(2017-09-03, 17:58)edit4ever Wrote: [ -> ]Can you post the zap2xml.log and sd4tvh.log if they are there?
Since John Galt's seems to be developed off of a nougat kernel - can you also make sure that the tv_grab_zap2xml and the tv_grab_sd4tvh files are executable?
Here is the log file, but not sure how to verify that the modules are executable.
# ... output of cat /storage/.kodi/userdata/addon_data/script.module.sd4tvh/sd4tvh.log
# LibreELEC release: S905.arm-Leia-testing
usage: sd4tvh.py -u USERNAME -p PASSWORD [-h] [-v] [-o OUTPUT_PATH] [-d DAYS]
[-m] [--hdhomerun HDHOMERUN] [--filter]
[--filter-path FILTER_PATH] [--channels]
[--channels-path CHANNELS_PATH]
sd4tvh.py: error: argument -u/--username: expected one argument
# ... output of cat /storage/.kodi/userdata/addon_data/script.module.zap2xml/zap2xml.log
/storage/.kodi/addons/script.module.zap2xml/zap2xml.py:617: UserWarning: gzip transfer encoding is experimental!
br.set_handle_gzip(True)
Reading config file: /storage/.kodi/addons/script.module.zap2xml/.zap2xmlrc
Logging in as -p
http://tvschedule.zap2it.com/tvlistings/...tvschedule
Didn't Match .*Logout of your Zap2it account.* Sleep 1 sec.:Function: loginZAP :Line: 591
Failed to login within ,3, retries.
:Function: loginZAP :Line: 594
errorNone
# ... output of cat /storage/.kodi/userdata/addon_data/service.tvheadend42/service.log
2017-09-03 11:07:27.707 [ INFO] main: Log started
2017-09-03 11:07:27.709 [ INFO] http: Starting HTTP server 0.0.0.0:9981
2017-09-03 11:07:27.709 [ INFO] htsp: Starting HTSP server 0.0.0.0:9982
2017-09-03 11:07:27.714 [ INFO] config: loaded
2017-09-03 11:07:27.715 [ INFO] config: scanfile (re)initialization with path <none>
2017-09-03 11:07:27.852 [ INFO] dvr: Creating new configuration ''
2017-09-03 11:07:27.857 [ INFO] descrambler: adding CAID 2600 as constant crypto-word (BISS)
2017-09-03 11:07:27.857 [ INFO] epggrab: module eit created
2017-09-03 11:07:27.857 [ INFO] epggrab: module uk_freesat created
2017-09-03 11:07:27.857 [ INFO] epggrab: module uk_freeview created
2017-09-03 11:07:27.857 [ INFO] epggrab: module nz_freeview created
2017-09-03 11:07:27.857 [ INFO] epggrab: module viasat_baltic created
2017-09-03 11:07:27.857 [ INFO] epggrab: module Bulsatcom_39E created
2017-09-03 11:07:27.857 [ INFO] epggrab: module psip created
2017-09-03 11:07:27.866 [ INFO] epggrab: module opentv-ausat created
2017-09-03 11:07:27.866 [ INFO] epggrab: module opentv-skyuk created
2017-09-03 11:07:27.867 [ INFO] epggrab: module opentv-skyit created
2017-09-03 11:07:27.868 [ INFO] epggrab: module opentv-skynz created
2017-09-03 11:07:27.869 [ INFO] epggrab: module pyepg created
2017-09-03 11:07:27.869 [ INFO] epggrab: module xmltv created
2017-09-03 11:07:27.871 [ INFO] spawn: Executing "/storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh"
2017-09-03 11:07:27.883 [ INFO] epggrab: module /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh created
2017-09-03 11:07:27.885 [ INFO] spawn: Executing "/storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml"
2017-09-03 11:07:27.897 [ INFO] epggrab: module /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml created
2017-09-03 11:07:27.898 [ INFO] spawn: Executing "/storage/.kodi/addons/service.tvheadend42/bin/tv_grab_file"
2017-09-03 11:07:27.904 [ INFO] epggrab: module /storage/.kodi/addons/service.tvheadend42/bin/tv_grab_file created
2017-09-03 11:07:27.968 [ INFO] epgdb: gzip format detected, inflating (ratio 14.6% deflated size 54145)
2017-09-03 11:07:27.972 [ INFO] epgdb: parsing 371188 bytes
2017-09-03 11:07:27.994 [ INFO] epgdb: loaded v2
2017-09-03 11:07:27.995 [ INFO] epgdb: config 1
2017-09-03 11:07:27.995 [ INFO] epgdb: brands 0
2017-09-03 11:07:27.995 [ INFO] epgdb: seasons 0
2017-09-03 11:07:27.995 [ INFO] epgdb: episodes 849
2017-09-03 11:07:27.995 [ INFO] epgdb: broadcasts 849
2017-09-03 11:07:27.996 [ NOTICE] START: HTS Tvheadend version 4.2.2-75 ~ LibreELEC Tvh-addon v9.0.1.111 started, running as PID:3238 UID:0 GID:39, CWD:/ CNF:/storage/.kodi/userdata/addon_data/service.tvheadend42
2017-09-03 11:07:28.220 [ INFO] tvhdhomerun: Found HDHomerun device 1055a951 with 2 tuners
2017-09-03 11:07:28.261 [ INFO] tvhdhomerun: Using Network type : ATSC-T
2017-09-03 11:07:28.261 [ INFO] tvhdhomerun: Created frontend 1055A951 tuner 0
2017-09-03 11:07:28.261 [ INFO] tvhdhomerun: Created frontend 1055A951 tuner 1
2017-09-03 11:07:28.261 [ INFO] tvhdhomerun: Found HDHomerun device 104cbea5 with 2 tuners
2017-09-03 11:07:28.276 [ INFO] tvhdhomerun: Using Network type : ATSC-T
2017-09-03 11:07:28.276 [ INFO] tvhdhomerun: Created frontend 104CBEA5 tuner 0
2017-09-03 11:07:28.276 [ INFO] tvhdhomerun: Created frontend 104CBEA5 tuner 1
2017-09-03 11:07:28.557 [ INFO] scanfile: DVB-S - loaded 1 regions with 112 networks
2017-09-03 11:07:28.557 [ INFO] scanfile: DVB-T - loaded 44 regions with 1112 networks
2017-09-03 11:07:28.557 [ INFO] scanfile: DVB-C - loaded 17 regions with 57 networks
2017-09-03 11:07:28.557 [ INFO] scanfile: ATSC-T - loaded 2 regions with 11 networks
2017-09-03 11:07:28.557 [ INFO] scanfile: ATSC-C - loaded 1 regions with 5 networks
2017-09-03 11:07:28.557 [ INFO] scanfile: ISDB-T - loaded 2 regions with 1297 networks
2017-09-03 11:07:28.916 [ INFO] mpegts: 689.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.107)
2017-09-03 11:07:28.916 [ INFO] tvhdhomerun: tuning to auto:689028615
2017-09-03 11:07:29.052 [ INFO] subscription: 0001: "epggrab" subscribing to mux "689.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.107)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:07:29.052 [ INFO] mpegts: 647.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.185)
2017-09-03 11:07:29.052 [ INFO] tvhdhomerun: tuning to auto:647028615
2017-09-03 11:07:29.171 [ INFO] subscription: 0002: "epggrab" subscribing to mux "647.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.185)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:07:29.758 [ INFO] htsp: Got connection from 192.168.10.82
2017-09-03 11:07:29.760 [ INFO] htsp: 192.168.10.82: Welcomed client software: Kodi Media Center (HTSPv29)
2017-09-03 11:07:29.762 [ INFO] htsp: 192.168.10.82 [ Kodi Media Center ]: Identified as user ''
2017-09-03 11:07:38.960 [ INFO] subscription: 0002: "epggrab" unsubscribing
2017-09-03 11:07:39.925 [ INFO] mpegts: 527.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.185)
2017-09-03 11:07:39.925 [ INFO] tvhdhomerun: tuning to auto:527028615
2017-09-03 11:07:40.034 [ INFO] subscription: 0004: "epggrab" subscribing to mux "527.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.185)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:08:14.017 [ INFO] subscription: 0001: "epggrab" unsubscribing
2017-09-03 11:08:15.017 [ INFO] mpegts: 557.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.107)
2017-09-03 11:08:15.017 [ INFO] tvhdhomerun: tuning to auto:557028615
2017-09-03 11:08:15.129 [ INFO] subscription: 0006: "epggrab" subscribing to mux "557.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.107)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:08:25.029 [ INFO] subscription: 0004: "epggrab" unsubscribing
2017-09-03 11:08:26.029 [ INFO] mpegts: 189.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.185)
2017-09-03 11:08:26.029 [ INFO] tvhdhomerun: tuning to auto:189028615
2017-09-03 11:08:26.134 [ INFO] subscription: 0008: "epggrab" subscribing to mux "189.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.185)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:09:00.059 [ INFO] subscription: 0006: "epggrab" unsubscribing
2017-09-03 11:09:01.059 [ INFO] mpegts: 473.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.107)
2017-09-03 11:09:01.059 [ INFO] tvhdhomerun: tuning to auto:473028615
2017-09-03 11:09:01.169 [ INFO] subscription: 000A: "epggrab" subscribing to mux "473.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.107)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:09:11.068 [ INFO] subscription: 0008: "epggrab" unsubscribing
2017-09-03 11:09:12.068 [ INFO] mpegts: 635.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.185)
2017-09-03 11:09:12.070 [ INFO] tvhdhomerun: tuning to auto:635028615
2017-09-03 11:09:12.179 [ INFO] subscription: 000C: "epggrab" subscribing to mux "635.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.185)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:09:12.956 [ INFO] subscription: 000A: "epggrab" unsubscribing
2017-09-03 11:09:13.943 [ INFO] mpegts: 497.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.107)
2017-09-03 11:09:13.943 [ INFO] tvhdhomerun: tuning to auto:497028615
2017-09-03 11:09:14.048 [ INFO] subscription: 000E: "epggrab" subscribing to mux "497.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.107)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:09:27.000 [ INFO] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: grab /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh
2017-09-03 11:09:27.002 [ INFO] spawn: Executing "/storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh"
2017-09-03 11:09:27.383 [ ERROR] spawn: cat: can't open 'xmltv.xml': No such file or directory
2017-09-03 11:09:27.383 [ ERROR] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: no output detected
2017-09-03 11:09:27.383 [WARNING] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: grab returned no data
2017-09-03 11:09:57.208 [ INFO] subscription: 000C: "epggrab" unsubscribing
2017-09-03 11:09:58.208 [ INFO] mpegts: 623.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.185)
2017-09-03 11:09:58.208 [ INFO] tvhdhomerun: tuning to auto:623028615
2017-09-03 11:09:58.313 [ INFO] subscription: 0010: "epggrab" subscribing to mux "623.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.185)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:09:59.009 [ INFO] subscription: 000E: "epggrab" unsubscribing
2017-09-03 11:10:00.009 [ INFO] mpegts: 515.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.107)
2017-09-03 11:10:00.009 [ INFO] tvhdhomerun: tuning to auto:515028615
2017-09-03 11:10:00.114 [ INFO] subscription: 0012: "epggrab" subscribing to mux "515.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.107)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:10:43.252 [ INFO] subscription: 0010: "epggrab" unsubscribing
2017-09-03 11:10:44.252 [ INFO] mpegts: 659.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.185)
2017-09-03 11:10:44.254 [ INFO] tvhdhomerun: tuning to auto:659028615
2017-09-03 11:10:44.361 [ INFO] subscription: 0014: "epggrab" subscribing to mux "659.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.185)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:10:45.260 [ INFO] subscription: 0012: "epggrab" unsubscribing
2017-09-03 11:10:46.259 [ INFO] mpegts: 653.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.107)
2017-09-03 11:10:46.259 [ INFO] tvhdhomerun: tuning to auto:653028615
2017-09-03 11:10:46.358 [ INFO] subscription: 0016: "epggrab" subscribing to mux "653.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.107)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:10:58.811 [ INFO] subscription: 0016: "epggrab" unsubscribing
2017-09-03 11:10:59.805 [ INFO] mpegts: 177.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.107)
2017-09-03 11:10:59.808 [ INFO] tvhdhomerun: tuning to auto:177028615
2017-09-03 11:10:59.908 [ INFO] subscription: 0018: "epggrab" subscribing to mux "177.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.107)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:11:29.292 [ INFO] subscription: 0014: "epggrab" unsubscribing
2017-09-03 11:11:30.292 [ INFO] mpegts: 479.028MHz in ATSC-T - tuning on HDHomeRun ATSC-T Tuner #0 (192.168.10.185)
2017-09-03 11:11:30.292 [ INFO] tvhdhomerun: tuning to auto:479028615
2017-09-03 11:11:30.399 [ INFO] subscription: 001A: "epggrab" subscribing to mux "479.028MHz", weight: 4, adapter: "HDHomeRun ATSC-T Tuner #0 (192.168.10.185)", network: "ATSC-T", service: "Raw PID Subscription"
2017-09-03 11:11:44.906 [ INFO] subscription: 0018: "epggrab" unsubscribing
2017-09-03 11:12:15.332 [ INFO] subscription: 001A: "epggrab" unsubscribing
2017-09-03 11:13:24.128 [ INFO] xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: grab /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml
2017-09-03 11:13:24.132 [ INFO] spawn: Executing "/storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml"
2017-09-03 11:13:29.820 [ ERROR] spawn: cat: can't open '/storage/.kodi/userdata/addon_data/script.module.zap2xml/xmltv.xml': No such file or directory
2017-09-03 11:13:29.820 [ ERROR] xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: no output detected
2017-09-03 11:13:29.820 [WARNING] xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: grab returned no data
2017-09-03 11:13:29.820 [ INFO] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: grab /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh
2017-09-03 11:13:29.822 [ INFO] spawn: Executing "/storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh"
2017-09-03 11:13:30.112 [ ERROR] spawn: cat: can't open 'xmltv.xml': No such file or directory
2017-09-03 11:13:30.113 [ ERROR] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: no output detected
2017-09-03 11:13:30.113 [WARNING] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: grab returned no data
2017-09-03 11:14:20.671 [ INFO] xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: grab /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml
2017-09-03 11:14:20.677 [ INFO] spawn: Executing "/storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml"
2017-09-03 11:14:25.991 [ ERROR] spawn: cat: can't open '/storage/.kodi/userdata/addon_data/script.module.zap2xml/xmltv.xml': No such file or directory
2017-09-03 11:14:25.992 [ ERROR] xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: no output detected
2017-09-03 11:14:25.992 [WARNING] xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: grab returned no data
2017-09-03 11:14:25.992 [ INFO] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: grab /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh
2017-09-03 11:14:26.000 [ INFO] spawn: Executing "/storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh"
2017-09-03 11:14:26.294 [ ERROR] spawn: cat: can't open 'xmltv.xml': No such file or directory
2017-09-03 11:14:26.295 [ ERROR] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: no output detected
2017-09-03 11:14:26.295 [WARNING] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: grab returned no data
2017-09-03 12:04:00.000 [ INFO] xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: grab /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml
2017-09-03 12:04:00.009 [ INFO] spawn: Executing "/storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml"
2017-09-03 12:04:05.271 [ ERROR] spawn: cat: can't open '/storage/.kodi/userdata/addon_data/script.module.zap2xml/xmltv.xml': No such file or directory
2017-09-03 12:04:05.271 [ ERROR] xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: no output detected
2017-09-03 12:04:05.271 [WARNING] xmltv: /storage/.kodi/addons/script.module.zap2xml/bin/tv_grab_zap2xml: grab returned no data
2017-09-03 12:04:05.271 [ INFO] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: grab /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh
2017-09-03 12:04:05.274 [ INFO] spawn: Executing "/storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh"
2017-09-03 12:04:05.583 [ ERROR] spawn: cat: can't open 'xmltv.xml': No such file or directory
2017-09-03 12:04:05.584 [ ERROR] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: no output detected
2017-09-03 12:04:05.584 [WARNING] xmltv: /storage/.kodi/addons/script.module.sd4tvh/bin/tv_grab_sd4tvh: grab returned no data
2017-09-03 12:07:27.000 [ INFO] epgdb: snapshot start
2017-09-03 12:07:27.058 [ INFO] epgdb: queued to save (size 568781)
2017-09-03 12:07:27.058 [ INFO] epgdb: brands 0
2017-09-03 12:07:27.058 [ INFO] epgdb: seasons 0
2017-09-03 12:07:27.058 [ INFO] epgdb: save start
2017-09-03 12:07:27.059 [ INFO] epgdb: episodes 1277
2017-09-03 12:07:27.059 [ INFO] epgdb: broadcasts 1277
2017-09-03 12:07:27.119 [ INFO] epgdb: stored (size 83964)
