2017-10-20, 15:02
I have a strange problem with YeeMee 3.5. The same was with 3.4 (updated today). YeeMee test is working, playback too. The YeeLight White fails only on starting playback. Hitting pause, resume from pause and stop works as expected.
Here's the log:
The second problem is that Kodi freezes by enabling / sometimes by disabling YeeMee addon - the loading circle is still spinning.
Here's the log:
14:37:14.523 T:140562720085760 DEBUG: YEEMEE >> YEMME - AMBI PRIORITY >> 1
14:37:14.523 T:140562720085760 DEBUG: YEEMEE >> LOWER BRIGHTNESS ON AMBI PAUSE >> 0
14:37:14.523 T:140562720085760 DEBUG: YEEMEE >> AMBI SMOOTHEN (MS) >> 0
14:37:14.523 T:140562720085760 DEBUG: YEEMEE >> REPORT ERRORS >> True
14:37:14.523 T:140562720085760 DEBUG: YEEMEE >> NUMBER OF BULBS >> 1
14:37:14.523 T:140562720085760 DEBUG: YEEMEE >> ON AT START >> 0
14:37:14.524 T:140562720085760 DEBUG: YEEMEE >> DISABLE FOR SHORT FILMS >>FALSE<<
14:37:14.524 T:140562720085760 DEBUG: YEEMEE >> ACTIVATION TIME >>OFF<<
14:37:14.524 T:140562720085760 DEBUG: YEEMEE >> MAX BRIGHT DAY >> 100
14:37:14.524 T:140562720085760 DEBUG: YEEMEE >> MAX BRIGHT CIVIL TW >> 100
14:37:14.524 T:140562720085760 DEBUG: YEEMEE >> MAX BRIGHT NAUTIC TW >> 100
14:37:14.524 T:140562720085760 DEBUG: YEEMEE >> MAX BRIGTH NIGHT >> 100
14:37:14.524 T:140562720085760 DEBUG: YEEMEE >> INIT BULB NUM: 1, IP ADDR: 192.168.1.244, MODEL: ceiling
14:37:14.524 T:140562720085760 DEBUG: YEEMEE >> NUMBER OF ACTIVE BULBS >> 1
14:37:14.525 T:140562720085760 DEBUG: YEEMEE >> Number Act Int Color Eff Duration
14:37:14.525 T:140562720085760 DEBUG: YEEMEE >> BULB 0 PLAY : >> 2 5 #BA2B2B 1 1000
14:37:14.525 T:140562720085760 DEBUG: YEEMEE >> BULB 0 STOP : >> 2 100 #BA2B2B 1 1000
14:37:14.525 T:140562720085760 DEBUG: YEEMEE >> BULB 0 PAUSE: >> 2 20 #BA2B2B 1 1000
14:37:14.525 T:140562720085760 DEBUG: YEEMEE >> BULB 0 AMBI: >> 0 BIAS: 0
14:37:14.525 T:140562720085760 DEBUG: YEEMEE >> NUMBER OF AMBI BULBS >> 0
14:37:14.525 T:140562720085760 DEBUG: YEEMEE >> NUMBER OF CONTROLLERS >> 0
14:37:36.821 T:140562720085760 DEBUG: YEEMEE >> PLAYBACK >>PLAYING<<
14:37:36.822 T:140562720085760 DEBUG: YEEMEE >> ACTIVATION TIME: 0
14:37:36.822 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 192.168.1.244 ambi passed check
14:37:36.822 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ priority: 1 player state: start
14:37:36.951 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 192.168.1.244 state start > action 2
14:37:36.958 T:140562720085760 DEBUG: YEEMEE >> (ON) POWER ON (MONO) RESULT >> ok
14:37:37.263 T:140562720085760 DEBUG: YEEMEE >> (ON) SET BRIGHT RESULT >> ok
14:37:49.430 T:140562720085760 DEBUG: YEEMEE >> PLAYBACK >>PAUSED<<
14:37:49.430 T:140562720085760 DEBUG: YEEMEE >> ACTIVATION TIME: 0
14:37:49.430 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 192.168.1.244 ambi passed check
14:37:49.430 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ priority: 1 player state: pause
14:37:49.430 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 192.168.1.244 state pause > action 2
14:37:50.440 T:140562720085760 DEBUG: YEEMEE >> (ON) POWER ON (MONO) RESULT >> ok
14:37:50.756 T:140562720085760 DEBUG: YEEMEE >> (ON) SET BRIGHT RESULT >> ok
14:37:56.460 T:140562720085760 DEBUG: YEEMEE >> PLAYBACK >>RESUMED<<
14:37:56.461 T:140562720085760 DEBUG: YEEMEE >> ACTIVATION TIME: 0
14:37:56.461 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 192.168.1.244 ambi passed check
14:37:56.461 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ priority: 1 player state: play
14:37:56.461 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 192.168.1.244 state play > action 2
14:37:56.499 T:140562720085760 DEBUG: YEEMEE >> (ON) POWER ON (MONO) RESULT >> ok
14:37:56.804 T:140562720085760 DEBUG: YEEMEE >> (ON) SET BRIGHT RESULT >> ok
14:38:04.904 T:140562720085760 DEBUG: YEEMEE >> PLAYBACK >>STOPPED<<
14:38:04.906 T:140562720085760 DEBUG: YEEMEE >> ACTIVATION TIME: 0
14:38:04.906 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 192.168.1.244 ambi passed check
14:38:04.906 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ priority: 1 player state: stop
14:38:04.906 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 192.168.1.244 state stop
14:38:04.906 T:140562720085760 DEBUG: YEEMEE >> @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 192.168.1.244 state stop > action 2
14:38:05.934 T:140562720085760 DEBUG: YEEMEE >> (ON) POWER ON (MONO) RESULT >> ok
14:38:06.240 T:140562720085760 DEBUG: YEEMEE >> (ON) SET BRIGHT RESULT >> ok
14:57:12.793 T:139804742252288 DEBUG: YEEMEE >> STARTED VERSION 3.5 on Kodi 17.4
14:57:12.891 T:139804742252288 DEBUG: YEEMEE >> GOT CURRENT LAT-LON: 48.3774, 17.5872
14:57:12.913 T:139804742252288 DEBUG: YEEMEE >> GOT TIMEZONE OFFSET: 2:00:00
14:57:12.955 T:139807555778752 DEBUG: Activating window ID: 10138
14:57:12.955 T:139807555778752 DEBUG: ------ Window Init (DialogBusy.xml) ------
14:57:13.199 T:139804742252288 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: attribute of type 'NoneType' is not callable
File "/home/e/.kodi/addons/service.yeemee/service.py", line 1666, in <module>
Sunrise, Sunset, civilTW, nauticTW = byLoc()
File "/home/e/.kodi/addons/service.yeemee/service.py", line 382, in byLoc
datetime_sunrise = datetime.strptime(sunrise, '%I:%M:%S %p')
TypeError: attribute of type 'NoneType' is not callable
14:57:13.207 T:139807555778752 DEBUG: ------ Window Init (DialogNotification.xml) ------
14:57:13.445 T:139804742252288 INFO: Python script stopped
14:57:13.446 T:139804742252288 DEBUG: Thread LanguageInvoker 139804742252288 terminating
14:57:18.942 T:139807555778752 DEBUG: ------ Window Deinit (DialogNotification.xml) ------
14:57:19.316 T:139807555778752 DEBUG: Keyboard: scancode: 0x40, sym: 0x0134, unicode: 0x0000, modifier: 0x100
14:57:19.317 T:139807555778752 DEBUG: OnKey: alt-leftalt (0x4f0d4) pressed, action is
