.
are you using the latest XBMC? 21701, maybe something got broken again?
Pr.Sinister Wrote:Hitcher,
Not sure if you are planning on adding this or not but i think it may be nice if
you added your Home Video ON/OFF mod from this page :
http://www.xbmc.org/forum/showthread.php?p=331050
No rush of course but like i said, i love being able to just download your mod
and only have to dump in my DialogFullSceenInfo.xml and DialogSeekBar.xml
-Pr.
Just tried adding that but it didn't work and I found that the Visualiser doesn't even show on the home screen.
is there anyway you can add this mod to your views.
click here
rflores2323 Wrote:is there anyway you can add this mod to your views.click here
I personally don't like it but if someone wants to code it as a new viewtype (id 553+) then I'll integrate it.
it's a real memory hog is that mod even on a pc not too keen myself on that one.
Hitcher Wrote:Works fine for me, anyone else get this?
Yeah i too am getting this. I select a season and set it to mark as watched and
it doesn't do it. I am in Low List mode.
-Pr.
Just checked in Low List and it's still working. Are you both running the latest SVN?
Fixed - God I hate booleen conditions.
mindweaver Wrote:I have a request. I don't know if it is possible.
When running the multiplex view you can choose the following settings for the infopanel "auto, trigger, on, off". But if you set it on "ON" for TV-series you have to have it set to ON for movies aswell.
I would like to have it ON for tv-shows and AUTO for movies. Is it possible make this option non global.
This is also fixed now - I had a stray letter in the one visible condition that was stopping the separate layouts for TV and Movies.
