(2013-01-10, 00:29)tmiranda316 Wrote: [ -> ]Is this a Frodo skin?
yes, like I said in the first post modded skin is based on latest
Xperience1080 git (2.0 Beta 3) so whatever goes for original skin applies here
(2013-01-10, 01:26)crni Wrote: [ -> ] (2013-01-10, 00:29)tmiranda316 Wrote: [ -> ]Is this a Frodo skin?
yes, like I said in the first post modded skin is based on latest Xperience1080 git (2.0 Beta 3) so whatever goes for original skin applies here
Yes, sorry didn't read thoroughly enough before i posted. Can't wait to try it out, unfortunately I will have to wait until the CinemaExperience plugin is updated for Frodo, it is essential for my wife to have the "real movie theater experience". This looks great though!
Great skin. I installed new wersion from Github, but nothing changed, no new settings. Deinstall old version, reboot, delete guisettings.xml, reboot, install new one and nothing. I use openelec 3.0 rc1. May be i need clear other settings or cache?
(2013-01-10, 17:36)zaxx Wrote: [ -> ]Great skin. I installed new wersion from Github, but nothing changed, no new settings. Deinstall old version, reboot, delete guisettings.xml, reboot, install new one and nothing. I use openelec 3.0 rc1. May be i need clear other settings or cache?
are you sure you are using correct github repo ?
Xperience1080plus
(2013-01-11, 11:49)zaxx Wrote: [ -> ] (2013-01-10, 18:14)crni Wrote: [ -> ]are you sure you are using correct github repo ?
Xperience1080plus
Repo is right.
not sure what to tell you... have you tried this:
download repo as zip > extract
Xperience1080plus-master folder from the zip and rename to
skin.xperience1080+ > copy folder to ../userdata/addons/ and replace existing skin
crni
Do you want to look on how to get CU LRC Lyrics working?
Hi
The main menu can be more visible?
Will be support for clearArt in OSD video?.
First of all thanks for this great mod.
I have a question regarding the "Movies" and "TV shows" tab. Is it possible to remove the area next to "NEW TV SHOWS" and "NEW MOVIES"? Or add something like in the "MUSIC" tab to show some more new movies?
I do not need the area left to "NEW TV SHOWS" and "NEW MOVIES" (video tile 1-4, tv show tile 1-2), so I have there a big + all the time. It doesn't look beautiful.
... as my english is not really good I added a picture to show you what I mean.
I installed the newest version on Github but I'm not sure how to access the scroll bars? Sorry if it sounds like a dumb question but going up and down just goes around the list for me (Play, Trailer, Choose Art, Refresh). Going to the right goes to the cast and going to the left brings up the movie poster...
Edit: Btw I do think having the scrollbars is a great idea as I've found movies with large plots scroll way too fast most of the time
(2013-01-12, 00:38)crni Wrote: [ -> ]Added text scrollbars to the movies/shows and music artist/album info text respectively
Available on Github
