2017-04-12, 12:45
(2017-04-12, 11:55)mohshadow17 Wrote: [ -> ]Hi guys. Difficult to understand all what is explained on the 50 first page.... but I tried.... API.... Shitty ("Merdique" en francais.... that doesn't inspire me... or need help)
The facts for me are clear. DTS Passthrough worked well before (Jarvis) and not in Kody 17.1. (Can't confirm in Kodi 17 only used 4 days before an update was proposed to me.
My devices: Android Box Beelink GT1 AMLOGIC S912 plugged by toshlink SPDIF with my A/V receiver Onkyo SR307 DTS capable (seems not DTS HD)
On a DTS movie, no sound at all by Passthrough, so I must disable Passtrough in movie setup. Concerning Dolby Digital 5.1 movies, no problem at all.
I don't really understand where comming from the issue... and most important for me how to correct it if it is possible.
If someone enough capable to help a (french) noob.. Thx a lot.
Its simple - that AMLogic S912 device you have does not have the required IEC Audio Support now required by Kodi Krypton.
There is nothing Kodi developers can do. Its a Firmware issue your seller has to sort out for you with an update.
Kodi cannot help with device Firmware.
Its all explained in Post #2 of this very thread:
http://forum.kodi.tv/showthread.php?tid=...pid2409146
You will have to Transcode DTS Audio to AC3 basically.
