(2012-05-07, 10:07)pakee Wrote: [ -> ]Actually if you use the latest version of Livestreams, you don't have to make the above change to launch a veetle channel from livestreams.
Not sure how to play streams without ids though
So Livestream version 1.06 does not need your code change?
(2012-05-07, 19:01)pakee Wrote: [ -> ]1.04, I think (http://forum.xbmc.org/showthread.php?tid...pid1095413)
Yes that line is not needed anymore (although I think it works even if its there)
Thank you Pakee.
I still cannot get veetle to work even with version 1.04
it works great with jtv and utube
Sorry I should have tried it before posting...you are right: to invoke veetle stream from other plugin you will need to add that line of code
jtv and youtube work fine though
If your listitem has isfolder set to false and isplayable set to true, those lines will not be required.
Thanks for the info. We were trying to open a veetle stream from a livestreams plugins xml file
(2012-01-05, 02:02)newatv2user Wrote: [ -> ]Since there are so many channels now, I tweaked the addon to show categories. If anyone's interested:
http://www.mediafire.com/?ymu7b696eg8csk4
Please merge this to the repository so it updates by itself
thanx
Actually there's a merge request from around 5 months back which pretty much does the same thing. But t0mm0 is MIA. So no merging and no automatic updates unless we create a new repo.
guys, can we get a epg for this?
(2012-07-30, 01:20)erhan75 Wrote: [ -> ]guys, can we get a epg for this?
Here's one that I use... obviously not integrated wit XBMC, but good for looking at what streams are playing:
http://veetleguide.appspot.com/
MMx
thanks, i was hoping we can get a update with a epg for this? I love this add on
Does anyoe know he to disable the adult link or put a password for that link?
An EPG for this would be amazing. Thanks for the veetleguide link, it helps. Is this possible to integrate?
erhan75- I don't think there is a way to disable a single link in xbmc, maybe you could block the website on your pc/router.
(2012-07-31, 02:46)spyder Wrote: [ -> ]An EPG for this would be amazing. Thanks for the veetleguide link, it helps. Is this possible to integrate?
It's called the after hours R channel, i was going though it last night and didnt read it, click on it and all I saw was agghhh agghhhhhhhhhh
lol, luckily i was alone.
has anything changed on veetle? can't seem to get any channels to load up today in xbmc.
