I shall see if I have time today to re-create the Database from 14 and see if I can run some sanity checks based on the SQL I see being used against the database and report here.
vbat - It's nothing that MC creates because, even if it were, the KODI data import should filter it out. I've been looking at the SQL and, well, it's written by a developer with little to no DBA knowledge (or a great SQL developer who spent too many days running on coffee and no sleep)
Hi is there any download link to kodi 14 stable version?
(2014-12-29, 19:05)expandables Wrote: [ -> ]Hi is there any download link to kodi 14 stable version?
Raspbmc's current release build is Kodi Helix stable.
So helix 1749 is the release stable version?
No. These are all testing builds. If you want Kodi stable on Raspbmc, return to the Raspbmc release build.
That what i am asking if raspbmc have a kodi stable build. I only see stable Gotham 13.2 for the raspberry pi. Do you know of a kodi build if so send the link.
That's the announcement where is the download link?
The first post in this thread provides instruction for returning to Raspbmc release version... I'm not sure exactly how I can better help you here.
ActionA
expandables use a sort of hack to use my builds and install them on his Raspbian setup.
He wants to find and install the Kodi build (only) used in latest Raspbmc.
expandables
You will only find Kodi test builds in here as you know.
Raspbmc doesn´t work like this normally, all you need to do in Raspbmc to get latest "Kodi Helix" is simply to install Raspbmc or update.
Even though you can find the Kodi build (only) that is used in Raspbmc, the structure is different compared to my builds, so my instructions will not work.
Maybe you can figure that out though, but have in mind that the firmware is not included.
Edit: You find all XBMC/Kodi release version (+ nightlies) for Raspbmc here:
http://download.raspbmc.com/downloads/bin/xbmc/
But again, my instructions will not work.
(2014-12-31, 03:58)goose2600 Wrote: [ -> ]Any news about a fix for the videodb update from v90 to v91 in case of duplicate actors?
Seems it was fixed by Montellese, according to https://github.com/xbmc/xbmc/pull/6020
That PR hasn't been merged. It's also not sufficient. I needed the additional Milhouse patch to update from 90->91.
Ah, I missed that you put the patch into newclock4, was going to apply it myself and make a build yesterday but didn´t find the time.
Haven´t had time to build anything recently, but will probably have time tomorrow.
I am personally not running any Raspbmc setup at the moment and I don´t think I will switch back since I am testing OSMC now.
As soon as OSMC is more stable (even though very stable for me so far) I will look into pushing test builds for OSMC.
expandables
Yes, I believe that is the latest build.
Hi miappa,
did you build Kodi 15 for OSMC? I am testing OSMC too (alpha 3).
Thank you.
