Full Version: [MOD] Aeon Hitched - Signing out
I'm finished with this mod now for a number of reasons (mainly because it's gone on far too long and taken up too much of my free time - time which I really wanted to use making my own skin) but anyone is welcome to carry on if they so wish.
Instead I'll be working on Alaska.
PLEASE NOTE: Latest SVN version of XBMC needed (found here) and you'll also need the latest fonts (extract to your Aeon folder).
New - Script to Download, Install and Update Git-hosted Aeon Showmix/Auriga/Hitched
GitHub Link - Aeon Hitched
MediaFire Download here (not as up to date as GitHub)
After you've got all the files you'll only need to download the aeon.rar to get any future updates unless otherwise stated.
NOTE 1: For the Weather forecasts you'll need install and enable (under Weather options) the Weather.com Plus Plugin which you can download using the SVN Repo Installer
NOTE 2: The 'cheat method' for media flagging (info stored in the Studio tag) is no longer used because XBMC now officially supports native media flagging.
You need to enable 'Extract Media Metadata Information' or use a Media Manager to create NFOs with the data.
NOTE 3: To use Conditional Weather Backdrops you must select the weather backdrop folder under Customisation.
NOTE 4: See here for the TV Show/Season Landscape (16x9) images
Credits and thanks - BlackTextures - 'Black / PitchBlackTextures - DuMbGuM / ReptileAeonTexures - The-Boxhead / Leeuw - Low List / Clearlist & Vertical Menu - eumel
2009-08-28 - ALL FILES NEEDED FOR THIS UPDATE
Fixed: Flagshade for Episodes.
Changed: Hide Left & Right arrows in Multiplex when not needed.
Changed: Default focus for OSD to Play/Pause.
Resized: Curtain backdrop.
Updated: Genre folders.
Added: Subtitle OSD and Play/Pause icons.
2009-08-27 - ALL FILES NEEDED FOR THIS UPDATE
Changed: Removed lines from behind Plot.
Changed: Backdrops no longer load behind Curtains.
2009-08-26
Fixed: Curtain On problem
Fixed: Thin Showcase panel.
Added: Old Multiplex with Trailer views.
Cleanup.
Changed: Separate backdrop controls for Movies, TV Shows and Music
2009-08-25
Updated: Lowlist.
2009-08-24
Updated: Aspect ratio icons.
Missed: Seek bar mod.
Fixed: DialogSelect.xml
Fix.
Added: Seek Bar mod.
2009-08-22
Fixed: Flickering thumbs in Showcase.
Changed: Number of Preloaded Items.
2009-08-21
Fixed: Multiplex Thumb layout.
Updated: Lowlist.
Fixed: Home alignment problem.
Updated: Lowlist.
Fixed: Info navigation.
Fixed: default genre image appearing over proper image.
Fixed: Showcase Info Panel.
Code clean up.
2009-08-18
Cleanup.
Readded. New and improved Showcase Info Panel.
Updated. Low List.
Fixed. Hide vignette.
Fixed. Larger Time panel not hiding fully.
2009-08-17
Fix.
Fix.
Reverted.
Fix.
2009-08-16
Fixed: Hide Music Library update.
Fixed: Various problems.
Cleanup.
Added: Info Panel to Showcase.
Added: Cast mod.
Changed: Updated Low List.
Fixed: Vertical Menu On/Off.
Changed: Animated Background images.
Added: Vertical Menu, thanks to eumel.
2009-08-15
Fixed: Case sensitive includes.
Fixed: Separate TV and Movies watched overlays On/Off.
Changed: Off default.
2009-08-14
Added: Animated Backgrounds.
Changed: Optional Scroll Letters.
2009-08-13
Updated: 'Latest Added' now has shadow.
'Now Playing' slides when lower Widgets are used.
'Totals' scroll for big collections.
'Weather' shadow added.
Updated latest added script.
Fixed: Forgot to include Slim List for Playlist.
2009-08-12
Fixed: Video window position in Multiplex.
Changed: Repositioned when RSS is OFF.
Added: Music Genre images and fallback.
Cleanup.
Changed: Animation speeds.
2009-08-11
Added: 'Latest Added' Totals.
Added: Lower Latest Added Widgets.
2009-08-10
Added: Music Multiplex thanks to cf2009.
Added: TV Genre Posters.
Removed: Fallback button.
Removed: Letter scroll fade delay.
Removed: Fanart reset for Curtains.
Added: Genre Posters and Fanart for List and Showcase views.
Added: Mouse support
2009-08-09
Added: Highlighted Letter when fast scrolling - thanks andyblac.
Updated: Recently Added python script.
Fixed: Include name error.
Removed: Invalid XML.
2009-08-07
Updated: Weather Forecast now includes '7 day' and 'Alerts'.
2009-08-06
Changed: Multiplex layout.
2009-08-05
Added: MediaStream sound effects.
Added: Clear List, thanks to eumel.
2009-08-04
Changed: aac.png
Changed: Removed Square/Poster from the Video List modes and now display
in correct aspect ratio.
Added: media logos.
2009-08-03
Fixed: Poster not displaying.
Changed: Slighty reduced Ratio images in size.
Added: Use 'Ratio' instead of 'Studio'.
Fixed: List Scrollbar (again).
Fixed: Fast scrolling of custom backdrops when changing Weather location.
Removed: Found elsewhere.
Fixed: Full List Max - Title and Plot alignment when Writer and/or
Director fields were empty.
2009-08-02
Added: Floor Night/Light button to Music Nav.
Added: poster.jpg support for FullScreenInfo plus Australian and German
certificates.
Added: Wall view arrows.
Added: Home Visuals (Video and Visualiser).
Fixed: Scrollbar for Slim List.
Added: New or Old Wall type view.
Changed: 'Skin Name' and 'By' to help indentify from standard Aeon.
Added: Optional Ratings for Slim List - default Year.
Fixed: Label lengths in Multiplex Poster view.
2009-08-01
Fixed: Missing overlay code.
Fixed: Multiplex Info toggle button.
Fixed: Fanart/Thumb layout button for TV Episodes.
Fixed: Episode Title overlap problem, thanks to jalesm.
Fixed: Slim List scrollbar.
Added: Playlist stuff.
2009-07-31
Added: Scrollbar to List Views.
Fixed: Floor Button problem.
2009-07-30
Fixed: Use Text for ratings.
Added: Optional 'Horizontal' or 'Vertical' scrolling for Wall view.
Fixed: Wall view background.
2009-07-29
Updated: Weather Submenu - 4 Day, 36 Hour, Weekend and Animate buttons.
Fixed: Wall background (again).
Fixed: Background problem.
Removed: Unused texture.
Added: CD/DVD Cover to Slim List.
Removed: Unused code.
Fixed: Library clean progress bar, thanks to ronie.
2009-07-28
Added: thrasherx's Wall mod.
2009-07-27
Fixed: Missing text and alignment problem in Yes/No dialog.
Changed: Scan fill position.
Fixed: Down for Submenu not working with 'Latest Added' disabled, thanks
to jalesm.
Fixed: Movie and TV watched overlays for Wall view.
Added: Curtains to Showcase.
Removed: Submenu checks.
Removed: TV check.
2009-07-26
Added: Video Files Fanart.
Added: Shutdown Submenu.
Changed: MPAA rating check, thanks to jalesm for pointing it out.
Added: Sub Menu items.
Fixed: Wall background.
Changed: Repositioned 'Latest Added' movie poster.
More code cleaning.
Removed: Main menu position change from Home.
2009-07-25
Fixed: More Watched Overlays.
Fixed: Latest Added Music - last title's thumb size was set as an Episode.
Changed: XML code checked for errors and layout cleaned up.
Fixed: OSD settings menu.
Fixed: Audio Setting bug.
Changed: Hide button.
Fixed: More overlay issues.
Changed: Trailer font, position and background.
Fixed: Watched Overlays.
2009-07-24
Updated: Almost completely added 'Black's mod.
2009-07-23
Added: CD/DVD Covers, thanks to 'Black.
Changed: Lengthened window for number of episodes to stop scrolling.
Removed: List Line (textures with small dimensions don't convert to
texture.xpr).
Changed: List line lightened and removed from texture.xpr and Select Bar
alignment.
Removed: Unlock all views for TV.
Added: Alternative TV layouts for List Full.
Fixed: Glass overlay.
Fixed: Line in dark themes - hopefully for the last time.
Removed: cf2009's Mod Pack.
2009-07-22
texture.xpr).
alignment.
2009-07-22
Fixed: OSD progress bar.
Added: Integrated cf2009's Mod pack.
Fixed: OSD wrap Up and Down controls.
Removed: Unneeded buttons in Low List view.
Fixed: List views separater line not showing when converted to texure.xpr.
2009-07-21
Updated: The-Boxhead's Reptile Theme.
Added: 'Now Playing' item coloured.
Changed: Rolled back some testing.
Added: Textures re-added.
Added: Fixed Fonts for foreign language uppercase problems, thanks to
mindweaver.
Fixed: Text colours for darker themes.
Fixed: Info panel.
2009-07-20
Themes texture support added
Night/Light Theme changed to Night/Light Floor
Localisation and a few problems fixed.
2009-07-16
Added: Dark Aeon
Fixed: Auto Info for Multiplex view.
2009-07-15
Hitcher merged branch 'auriga' of git://github.com/djh/aeon.git
Updates from djh: fixed: glass transparency for Multiplex Movies
Updates from djh: fixed: Music List icon edge
Cleaned up.
Changed: Preloaditems added for 'background' loading.
Added: Party Mode to Music.
Added: Larger tablet for TV Posters in Multiplex.
Changed: Localised 'CURRENT TIME' & 'FINISH TIME'.
Updated: Swedish strings thanks to mindweaver.
Updated: Spanish strings thanks to issun00
Fixed: Dialog popup visiblity.
Added: OSD Sliders controls.
Added: Poster layout for Old Multiplex view.
Removed: Old Includes_MediaFlags.xml.
Fixed: Old Multiplex left arrow not appearing.
Fixed: Thumbs appearing behind Poster in Multiplex mode.
2009-07-14
Added: TV Posters + Movie Info Poster + Watched Overlay for Multiplex.
Fixed: Low List removed from Music and Video file modes.
Changed: Watched Icon.
Added: Media Flags On/Off for List views.
Fixed: Now Playing widget appearing on Low List.
Removed: Redundant Full/Slim button.
Fixed: Bottom separator line appaearing in other views.
2009-07-13
Added: Leeuw's Low List view.
Added: Stop button for Video and Music OSD.
Fixed: Menu naviagtion (Thanks to andyblac and 'Black)
Added: Hide Library update Dialog for Slideshow, Visualiser and Video.
Fixed: Removed Fanart button from Wall view.
Added: Fanart for List views.
Added: New Studio Tags.
2009-07-12
Fixed: File Browser bug.
Added: Favourites menu thanks to CF2009.
Added: Pulse on select.
Added: BBFC Ratings.
Updated: Mute and Yes/No dialog.
Added: Pulse for Context Menu.
Changed: Info and Seek bar.
Fixed: Shutdown menu focus (Visualiser) and lengthened for File Manager.
Added: Native Media Flagging.
Fixed: Album years in List Slim.
New and Improved Showcase Info Panel
Themes added
Full and Slim List views
Top 100
File Manager
Native Media Flagging added
Shutdown Menu Fixed
New Seek and Info bars
Added BBFC Ratings
Updated Dialogs
Added Pulse for Context Menu
Added Favourites Menu
Added 'Stop' Button to OSDs
Added Lueew's Low List
Added TV Posters for Multiplex
Dark Aeon
Great work getting rid of the pointless view change screen, though it does feel strange at first. and the file manager is a welcome bonus, as i did not manage to get it working correctly on my current version. keep it upSmile
looks great, thanks for fixing the top 100 mode
Great to see the mod on github - downloading it now. Removing the view change screen should also increase the usability when using the Launcher script for the Games link. This way the view change screen doesn't always popup when selecting Games.
I am on vacation starting tomorrow and i was gonna try and change the
view selection so we could have more than the default 4 view unless we use conditions.
Saves me a looooooooot of time... I was actually gonna try and have it stay the
same type of selection except that the 1st time you select it, you are selecting
the view "group" and then it gives you 4 more choices for the actual view.
This would effectively give you a possible total of 16 views... Anyway, glad i
don't have to attempt this now and get frustrated Smile
Maybe now i can revisit another mod i was working on and abandoned
because of the limited views...
Great work man!
-Pr.
looks very good, download now Wink
Pr.Sinister Wrote:I am on vacation starting tomorrow and i was gonna try and change the
Great work man!
-Pr.
VerticalMenu can have more then 4 Viewtypes. Rolleyes
How do I get to the poster view for tv shows?
Nothing happens when I try to change away from the multiplex view.
Also when choosing fanart backdrops in the customize settings, the file browse selection is 1 selection too much up.
zag2me Wrote:How do I get to the poster view for tv shows?
You have to unlock the other views for TV Shows in the settings.
zag2me Wrote:Also when choosing fanart backdrops in the customize settings, the file browse selection is 1 selection too much up.
Thanks for finding that, it's now been fixed.
File Browser fix
Hey Hitcher, nice to see the mod on git Smile
Before you had watched status icon overlay fixed now it's back to auriga status, that is that it's hiding behind the episode thumb.
One more thing. One thing that djh has forgotten is to put EPISODE and SEASON as localized strings. So when I have my skin set to Swedish I get EPISODE instead of AVSNITT.
eumel Wrote:VerticalMenu can have more then 4 Viewtypes. Rolleyes
I don't see the point of the rolling eyes. If you had just put that last phrase, i
would have said :
"Cool! I didn't know about that! With work, the wife and the new business i'm
trying to get off the ground, it's easy to miss a thread in this forum!"
But now the more appropriate answer is :
"Well since i have a life outside this hobby, i only look a threads/mods that are
popular. Yours isn't."
-Pr.
