emelar
How do you enable the sound card in these builds?
I actually have no idea so it would be good to know (see post above yours).
I tried to get latest Firmware and latest kernel updates to see if there is a better support for external soundcards now
as described in the postings before
but the result was a lost of SSH login
had to use factory reset again
and ( sorry I´m still a beginner with that) this : "sudo BRANCH=next rpi-update" did not work for me
(2014-03-03, 09:59)miappa Wrote: [ -> ]I don´t know much about this to be honest and don´t have anything to test myself, but I don´t think that turning on external sound card in Raspbmc setttings is the correct way to do this on these builds(?).
I thought that you should be able to choose another output in XBMC settings, and turning on the sound card in Raspbmc settings would probably mess things up, but I am not certain about this.
Please correct me if I am wrong anyone.
That sounds right. The external sound card in raspbmc settings will enable the omx alsa component which has never worked fully and will likely break omxplayer.
Leave that switch off in these builds.
Would it be possible to auto-update the nightlies? (With a script or something like that?)
One other question.. Is it possible to disable the "Incompatible addons" check?
itsjoey
1. These are
unofficial test builds, anybody is welcome to post test builds here (that was actually my intention with this thread, but it´s been quite lonely so far).
And I will not do this forever + I have no proper file hosting so there will be no "official" way to install them (might vary).
However, anybody is welcome to make a script if they want. Someone made an attempt previously in this thread you can check out.
But, as it is simply to copy/paste the complete instruction into a terminal window I personally see no reason to do this.
2. You can "hack" your addons, but the check is there for a reason -> When Gotham is ready it will protect people from installing incompatible addons.
Remember, these are (unofficial)
test builds. You might get a better answer in the main forum as this is a question for Gotham in general.
The proper way though would be to get the addon author to update for Gotham.
Atinkler
Only XBMC builds here. No touchy rootfs or boot.
If that is a change that should be done I am sure Sam will include it in the next update. It is also quite easy to change yourself if you want.
No problem I've changed the cmdline.txt now.
Cheers
Looks that there is some problems with vorbis codec on latest build when using HDMI sounds. Example with this video:
http://www.youtube.com/watch?v=GU4K7YHC_50
After I rollbacked to 20140228-nc3 works without any problems
Thanks miappa and popcornmix.
I disabled external sound cards in Raspbmc settings but still nothing. The audio sources show only HDMI and analogue. Interestingly enough when I try to play back a mp3 on wither omxplayer or DVDPlayer neither will work, paplayer works (i.e. I can see playback in the GUI) but still no output...
I'll fiddle around some more, it's my spare pi so no biggie if I break it!
Good evening,
I have question regarding dual audio output, this isn't working. Normally I am using standard hdmi connection and activation of dualmode. The software / firmware where this is working is pichimney. Maybe I am doing somethimg wrong, but unfortunately I can't find my mistake.
Suggestions are more then welcome.
miappa,
Thank you for your answer, but streaming Internet radio is which player?
miappa,
Will adjust advancedsettings and see if this solves the problem.
popcornmix
Truehd is working, I have a 7.1 TrueHD movie, only hickup every few seconds, let say 6 to 8 seconds. Don't have a 5.1 to test. Receiver displays PCM on the screen but the sound is 5.1.
(I only have 5.1 speakers setup)
