2015-05-08, 13:09
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
2015-05-08, 14:44
(2015-05-08, 13:09)Skank Wrote: [ -> ]Then why do you say: damn you guys, just ordered one
Because i don't really need it,but since i am a gadget enthusiast, i said why not....
2015-05-08, 17:27
(2015-05-07, 18:35)Kram23 Wrote: [ -> ](2015-05-07, 10:16)Kluiver7830 Wrote: [ -> ]Hi, all.
I got Chinese version of Q5 quad. Actually I bought from eBay.
But, I heard that it can not apply any English firmware at all.
Is there anyone know how can I apply English firmware? (ie. Futeko's version)
And, if you know about how can root Q5, please let me know about it.
Thanks!!!
No way yet of installing the English firmware, someone has to work out what the differences are between the 2 softwares first, I wouldn't know where to begin with that.
As for rooting you can read this http://www.android-mediaplayer.de/index....4K-Device/ I have not tried it yet.
Good luck.
Plus one on hoping someone comes up with an English firmware for the Chinese Q5. I got mine before I was aware that there was an English one available and have no luck in installing any other firmware other than HiMedia's own newer Chinese version. The Q4 4D plays everything fine but I would love to get a custom firmware on t similar to this one mentioned on the Futeko Forum (http://www.futeko.com/newforum/index.php?topic=135.0)
http://forum.softpedia.com/topic/999318-...e__st__252
I've tried numerous variations on naming,etc. but it won't boot.......
2015-05-09, 00:30
When I had the Chinese version initially, it wouldn't take the firmware Futeko posted at all, not even the ATMOS patch. There's even a different HiMedia wrapper version. So the hardware (or at least SDK) probably varies a bit. The new Chinese firmware for 1.0.8 does support ATMOS however w/o need for a patch.
2015-05-09, 15:52
(2015-05-08, 17:27)Alexdad54 Wrote: [ -> ](2015-05-07, 18:35)Kram23 Wrote: [ -> ](2015-05-07, 10:16)Kluiver7830 Wrote: [ -> ]Hi, all.
Thanks!!!
Good luck.
Thanks all. It's very useful information for me.
I will try apply custom firmware in Futeko forum.
And, I will also try to root this device.
If I success, I will update soon
Many thanks!!
2015-05-10, 03:19
I Think the new Himedia H7 is chip is made by RockChip.
2015-05-10, 03:25
It's a new CPU by Rockchip. Based on 3288, I'm not so confident, but hopefully HiMedia chose them for a good reason.
2015-05-10, 05:33
The Himedia player they showed is not gigabit or I saw it wrong?
2015-05-12, 02:09
(2015-04-11, 21:02)looun Wrote: [ -> ]new chinese firmware
芒果嗨Q [Q系列四核-Q5/Q10/Q16/M3/Q3/HD600A/H7二代/H8二代] 1.0.8 新版固件发布
Quote:Records:
1. To solve the whole shadow Dolby sound (Dolby Atmos) of True-HD audio track can not be decoded, through transmission haunt sound problems
2. M3 model increases the standby LED light control switch function, switch - "Advanced Settings -" standby
3. Solve the third video apk, scaling unusual problem
For example: HDP live at home live TV, the aspect ratio - the ratio can not be transferred to the original play, causing the characters on the screen stretched, deformed characters
4. solve a long loop, there will be a black screen problem
5. solve some certain sources for playback, it will lead to the collapse of the underlying problem
For example: clear breathtaking .mp4, OBS Oh My God, Ment.ts etc!
6 resolved cut to 4K resolution output, 1920 * 1088 format video player stuck problem
7. solved mango TV broadcast sources in the h265 occasional black screen problem
8. resolved cut to 1080P UI and 4K resolution, the player will be stuck 4k video screen does not move
9. solved BDMV Raytheon 26 minutes and 41 seconds at the card crashes, null pointer collapse Library button does not respond, you need the power to restart
11. Strengthening the 3D Blu-ray playback compatibility
12. Occasionally, the phone can not find a solution to the problem of the box
13. After the upgrade solves Verbatim live, potatoes xl, HDP live to V1.8.6 version can not be set to one-touch access
14. For further optimize the setup wizard, Home, application management, one-touch access, search, games, etc.
Unfortunately i received a chinese version.
This download link is impossible to download.(new link to download please)
The version i received had firmware 1.0.4
Can i updated from 1.0.4 to 1.0.8?
2015-05-12, 03:35
Links: http://pan.baidu.com/s/1dDERvl3
Password: 8zwi
Password: 8zwi
2015-05-12, 03:42
(2015-05-12, 03:35)looun Wrote: [ -> ]Links: http://pan.baidu.com/s/1dDERvl3
Password: 8zwi
Do you have a different link?
With this firmware is there any difference between the English version and the Chinese version?
2015-05-14, 00:37
(2015-05-12, 03:42)movie78 Wrote: [ -> ](2015-05-12, 03:35)looun Wrote: [ -> ]Links: http://pan.baidu.com/s/1dDERvl3
Password: 8zwi
I updated to 1.08 via the Baidu website, you have to install the Baidu download manager first and then it's pretty straightforward (Google translate is my friend!). Some improvements but still the same launcher.
I'm crossing fingers that someone figures out the differences between the boxes so I can install a custom firmware....
Update: The German forum says there's a 1.09 firware being released by HiMedia tomorrow, May 14th.
2015-05-14, 03:08
(2015-05-12, 02:09)movie78 Wrote: [ -> ]Unfortunately i received a chinese version.Who/where did you order from?
2015-05-14, 13:12
2015-05-14, 13:18
If it was NIKINGSTORE, I would've expected they sent you the English version. I bought off niking-niking on eBay, which I think is the same seller and got the English version. Only way to be certain you'll get the English version is Futeko, but as they ship from UK, it's about $30 more.
