no it is not the same box.
The problem is on my raspberry pi 3 with recalbox (kodi 16.1).
Kodi 17 or yeemee works is on my rapsberry pi2 (kodi 17).
I actually deleted yeemee and reinstall from your deposit.
It's always the same.
Strange... but it is not addon problem but your Kodi installation. Can't think why it wouldn't find PIL module. You can try help in the general Kodi topics. I am declaring PIL in the addon and nothing I can do about it. It works on both 16 and 17. Something messed up in your Kodi installation.
(2018-01-13, 12:30)vosay Wrote: [ -> ]https://paste.ubuntu.com/26377241/
I still do not know what the "Ambi test" is all about ... the test is only for every Yeelight and just lights up ... I have only activated in Ambi settings and other RenderCapture settings, no more.
...hello did you find anything?
(2018-01-13, 23:49)thekow Wrote: [ -> ] (2018-01-13, 12:07)DaLanik Wrote: [ -> ]Hi ..
Well.
I tried this suggestion and get no jpgs the light changes colour (solid not ambi) but no jpgs are produced. I am looking in the .kodi/temp directory as it is the temp directory for kodi.
Do you get any errors? Look at the log.
Are you sure that is the v4.21 from the test repo
? No such line (that gives error) in new version....
Yea that is old version:
09:20:20 T:2665388864 NOTICE: YEEMEE >>
STARTED VERSION 4.2 on Kodi 16
Ok thank you.
I think the problem comes from recalbox.
I don't know if there is a way to install PIL module manualy, you can ask at general help forum.
(2018-01-13, 21:12)vosay Wrote: [ -> ] (2018-01-13, 12:30)vosay Wrote: [ -> ]https://paste.ubuntu.com/26377241/
Hello, again the add-on error at KODI ... v4.21. Otherwise, it still does not work, once again the movie happened that Yeelight was activated at the start of the video. Then no longer.
I can't fix it without log
Same as some people here, I try to have Ambilight on when I play video with Kodi.
I have a strip and this one on when kodi start and go off when video stop. But I don't have ambilight when I'm watching a video
The setup is :
Android TV Sony with Kodi installed and YeeMee addon of course.
How can I get the log to fix this issue ? Thx
