2018-07-31, 17:05
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
2018-07-31, 18:33
When I grep only lines of interest, I get:
22:37:53.871 T:2724 DEBUG: YEEMEE >> PLAYBACK >>PLAYING<<
22:37:53.872 T:2724 ERROR: EXCEPTION: Unknown addon id 'screensaver.video'.
22:37:53.902 T:3612 ERROR: Previous line repeats 1 times.
22:37:55.907 T:2724 DEBUG: YEEMEE >> LUMIFACTOR IS 100
22:38:00.743 T:2724 DEBUG: YEEMEE >> PLAYBACK >>STOPPED<<
22:38:00.744 T:2724 ERROR: EXCEPTION: Unknown addon id 'screensaver.video'.
22:38:00.751 T:4100 ERROR: Previous line repeats 1 times.
22:38:16.373 T:2724 DEBUG: YEEMEE >> OFF AT END >> ACTIVATION TIME: 0
22:38:16.373 T:2724 DEBUG: YEEMEE >> OFF AT END >> TURNING OFF BULB 192.168.1.231
22:38:16.380 T:2724 DEBUG: YEEMEE >> 192.168.1.231: STOP CF RESULT >> ok
22:38:16.688 T:2724 DEBUG: YEEMEE >> 192.168.1.231: TURN OFF RESULT >> ok
22:38:16.688 T:2724 DEBUG: YEEMEE >> OFF AT END >> TURNING OFF BULB 192.168.1.235
22:38:16.707 T:2724 DEBUG: YEEMEE >> 192.168.1.235: STOP CF RESULT >> ok
22:38:17.015 T:2724 DEBUG: YEEMEE >> 192.168.1.235: TURN OFF RESULT >> ok
22:38:17.015 T:2724 DEBUG: YEEMEE >> EXIT
I see nothing wrong....
2018-07-31, 18:41
I'm back but I have a lot of work at work
Again, when I filter only lines of interest (errors and YeeMee) nothing special:
As you can see, It starts the server, turns on the bulb, sets music mode and connects.... and you can see responses from the bulb that everything is ok...
Quote:00:17:23.984 T:196791878896 DEBUG: YEEMEE >> INIT BULB NUM: 1, IP ADDR: 192.168.1.80, MODEL: stripe
00:17:23.985 T:196791878896 DEBUG: YEEMEE >> NUMBER OF ACTIVE BULBS >> 1
00:17:23.985 T:196791878896 DEBUG: YEEMEE >> Number Act Int Color Eff Duration
00:17:23.985 T:196791878896 DEBUG: YEEMEE >> BULB 0 PLAY : 0 20 #BA2B2B 0 400
00:17:23.985 T:196791878896 DEBUG: YEEMEE >> BULB 0 STOP : 0 20 #BA2B2B 0 400
00:17:23.985 T:196791878896 DEBUG: YEEMEE >> BULB 0 PAUSE : 0 20 #BA2B2B 0 400
00:17:23.985 T:196791878896 DEBUG: YEEMEE >> BULB 0 AMBI : 1 BIAS: 0
00:17:23.985 T:196791878896 DEBUG: YEEMEE >> NUMBER OF AMBI BULBS >> 1
00:17:23.986 T:196791878896 DEBUG: YEEMEE >> NUMBER OF CONTROLLERS >> 0
00:17:24.564 T:196829107440 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://www.lyngsat-logo.com/hires/rr/rt_america.png
00:17:25.029 T:196830143728 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
00:17:25.029 T:196830143728 ERROR: CCurlFile::Open failed with code 0 for http://sceper.ws/feed
00:17:29.289 T:196791878896 DEBUG: YEEMEE >> PLAYBACK >>PLAYING<<
00:17:29.290 T:196791878896 ERROR: EXCEPTION: Unknown addon id 'screensaver.video'.
00:17:29.290 T:196791878896 DEBUG: YEEMEE >> ACTIVATION TIME ON/OFF: 0
00:17:29.307 T:196935271664 DEBUG: YEEMEE >> SERVER >> 192.168.1.64 WAITING FOR CONNECTION...
00:17:29.314 T:196791878896 DEBUG: YEEMEE >> MESSAGE TO 192.168.1.80: {u'params': [u'power', u'music_on'], u'id': 1, u'method': u'get_prop'}
00:17:29.322 T:196917314800 DEBUG: YEEMEE >> LUMIFACTOR IS 100
00:17:29.586 T:196791878896 DEBUG: YEEMEE >> RESPONSE FROM 192.168.1.80: off, 0
00:17:29.586 T:196791878896 DEBUG: YEEMEE >> MESSAGE TO 192.168.1.80: {u'params': [u'on', u'smooth', 200], u'id': 1, u'method': u'set_power'}
00:17:29.610 T:196791878896 DEBUG: YEEMEE >> RESPONSE FROM 192.168.1.80: ok,
00:17:29.721 T:196791878896 DEBUG: YEEMEE >> MESSAGE TO 192.168.1.80: {u'params': [1, u'192.168.1.64', 55440], u'id': 1, u'method': u'set_music'}
00:17:29.755 T:196791878896 DEBUG: YEEMEE >> RESPONSE FROM 192.168.1.80: ok,
00:17:29.756 T:196935271664 DEBUG: YEEMEE >> SERVER >> CONNECTION FROM: ('192.168.1.80', 49166) ACCEPTED
00:17:29.756 T:196947789040 DEBUG: YEEMEE >> SERVER >> CONNECTION OPEN FOR ('192.168.1.80', 49166)
00:17:29.756 T:196947789040 DEBUG: YEEMEE >> SERVER >> LUMIFACTOR IS 100
00:17:32.033 T:196830143728 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
00:17:32.033 T:196830143728 ERROR: CCurlFile::Open failed with code 0 for http://sceper.ws/feed
00:17:39.037 T:196830143728 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
00:17:39.037 T:196830143728 ERROR: CCurlFile::Open failed with code 0 for http://sceper.ws/feed
00:17:39.037 T:196830143728 ERROR: Unable to obtain rss feed: http://sceper.ws/feed
00:18:24.901 T:196791878896 DEBUG: YEEMEE >> PLAYBACK >>STOPPED<<
00:18:24.926 T:196791878896 ERROR: EXCEPTION: Unknown addon id 'screensaver.video'.
00:18:24.926 T:196791878896 DEBUG: YEEMEE >> ACTIVATION TIME ON/OFF: 0
00:18:24.926 T:196947789040 DEBUG: YEEMEE >> SERVER >> CONNECTION CLOSED FOR 192.168.1.80
00:18:24.928 T:196935271664 DEBUG: YEEMEE >> SERVER >> CONNECTION FROM: ('192.168.1.64', 51647) ACCEPTED
00:18:24.929 T:196791878896 DEBUG: YEEMEE >> SERVER >> STOP SERVER EXCEPTION (THIS IS EXPECTED AND OK): [Errno 9] Bad file descriptor
00:18:24.930 T:196935271664 DEBUG: YEEMEE >> SERVER >> END
00:18:24.936 T:196732986608 DEBUG: YEEMEE >> SERVER >> NO BULB, CONNECTION FROM ('192.168.1.64', 51647), TERMINATING HANDLER
00:18:25.128 T:196947789040 DEBUG: YEEMEE >> MESSAGE TO 192.168.1.80: {u'params': [u'power', u'music_on'], u'id': 1, u'method': u'get_prop'}
00:18:25.134 T:196947789040 DEBUG: YEEMEE >> RESPONSE FROM 192.168.1.80: on, 0
00:18:25.235 T:196947789040 DEBUG: YEEMEE >> MESSAGE TO 192.168.1.80: {u'params': [u'off', u'smooth', 500], u'id': 1, u'method': u'set_power'}
00:18:25.246 T:196947789040 DEBUG: YEEMEE >> RESPONSE FROM 192.168.1.80: ok,
00:18:29.855 T:196782023920 ERROR: DoWork - Direct texture file loading failed for androidapp://sources/apps/com.plexapp.android.png
2018-07-31, 18:44
(2018-06-25, 10:26)TeDeV Wrote: [ -> ]another weird thing is that....Can you try without the URL control? Does it work then? Just delete the IP adress of the controller.
i am using a url controller to turn my smart plug off when the movie starts and the turn ambilight on.
2018-08-01, 12:53
can you confirm me if your addon also works with the yeelight Light Strip Plus version?
the difference between them is that the yeelight PLUS can be increased up to 10 meters
https://pt.aliexpress.com/item/2018-Mais...2e0eTPQq21
2018-08-01, 17:24
I know the difference but don't know the ID If it has the same ID, it should work.
2018-08-04, 04:39
just confirm one thing for me.
if I buy two 2m RGB Yeelight they work together at Yeemee?
2018-08-04, 12:41
They should. Even new extendeble should work, if it has different ID than the old one (and there's no reason it should, since it is only longer and has no new functionality) it would be easy to make it work, just add the new ID in my addon (couple lines of code). But hard to tell if no one has tried it yet.
2018-08-08, 11:02
no. no it doesn't.
i am running Kodi 18 with GRID skin.
i turned the urls off and still the same thing.
the addon is a hit or miss (usually a miss)
most of the times if you want it to make it work you must choose a movie from the main menu where it shows the recent movies. it usually works there but not always.
if i go in the movies menu and select the movie from there! 7/10 it doesn't work. it's like your plugin doesn't understand that a movie started (only with the bulbs. the url controllers always work)
and i guess that it is not your fault exactly because i know that the addon used to work fine. maybe something was changed in Kodi?
and i don't know if you have any idea but that red color is killing me. for example... if you start a movie where the UNIVERSAL logo with the earth shows up..... you will see a red color somewhere. (where it shouldn't)
keep in mind that i have 2 bulbs behind my tv set to left and right at 1/2.
2018-08-08, 11:20
Aha, maybe, Kodi 18 is still alpha/beta so it was never tested.... but the log showed everything OK.... strange. I'm still on kodi 17.6
Can you try debug capture and get the images? We'll see if the images containg RED... if they do - it is a problem with kodi...
Also, you can try 17.6
2018-08-08, 17:00
well i don't know how easy it is to try 17.6 since i don't want to remove my kodi. i will try to keep a backup.
as for the images, can you please guide me how to get the pictures you want for the debug?
2018-08-08, 17:14
See the 1st post in this thread, it is explained there.
2018-08-15, 09:02
@"DaLanik"
Thank you for the addon. Iam using it for a long time.
Yesterday i switch to LibreELEC (Leia) v8.90.003 ALPHA
The Addon is still working fine except the time frame. I try both manually and automatic. But both do not function. The Strip lights up at every time of day
2018-08-15, 09:22
OK, could you turn on debugging and post the whole log when it does that?
2018-08-17, 01:07
anyone using the addon with kodi 18?
i can't figure out why it doesn't work 80% of the times and 20% it works.
i am trying to figure it out but nothing.
i am using the "START" testing method in the addon and the bulbs are not working.
i am then testing each bulb separately and it works through the plugin.
this is so weird. most of the times i have to close kodi and start it again in order for it to work.
another weird thing is that sometimes, if i stop a movie and the addon was working.... kodi crashes.
i can't place my finger on it
