2009-08-26, 23:29
Hitcher Wrote:Any images you use need to be named - <genrename>.bmp
Make sure it's not inside another folder (ie skins/Aeon/Aeon/)
Checked and its not :/
abiogenesis Wrote:What should i do?Get the latest update.
Hitcher Wrote:[b][align=center]Old Multiplex as another viewtype
rausch101 Wrote:Sweeeeeet...is this view compatible with anoobie's original video/trailer mod 3?No idea.
Hitcher Wrote:Get the latest update.
Mojolive Wrote:Hi Oki, I really need some help Please. I just can't figure this out..
I am running windows 7 ( newestbeta) XBMC Build #22427 newest as of August 27. I am also running the new Hitcher Skin 2009-08-26.. github...
Everytime install this Hitcher Skin. xbmc will just hang.. then sometimes it will play the movies with out hanging (when it is hanging) it will just not do anything.. have to Control , Alt , Delete. quit xbmc.. and restart.. sometimes it will not even play the movies.. I am so frustrated with this.. I have 2 computers running windows 7 . ALWAYS THE SAME PROBLEM.. it is something with Hitchers skin.. because the normal Aeon skin does not crash . the PM3 skin does not crash.. I just can not get this to work.. can anyone tell me if they have heard of this. ( i do not know if it is hitchers skin.. I mean i am even sure it could be.. ) but then I copy the hitcher folder and add the fonts to the skin folder on xbmc.. and then select it in the apperance menu.. it always crashes XBMC or hangs.. ALWAYS.. I do not know what it could be.. but it is so bad. that it is unusable .. can anyone help me with this please. please. thanks in advance.. sorry if this is the wrong place to post this.
Every time install this Hitcher Skin. xbmc will just hang.. then sometimes it will play the movies with out hanging (when it is hanging) it will just not do anything.. have to Control , Alt , Delete. quit xbmc.. and restart.. sometimes it will not even play the movies.. I am so frustrated with this.. I have 2 computers running windows 7 . ALWAYS THE SAME PROBLEM.. it is something with Hitchers skin.. because the normal Aeon skin does not crash . the PM3 skin does not crash.. I just can not get this to work.. can anyone tell me if they have heard of this. ( i do not know if it is hitchers skin.. I mean i am even sure it could be.. ) but then I copy the hitcher folder and add the fonts to the skin folder on xbmc.. and then select it in the appearance menu.. it always crashes XBMC or hangs.. ALWAYS.. I do not know what it could be.. but it is so bad. that it is unusable .. can anyone help me with this please. please. thanks in advance.. sorry if this is the wrong place to post this.
Mojolive Wrote:Hi Oki, I really need some help Please. I just can't figure this out..post a full debug log
