2013-02-06, 01:32
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
2013-02-06, 01:32
2013-02-06, 12:27
CU LRC Lyrics not works for me with the skin Xperience, with Confluence everything is fine.
Read this, please:
http://forum.xbmc.org/showthread.php?tid...pid1287370
Thanks...
Read this, please:
Thanks...
2013-02-06, 13:42
(2013-02-06, 12:27)PatOso Wrote: [ -> ]CU LRC Lyrics not works for me with the skin Xperience, with Confluence everything is fine.
Read this, please:
Thanks...
I have CU Lyrics not CU LRC Lyrics and they are working fine here (as seen on the above screenshots)... should I been using CU LRC Lyrics ? why ?
(I just checked with Confiluence and CU Lyrics are working there also)
2013-02-06, 15:42
Try new version on Github and let me know if CU LRC Lyrics are working as expected
2013-02-06, 15:59
Hey crni,
Thanks so much for creating the UK film ratings icons. I wondered if I could put a feature request in, would it be possible to create some icons for the source of the file. Personally I understand codecs but they don't mean much to the non-techy user (partners, children, parents and so on).
For example, Confluence checks the filename for BluRay, DVD, HDTV, WEB-DL etc. and displays an appropriate logo. Would this be something you would think about making an optional alternative/adding additional to the flags?
Even if somebody could create the icons (I don't have much skill in this department) I could put the mod together pretty easily.
2013-02-06, 16:33
(2013-02-06, 13:42)crni Wrote: [ -> ]I have CU Lyrics not CU LRC Lyrics and they are working fine here (as seen on the above screenshots)... should I been using CU LRC Lyrics ? why ?
Because CU lyrics is broken in the official Repo.
http://forum.xbmc.org/showthread.php?pid=1246092
(2012-12-06, 20:04)ronie Wrote: [ -> ]development of cu lyrics has stopped.
as of xbmc frodo, please use cu lrc lyrics:
http://forum.xbmc.org/showthread.php?tid=147340
(2013-02-06, 15:42)crni Wrote: [ -> ]Try new version on Github and let me know if CU LRC Lyrics are working as expected
I do it when I return a home.
2013-02-06, 18:36
hey crni hows support for advanced launcher comin along my friend and have you worked on a couple wallview layouts , or atleast fixed the current one by making the non selected covers not so horribly dimmed one can hardly see them and perhaps zoom out the selected cover more and add the ability to call up movie information with the RB button ,and have you looked into video backgrounds functionality instead of static backgrounds as currently is , and have you considered making a repository addon that has the latest git updates would be much appreciated ,thanks my friend, we all appreciate your hard work alot
2013-02-06, 19:06
(2013-02-06, 18:36)hentai23 Wrote: [ -> ]hey crni hows support for advanced launcher comin alongI do not use advanced launcher so that's way down on my list of priorities (if ever)
I'm content with wall view as it is (also you should calibrate your display if you do not see covers as they should be perfectly visible)
I do not like dreamscene and have no plans to add them (since most of the background is obscured anyway I see no point)
As for the repository that's something I'd consider but not right now
2013-02-06, 19:17
(2013-02-06, 15:59)mortstar Wrote: [ -> ]Hey crni,
I was looking at this also, but mainly more at replacing the existing icons for 1080p etc. with some nicer ones - the current ones don't really gel that well with the otherwise very slick interface as I also agree that they would be simpler being just "HD","SD" etc.
Seems to just be a case of whipping up some new icons (I was thinking of modifying the Aeon ones) and overwriting the existing set.
2013-02-06, 23:20
Thanks for the mod I really like it. +1 to the repo request, it would make it easier to update.
2013-02-07, 00:15
2013-02-07, 02:46
Hi crni !
First of all, I would like to thank you and Blacks for the amazing work on this skin.
But sadly I have to report something that seems like a bug to me.
I use xbmc with the default language as "Portuguese (Brazilian)" and some text are appearing incomplete.
The problem occurs more on the home screen.
But with the mini menu too.
The same problem happens with Blacks skin.
I chosed yours because of the home layout, I preffer this one instead of Metro.
I think the problem is with special characters, like "ç" , "Ç" , "ã" , "Ã" , "õ" , "Õ" and others.
Bellow are some screens with the problem.
Please note that in one screen, the GREEN box highlight a right text, even with the special characters that I talked.
The yellow text next to the yellow box is how the text is supposed to appear.
Image links if the bellow don't work !
http://imageshack.us/photo/my-images/541...ot000z.png
http://imageshack.us/photo/my-images/171...t008ux.png
http://imageshack.us/photo/my-images/526...t004on.png
http://imageshack.us/photo/my-images/502...t002uy.png
Thanks for your attention !
2013-02-07, 12:06
2013-02-07, 13:19
CU LRC Lryics works fine.
2013-02-07, 16:07
very nice crni, and about advanced launcher i can understand its at the bottom of your priority list since you dont use it , id appreciate it thou my friend since i use it for all my comics , games , emulators etc , btw my display is correctly calibrated per calibration guidelines , you gotta admit thou it is quite abit dimmed thou , just a littttlle bit less dimming ,and would it be possible to add genre category like action/horror etc to the title of the selected movie that would be
nice, anyhow its up to you if you would like to add to the currently excellent wallview , just a couple of little nags still enjoying the hell out of it thou , and is there a way to have the RB button call up movie information , that would be nice, cant wait for that repository addon , and about the dreamscene support request , its ok if you dont add it but you gotta admit it does look pretty sleek even when most is obscured but depending on video you use it could add to the experience quite nicely , anyhow keep up the excellent work
