Mine is 3D capable and I set to detect if is 3d or not
popcornmix
Yes, 3D TV.
And for the second part, you are probably right, maybe my mind playing tricks. But if I do see anything (will try to compare) I will report back.
Can you tell me if there is a fix to view 3D Films in 2D monoscopic view on non 3D flatscreens ?
Until now this Feature does not work on my Pi with recent Gotham builds
Or is it still work do to in the future?
Pixel ratio and also top/left etc settings or just pixel ratio?
popcornmix
Very nice, cheers. Will try this soon.
I am also wondering what bylderup asked, 2D-mode works for me in Frodo but not in Gotham. Perhaps this is even related, will test some as soon as I have a new build.
(2013-12-08, 18:55)miappa Wrote: [ -> ]I am also wondering what bylderup asked, 2D-mode works for me in Frodo but not in Gotham. Perhaps this is even related, will test some as soon as I have a new build.
It's a different issue. I'm just looking into mono playback for 3d videos.
Ok, thanks.
The rate you fix things in I should probably wait with a new build.
I already got it running... BUT! I saw Sam´s pull request and that you added it to newclock3.
I´ll wait 30 minutes before I get going again, do you have anything more planned for tonight?
(2013-12-08, 19:45)miappa Wrote: [ -> ]Ok, thanks.
I'll try to get mono view of 3d working today, hopefully within next hour. That will probably be the last commit today.
Thanks a lot, I´ll wait a bit then.
(2013-12-08, 20:13)miappa Wrote: [ -> ]Thanks a lot, I´ll wait a bit then.
Okay, committed - think I'm done for today.
Updated Gotham build from Popcornmix´s
newclock3, rebased on XBMC master on Dec 7.
New features and fixes:
• Fix for issues with IOS7 Airplay (thanks Sam!)
• 2D (mono) playback for 3D movies
• Fix for bug with 3D TV´s where pixel aspect ratio was reset to 0.5
• Fix for screen calibration with 3D TV´s being reset
Included since previous builds:
• Working DVD playback
• GUI sounds (with fix for GUI sounds/passtrhough issues)
• Fix for subtitles (both unsync and all subs rendered at 0)
• Fix for broken skin.widget
• Various patches from bavison (speed improvements etc.)
• Various fixes in XBMC master
If you don´t have libdvdcss already you will have to compile this as explained in
post #1.
Latest firmware from master tree recommended, also explained in
post #1.
To install, SSH to Pi and (note the ” .” (space + dot) in the end of the cp command!):
cd .upgrade
wget -O xbmc-13-20131208-newclock3-dvd.tar.gz http://goo.gl/qjDdVK --no-check-certificate
mkdir -p xbmc-13-20131208-newclock3-dvd
tar -xzf xbmc-13-20131208-newclock3-dvd.tar.gz -C xbmc-13-20131208-newclock3-dvd
cd xbmc-13-20131208-newclock3-dvd/xbmc-bcm/xbmc-bin/lib/xbmc/system
cp /usr/local/lib/libdvdcss.so.2.1.0 .
ln -sf libdvdcss.so.2.1.0 libdvdcss.so.2
ln -sf libdvdcss.so.2 libdvdcss.so
Then in Raspbmc, go into "Raspbmc Settings/Nightly Build Configuration/Switch Between Versions of XBMC", and choose new build + restart XBMC.
popcornmix
All 1080-settings in guisettings.xml got the following values which caused issues when switching off the guires limit:
<resolution>
<description>1920x1080 @ 50.00 - Full Screen</description>
<subtitles>694</subtitles>
<pixelratio>1.000000</pixelratio>
<overscan>
<left>1</left>
<top>0</top>
<right>1280</right>
<bottom>720</bottom>
</overscan>
</resolution>
I edited this manually to 1920 and 1080 which worked.
Edit: The values for subtitles are also wrong (in the middle of the screen). Changed it manually to 1060 which seemed to be ok.
Edit2: I think (not sure) that this fixed itself when I reset and recalibrated. Might just have been a "normal" guisetting issue when doing things in the wrong order.
Other than that everything seems to work, I have tested all of the new fixes.
(2013-12-08, 22:05)miappa Wrote: [ -> ]@popcornmix
Unfortunately overscan (calibration) settings are handled in GUI pixels, rather than display resolution pixels (which I feel would be better). This means switching always breaks calibration.
Changing the meaning of these in guisettings.xml would obviously break everyone's calibration.
I need to think about some way of handling this.
Before Gotham final release I'd like to make 1080p GUI the default, it's just awkward to switch because of this issue.
