hi there, how can I set up Xperience so that I can use video genre fanarts? I've tried using the folders available and couldn't show fanarts when I was selecting a genre. Also, I want to post my own genre posters.
Please, help.
Thank you.
Hmm.. Currently 'Live TV' is positioned next to 'Search' and 'Home'. How to move it more to the right? :-)
(2013-01-21, 17:14)Chrysaor Wrote: [ -> ]Hmm.. Currently 'Live TV' is positioned next to 'Search' and 'Home'. How to move it more to the right? :-)
you can't... well at least not that easy. It is possible but that would require lot's of adjustments and rewriting to the Home screen
awesome keep on modding blacks xperience , this is one epic team up , i like it
hey could you add viewtypes for files mode , programs addons as well not sure if they use the same viewtype process as files mode, id like that alot , since i use advanced launcher and i use files mode for movies , tv shows and just about everything else , id appreciate alot
hey you think you could add support for video backgrounds , that would be awesome like here
https://www.youtube.com/watch?v=kfg10RdE...=1&list=UL
Please, help.
Thank you.
(2013-01-20, 20:32)`Black Wrote: [ -> ]And anyway, it's supported by the skin. Not as big as in titidel's screenshots but that doesn't fit at all so I kept it a little smaller behind the cover.
I'm sorry to have bothered with it, but I could not find the option in the configuration, because it is poorly translated into French. I finally found it!
(2013-01-21, 23:40)gabsaoleo Wrote: [ -> ]hi there, how can I set up Xperience so that I can use video genre fanarts? I've tried using the folders available and couldn't show fanarts when I was selecting a genre. Also, I want to post my own genre posters.
Please, help.
Thank you.
+1
hey guys
any chance we could add the mod "thumbnail view" to the "now playing" view
main reason i want to see other views then list view is for the youtube app,when i press the "play all feature" and choose the "now playing"'
with this skin it will only bring up list view.. coming from aeon nox i use to be able to select thumbnail view
Again nice work crni! You've re-added picture in classic mode - could you please add them in the top menu within the plus version of this skin, too? Thanks
(2013-01-22, 20:54)Cassiel Wrote: [ -> ]Again nice work crni! You've re-added picture in classic mode - could you please add them in the top menu within the plus version of this skin, too? Thanks
+1
(2013-01-23, 20:39)mikkelnl Wrote: [ -> ] (2013-01-22, 20:54)Cassiel Wrote: [ -> ]Again nice work crni! You've re-added picture in classic mode - could you please add them in the top menu within the plus version of this skin, too? Thanks
+1
to much work, also that would require adding some kind of Pictures panel and I have no idea what to put there other then more custom tiles which are already plenty.
It's very easy to add pictures under Applications custom tiles (as explained in the first post) so for now I have no plans to add more metro categories.
You can add support for Script Cinema Experience?
(2013-01-24, 18:38)PatOso Wrote: [ -> ]You can add support for Script Cinema Experience?
+1
Quote:Added support for Cinema Experience
When add-on is installed and enabled using 'Play' in video details will launch script
Thanks, but may be in a button?
