With Version 3.6 and 3.7 i get an error after installing the addon und kodi doesnt react anymore.
The installation of Version 3.81 works, but ambilight doesnt work. Lamps just go on, but doesnt change colours.
23:09:45.098 T:1946028576 DEBUG: ADDON: cpluff: 'Plug-in service.yeemee has been installed.'
23:09:50.421 T:1946028576 DEBUG: LocalizeStrings: loaded 107 strings from file /storage/.kodi/addons/service.yeemee/resources/language/English/strings.xml
23:10:01.402 T:1713947552 DEBUG: CPythonInvoker(1, /storage/.kodi/addons/service.yeemee/service.py): start processing
23:10:04.915 T:1713947552 DEBUG: CPythonInvoker(1, /storage/.kodi/addons/service.yeemee/service.py): the source file to load is "/storage/.kodi/addons/service.yeemee/service.py"
23:10:04.919 T:1713947552 DEBUG: CPythonInvoker(1, /storage/.kodi/addons/service.yeemee/service.py): setting the Python path to /storage/.kodi/addons/service.yeemee:/storage/.kodi/addons/script.module.requests/lib:/usr/share/kodi/addons/script.module.pil/lib:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages:/usr/lib/python2.7/site-packages/gtk-2.0
23:10:04.919 T:1713947552 DEBUG: CPythonInvoker(1, /storage/.kodi/addons/service.yeemee/service.py): entering source directory /storage/.kodi/addons/service.yeemee
23:10:05.018 T:1713947552 DEBUG: CPythonInvoker(1, /storage/.kodi/addons/service.yeemee/service.py): instantiating addon using automatically obtained id of "service.yeemee" dependent on version 2.1.0 of the xbmc.python api
23:10:05.029 T:1858073504 DEBUG: DecodeJpegToTexture: decoded special://masterprofile/Thumbnails/f/fa56a57c.jpg 360x540
23:10:38.368 T:1713947552 DEBUG: YEEMEE >> STARTED VERSION 3.81 on Kodi 17
23:10:40.050 T:1713947552 DEBUG: YEEMEE >> GOT CURRENT LAT-LON: 51.6189, 7.5222
23:10:41.586 T:1713947552 DEBUG: YEEMEE >> GOT TIMEZONE OFFSET: 2:00:00
23:10:42.719 T:1713947552 DEBUG: YEEMEE >> GOT CURRENT SUNRISE: 08:30
23:10:42.728 T:1713947552 DEBUG: YEEMEE >> GOT CURRENT SUNSET: 17:56
23:10:42.745 T:1713947552 DEBUG: YEEMEE >> GOT CIVIL TW: 18:32
23:10:42.761 T:1713947552 DEBUG: YEEMEE >> GOT NAUTIC TW: 19:12
23:10:44.739 T:1713947552 DEBUG: YEEMEE >> YEMME - AMBI PRIORITY >> 1
23:10:44.739 T:1713947552 DEBUG: YEEMEE >> LOWER BRIGHTNESS ON AMBI PAUSE >> 0
23:10:44.740 T:1713947552 DEBUG: YEEMEE >> AMBI SMOOTHEN (MS) >> 0
23:10:44.746 T:1713947552 DEBUG: YEEMEE >> YEMME - AMBI PRECISION >> 0
23:10:44.759 T:1713947552 DEBUG: YEEMEE >> REPORT ERRORS >> False
23:10:44.760 T:1713947552 DEBUG: YEEMEE >> NUMBER OF BULBS >> 2
23:10:44.760 T:1713947552 DEBUG: YEEMEE >> ON AT START >> 0
23:10:44.762 T:1713947552 DEBUG: YEEMEE >> DISABLE FOR SHORT FILMS >>FALSE<<
23:10:44.762 T:1713947552 DEBUG: YEEMEE >> ACTIVATION TIME >>OFF<<
23:10:44.775 T:1713947552 DEBUG: YEEMEE >> MAX BRIGHT DAY >> 100
23:10:44.776 T:1713947552 DEBUG: YEEMEE >> MAX BRIGHT CIVIL TW >> 100
23:10:44.776 T:1713947552 DEBUG: YEEMEE >> MAX BRIGHT NAUTIC TW >> 100
23:10:44.778 T:1713947552 DEBUG: YEEMEE >> MAX BRIGTH NIGHT >> 100
23:10:45.056 T:1713947552 DEBUG: YEEMEE >> INIT BULB NUM: 1, IP ADDR: 192.168.0.45, MODEL: color
23:10:45.173 T:1713947552 DEBUG: YEEMEE >> INIT BULB NUM: 2, IP ADDR: 192.168.0.24, MODEL: color
23:10:45.189 T:1713947552 DEBUG: YEEMEE >> NUMBER OF ACTIVE BULBS >> 2
23:10:45.189 T:1713947552 DEBUG: YEEMEE >> Number Act Int Color Eff Duration
23:10:45.190 T:1713947552 DEBUG: YEEMEE >> BULB 0 PLAY : >> 2 20 #BA2B2B 0 500
23:10:45.200 T:1713947552 DEBUG: YEEMEE >> BULB 0 STOP : >> 1 20 #BA2B2B 0 500
23:10:45.203 T:1713947552 DEBUG: YEEMEE >> BULB 0 PAUSE: >> 2 5 #BA2B2B 0 500
23:10:45.204 T:1713947552 DEBUG: YEEMEE >> BULB 0 AMBI: >> 4 BIAS: 0
23:10:45.204 T:1713947552 DEBUG: YEEMEE >> Number Act Int Color Eff Duration
23:10:45.205 T:1713947552 DEBUG: YEEMEE >> BULB 1 PLAY : >> 2 20 #BA2B2B 0 500
23:10:45.205 T:1713947552 DEBUG: YEEMEE >> BULB 1 STOP : >> 1 20 #BA2B2B 0 500
23:10:45.206 T:1713947552 DEBUG: YEEMEE >> BULB 1 PAUSE: >> 2 5 #BA2B2B 0 500
23:10:45.206 T:1713947552 DEBUG: YEEMEE >> BULB 1 AMBI: >> 7 BIAS: 0
23:10:45.237 T:1713947552 DEBUG: YEEMEE >> NUMBER OF AMBI BULBS >> 2
23:10:45.238 T:1713947552 DEBUG: YEEMEE >> NUMBER OF CONTROLLERS >> 0
23:12:33.371 T:1713947552 DEBUG: YEEMEE >> PLAYBACK >>PLAYING<<
23:12:33.376 T:1713947552 DEBUG: YEEMEE >> ACTIVATION TIME ON/OFF: 0
23:12:33.462 T:1481634720 DEBUG: YEEMEE >> SERVER >> 192.168.0.213 WAITING FOR CONNECTION...
23:12:33.921 T:1713947552 DEBUG: YEEMEE >> MESSAGE TO 192.168.0.45: {u'params': [u'power', u'music_on'], u'id': 1, u'method': u'get_prop'}
23:12:33.922 T:1491264416 DEBUG: YEEMEE >> LUMIFACTOR IS 100
23:12:34.247 T:1713947552 DEBUG: YEEMEE >> RESPONSE FROM 192.168.0.45: off, 0
23:12:34.267 T:1713947552 DEBUG: YEEMEE >> MESSAGE TO 192.168.0.45: {u'params': [u'on', u'smooth', 200], u'id': 1, u'method': u'set_power'}
23:12:34.312 T:1713947552 DEBUG: YEEMEE >> RESPONSE FROM 192.168.0.45: ok,
23:12:34.419 T:1713947552 DEBUG: YEEMEE >> MESSAGE TO 192.168.0.45: {u'params': [1, u'192.168.0.213', 55440], u'id': 1, u'method': u'set_music'}
23:12:34.468 T:1481634720 DEBUG: YEEMEE >> SERVER >> CONNECTION FROM: ('192.168.0.45', 49161) ACCEPTED
23:12:34.474 T:1713947552 DEBUG: YEEMEE >> RESPONSE FROM 192.168.0.45: ok,
23:12:34.495 T:1473246112 DEBUG: YEEMEE >> SERVER >> CONNECTION OPEN FOR ('192.168.0.45', 49161)
23:12:34.495 T:1473246112 DEBUG: YEEMEE >> SERVER >> LUMIFACTOR IS 100
23:12:35.063 T:1713947552 DEBUG: YEEMEE >> MESSAGE TO 192.168.0.24: {u'params': [u'power', u'music_on'], u'id': 1, u'method': u'get_prop'}
23:12:35.110 T:1713947552 DEBUG: YEEMEE >> RESPONSE FROM 192.168.0.24: on, 0
23:12:35.126 T:1713947552 DEBUG: YEEMEE >> MESSAGE TO 192.168.0.24: {u'params': [1, u'192.168.0.213', 55440], u'id': 1, u'method': u'set_music'}
23:12:35.165 T:1481634720 DEBUG: YEEMEE >> SERVER >> CONNECTION FROM: ('192.168.0.24', 49161) ACCEPTED
23:12:35.176 T:1713947552 DEBUG: YEEMEE >> RESPONSE FROM 192.168.0.24: ,
23:12:35.198 T:1464857504 DEBUG: YEEMEE >> SERVER >> CONNECTION OPEN FOR ('192.168.0.24', 49161)
23:12:35.199 T:1464857504 DEBUG: YEEMEE >> SERVER >> LUMIFACTOR IS 100
23:13:50.928 T:1713947552 DEBUG: YEEMEE >> PLAYBACK >>STOPPED<<
23:13:50.930 T:1713947552 DEBUG: YEEMEE >> ACTIVATION TIME ON/OFF: 0
23:13:50.932 T:1464857504 DEBUG: YEEMEE >> SERVER >> CONNECTION CLOSED FOR 192.168.0.24
23:13:50.934 T:1473246112 DEBUG: YEEMEE >> SERVER >> CONNECTION CLOSED FOR 192.168.0.45
23:13:50.947 T:1481634720 DEBUG: YEEMEE >> SERVER >> CONNECTION FROM: ('192.168.0.213', 46342) ACCEPTED
23:13:50.948 T:1481634720 DEBUG: YEEMEE >> SERVER >> END
23:13:50.962 T:1713947552 DEBUG: YEEMEE >> SERVER >> STOP SERVER EXCEPTION (THIS IS EXPECTED AND OK): [Errno 9] Bad file descriptor
23:13:50.964 T:1858073504 DEBUG: YEEMEE >> SERVER >> NO BULB, CONNECTION FROM ('192.168.0.213', 46342), TERMINATING HANDLER
23:13:51.137 T:1473246112 DEBUG: YEEMEE >> MESSAGE TO 192.168.0.45: {u'params': [u'power', u'music_on'], u'id': 1, u'method': u'get_prop'}
23:13:51.142 T:1464857504 DEBUG: YEEMEE >> MESSAGE TO 192.168.0.24: {u'params': [u'power', u'music_on'], u'id': 1, u'method': u'get_prop'}
23:13:51.159 T:1464857504 DEBUG: YEEMEE >> RESPONSE FROM 192.168.0.24: on, 0
23:13:51.261 T:1464857504 DEBUG: YEEMEE >> MESSAGE TO 192.168.0.24: {u'params': [u'off', u'smooth', 500], u'id': 1, u'method': u'set_power'}
23:13:51.279 T:1464857504 DEBUG: YEEMEE >> RESPONSE FROM 192.168.0.24: ok,
23:13:51.349 T:1473246112 DEBUG: YEEMEE >> RESPONSE FROM 192.168.0.45: on, 0
23:13:51.452 T:1473246112 DEBUG: YEEMEE >> MESSAGE TO 192.168.0.45: {u'params': [u'off', u'smooth', 500], u'id': 1, u'method': u'set_power'}
23:13:51.470 T:1473246112 DEBUG: YEEMEE >> RESPONSE FROM 192.168.0.45: ok,
23:13:51.482 T:1713947552 DEBUG: YEEMEE >> 192.168.0.45: STOP CF RESULT >> ok
23:13:51.795 T:1713947552 DEBUG: YEEMEE >> 192.168.0.45: TURN OFF RESULT >> ok
23:13:51.814 T:1713947552 DEBUG: YEEMEE >> 192.168.0.24: STOP CF RESULT >> ok
23:13:52.128 T:1713947552 DEBUG: YEEMEE >> 192.168.0.24: TURN OFF RESULT >> ok
