(2017-12-01, 04:25)edit4ever Wrote: [ -> ]@hagertyoh - thanks for the update. If you don't have any channels setup it should download all channels. Were you getting an error before you added channels?
If possible - it would be great if you could run a test by uninstaling the zap2epg addon on LE, deleting the userdata folder as well, and trying a clean install.
I know that can be a bit time consuming, so if you can't do it right away - no worries. Also, I'd love to see a log from what you have now and one after you clean install without setting up any channels.
Here is the log file with no channels selected. I will do a clean install tomorrow and get a copy of the log.
2017/11/30 21:51:46 Kodi settings version is: 2
2017/11/30 21:51:46 Running zap2epg for zipcode: 45840 and lineup: Local Over the Air Broadcast
2017/11/30 21:51:46 Accessing Tvheadend channel list from: 127.0.0.1
2017/11/30 21:51:46 18 Tvheadend channels found...
2017/11/30 21:51:46 Downloading guide data for: 1512093600
2017/11/30 21:51:47 Parsing 1512093600.json.gz
2017/11/30 21:51:47 Exception: parseStations
File "/storage/.kodi/addons/script.module.zap2epg/zap2epg.py", line 369, in parseStations
if skey in stationList:
TypeError: argument of type 'NoneType' is not iterable
2017/11/30 21:51:47 Exception: parseEpisodes
File "/storage/.kodi/addons/script.module.zap2epg/zap2epg.py", line 418, in parseEpisodes
2017/11/30 21:51:47 Downloading guide data for: 1512104400
2017/11/30 21:51:47 Parsing 1512104400.json.gz
2017/11/30 21:51:47 Downloading guide data for: 1512115200
2017/11/30 21:51:48 Parsing 1512115200.json.gz
2017/11/30 21:51:48 Exception: parseEpisodes
2017/11/30 21:51:48 Downloading guide data for: 1512126000
2017/11/30 21:51:48 Parsing 1512126000.json.gz
2017/11/30 21:51:48 Downloading guide data for: 1512136800
2017/11/30 21:51:49 Parsing 1512136800.json.gz
2017/11/30 21:51:49 Exception: parseEpisodes
2017/11/30 21:51:49 Downloading guide data for: 1512147600
2017/11/30 21:51:49 Parsing 1512147600.json.gz
2017/11/30 21:51:49 Downloading guide data for: 1512158400
2017/11/30 21:51:50 Parsing 1512158400.json.gz
2017/11/30 21:51:50 Exception: parseEpisodes
2017/11/30 21:51:50 Downloading guide data for: 1512169200
2017/11/30 21:51:50 Parsing 1512169200.json.gz
2017/11/30 21:51:50 Creating xmltv.xml file...
2017/11/30 21:51:50 Writing Stations to xmltv.xml file...
2017/11/30 21:51:50 Writing Episodes to xmltv.xml file...
2017/11/30 21:51:50 Checking for old cache files...
2017/11/30 21:51:50 Deleting old cache: SH02402794.json
2017/11/30 21:51:51 Deleting old cache: SH01324196.json
2017/11/30 21:51:51 zap2epg completed in 4.8 seconds.
2017/11/30 21:51:51 0 Stations and 0 Episodes written to xmltv.xml file.
