2015-09-15, 09:17
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
2015-09-15, 11:24
How do I tell it what addon to run?
2015-09-15, 12:57
(2015-09-10, 11:51)vinzc Wrote: [ -> ]@idorel77
Just wow! That's perfect. Thanks for the work!
I've also noticed once the slideshow (from library "Pictures") is active there's no going back. I need a keyboard to hit "Back". Can it be fixed? (I'll also try looking that up on my own.)
@syntezit
The logo shall be 400 pixel square, transparent PNG.
(2015-09-15, 08:21)idorel77 Wrote: [ -> ]Hi vinzc, i will look and i will try to fix that also.
Excellent! Thanks a lot!
2015-09-15, 20:24
(2015-09-15, 08:42)idorel77 Wrote: [ -> ]Hi , glad you like it.
I made this skin for Rpi carpc but you can use on android or other system very well, but i can't make the buttons customisable for all systems.
You can change Radio and Navigation buttons with Pictures and Favourites .
For custom buttons you can edit Home.xml or Includes.xml.
Tips. For Pandora etc... you can change the Radio button with Favourite and go to Pandora addon and add to Favourite.
I don't find it yet how to make a home custom button , for add any addon for ex....
Thanks for you prompt reply,
I like the idea that it is possible to
use the big favorites button (not the
star icon on bottom left).
My next question is could I double up
the big favorites button.
ie: one on the bottom left and right,
then relabel them, and both will open
the favorites popup window.
But here is the snag,...
can each favorites have a differant
list of items in its list? On the left
button I can just put all my streaming
radio apps, and on the right,
put all my navigation/OBD/Maps/Speedo
etc apps in that.
...then there is the favorites star
button on the bottom that I like to use
for another list of apps,
(of course a different list then the
big button L R ones)
I also would like to relocate the power
button to the bottom between the file
manager and favorites star button.
This makes more sense to me IMHO not to
have a big power/exit button taking up
room. Nice and small.
....there is no way to change the
buttons in the setting to use the
pictures and navigation at the same
time. It seems that one can only pick
one or the other. I like to use both
pics and nav.
I made a mockup in Photoshop to give an
idea on how I like to use your skin.
Again,... such a wonderful skin for
Kodi to use mobile.
Cheers.
2015-09-15, 20:36
fixed above image upload
2015-09-15, 21:15
Hi everyone! I have made some more changes to this skin. Here are the changes so far:
- PVR (IPTV) access
- Radio streaming access
- PVR settings access
- Kodi standard logo
- Left exit button for Android systems without a physical button
- Removed some Skin Settings, namely the extra Raspberry Pi options (Navigation and Radio FM buttons removed)
To do:
- Advanced Launcher button for Apps
- Movies library button
- Series library button
https://www.dropbox.com/s/jwpciygwjgub1s...n.zip?dl=0
@idorel77
Thanks! I shared it with a portuguese Facebook group for testing and for them to tell me what it is missing. I think this skin has the potential to become the main smartphone Kodi skin.
Here's how it looks now. What else could we fit in here?
- PVR (IPTV) access
To do:
@idorel77
watch gallery
2015-09-16, 19:32
Hi, I am happy to know this thread.
I use this skin for my carpc, and love the simplicity of this one very much.
However I have little hard to scroll through lists (Libraries, setting menu, file manager, etc)
It is not about skin but because my touch pad driver do not support dragging and scrolling.
So I want to add page up / down button to every lists and searched kodi skin help.
Unfortunately I am stuck at the very first part.
Scroll Bar Control in Kodi wiki describe page up / down button need to be added separated button.
However I found Music, Video button to not open xml but kodi internal function.
I am lost, and cannot figure out what to do.
Please help me by giving me a clue to add up/down button to default scroll bar, I do appreciate it.
2015-09-17, 15:44
Yeah, I notice this too.
I always have to use the up/down right hand slider for anything that's in a list, except the music/video playlists. This would be nice to add that function of just scrolling on the list itself to anything that is in lists form,...with just a flick of the finger.
ie: app lists etc.
ie: app lists etc.
2015-09-17, 21:19
Hi, i will try to add this days
2015-09-17, 21:58
idorel,
you are a gentleman,..thanks my friend.
2015-09-17, 22:20
Check touchscreen.xml out as it is related:
http://forum.kodi.tv/showthread.php?tid=...pid2108392
2015-09-18, 16:13
2015-09-18, 16:52
2015-09-18, 16:57
What system do you use?
2015-09-21, 10:13
(2015-09-18, 16:57)idorel77 Wrote: [ -> ]What system do you use?
OpenELEC 5.0 series on a X86_64 PC hardware.
