Hi
i have a little problem. since the last update i m not able anymore to switch between to channels with the "0". how can i fix this?
is it possible to set a fix startup channel ?
but all the rest is really perfect all what i want is there
thanks to all of you for your hard work
greetz
Hello,
maybe someone can help me...
i got a Sundtek MediaTV Pro DVBC/T running on my Asus M50VN with Ubuntu 11.04 and XBMC 11pre
i installed drivers succesfully - no problems, i was able to find analog channels using Tvtime.
the remote works as well but:
configured tvheadend like you postet in your tutorial, but:
under configuration -> TV Adapters .... chose my tv adapter "Sundtek DVB-C"
click every radio buttom like you explained...
NIT-o Network ID - did i find running my tv status informations -> network id ? 40984
using Kabel-BW Germany.
than i added my DVB Network location... Germany -> Kabel BW
but nothing happend - no channels
and
Muxes awaiting initial scan: is still 1 after 1 hour ..
what should i do ? does this work with ubuntu 11.04 ?
help pls
Do you have checked "idle scan" in the tvheadend webinterface?
_BJ1
yes sure....
tvheadend start in Debug Mode:
[WARNING]:accesscontrol: Created default wide open access controle entry
[INFO]:dvb: Found adapter /dev/dvb/adapter0 (Sundtek DVB-C) via PCI
[INFO]:v4l: /dev/video0: uvcvideo USB2.0 1.3M UVC WebCam usb-0000:00:1d.7-5 capabilities: 0x04000001
[INFO]:v4l: /dev/video0: Input #0: Camera 1 (Camera), audio:0x0, tuner:0, standard:0000000000000000,
[INFO]:v4l: /dev/video0: Format #0: YUV 4:2:2 (YUYV) [YUYV]
[WARNING]:v4l: /dev/video0: Device does not have a tuner, device skipped
[ALERT]:v4l: Unable to open /dev/video1 -- No such device or address
[INFO]:dvr: Creating new configuration ''
[WARNING]:dvr: Output directory for video recording is not yet configured for DVR configuration "". Defaulting to to "/home/tristan/Videos". This can be changed from the web user interface.
[INFO]:CSA: Using SSE2 128bit parallel descrambling
[NOTICE]:START: HTS Tvheadend version 2.12.99~git20110521.8281379~odk2~natty started, running as PID:6022 UID:1000 GID:1000, settings located in '/home/tristan/.hts/tvheadend'
[DEBUG]:AVAHI: Adding service 'Tvheadend'
[INFO]:AVAHI: Service 'Tvheadend' successfully established.
why is there my WEBCAM?
~$ /opt/bin/mediaclient --lc
List of Media Clients **
/dev/dvb/adapter0/frontend0:
7149 ... tvheadend
/dev/dvb/adapter0/dvr0:
7149 ... tvheadend
/dev/dvb/adapter0/demux0:
7149 ... tvheadend (0000)
7149 ... tvheadend (0001)
7149 ... tvheadend (0010)
7149 ... tvheadend (0011)
7149 ... tvheadend (0012)
/dev/video1:
No client connected
/dev/vbi0:
No client connected
/dev/radio0:
No client connected
/dev/rds0:
No client connected
/dev/mediainput0:
No client connected
/dev/dsp0:
No client connected
/opt/bin/mediaclient -e
List of Media Hardware Devices **
device 0: [ Sundtek MediaTV Pro] DVB-C, DVB-T, ANALOG-TV, FM-RADIO, REMOTE-CONTROL, OSS-AUDIO, RDS
[SERIAL]:
[DVB-C]:
FRONTEND: /dev/dvb/adapter0/frontend0
DVR: /dev/dvb/adapter0/dvr0
DMX: /dev/dvb/adapter0/demux0
[DVB-T]:
[ANALOG-TV]:
VIDEO0: /dev/video1
VBI0: /dev/vbi0
[FM-RADIO]:
RADIO0: /dev/radio0
RDS: /dev/rds0
[REMOTECONTROL]:
INPUT0: /dev/mediainput0
[OSS]:
OSS0: /dev/dsp0
Sorry if this was asked before, but a search of this thread for bluray turned up empty.
I am right now using the Mario Sitz PPA for the bluray support, but would like to also have PVR. Does anyone know if this version has bluray support compiled in? If not, any alternative, other than building from source, for having both bluray and PVR?
Hi to everybody!
For some time I search an solution for live tv streamin on network(LAN), and I found tvheadend to be the right sollution for me BUT:
I didn't manage to setup my TV tunner card Asus TV-FM 7135
http://lxr.linux.no/linux+v2.6.31/Docume...ST.saa7134 - numer 53)
I use ubuntu lucid server with latest updates. For the moment I give up with this card BUT
Yesterday a friend give me an Pinnacle PCTV Hybrid Stick Solo 330e.
By default this card not working but after I read this post :
http://linuxpc.info/node/51
I manage to install it on my sistem: Biostar G31-M7 with intel dual core 2.5 GHz, 1 g ram , and wach tv with tvtime (sound not working god who nows why)
When I go to
http://LAN_IP:9981 at Configuration and TV adapters, I can't see any kind of tv adapters.
My question: what I'm doing wrong!
hi,
I have prob with recording from top menu, when i click on record button he tell me server error!
I use windows xbmc pvr2 for windows and last build tvheadend
log :
01:56:02 T:1736 M:921583616 ERROR: PVR: Tvheadend HTSP Client/192.168.2.17:9982 - Client returns bad error (-3) after AddTimer
what can i do ?
Hi All,
Currently using XBMC and TVHeadend on an ubuntu base. Is there a way to get the screen to fade to black during channel changes? I currently get slight ghosting while the new channel is processed and displayed. ( The wife finds it ugly )
Hi Dushmaniac,
Using you tvheadend + xbmc-pvr build for many months now, very smooth, again my compliments!!
Everything was running smooth till a few weeks ago... then tvheadend was starting to crash every now and then.. Is not that big problem, just start it up again and it's working again.. BUT it is happening more and more now, sometimes a few times in the hour, so it's starting to annoy at the moment. I hope you can point me in the right direction for solving this problem.
It happens very randomly: switching channels in xbmc; deleting a channel in tvheadend; map DVB channels; etc.
Here is my crashlog:
http://pastebin.com/8xw2a1rF
My tvheadend server is a 64-bits Ubuntu 10.04.2
firsttris Wrote:yes sure....
7149 ... tvheadend
7149 ... tvheadend
/dev/video1:
No client connected
/dev/vbi0:
No client connected
/dev/radio0:
No client connected
/dev/rds0:
No client connected
/dev/mediainput0:
No client connected
/dev/dsp0:
No client connected
[SERIAL]:
[DVB-C]:
[DVB-T]:
[ANALOG-TV]:
VIDEO0: /dev/video1
VBI0: /dev/vbi0
[FM-RADIO]:
RADIO0: /dev/radio0
RDS: /dev/rds0
[REMOTECONTROL]:
[OSS]:
OSS0: /dev/dsp0
have you checked: /var/log/mediaclient.log for errors...
some times you get errors locking... if you have used the card in windows...
then you need to run: /opt/bin/mediaclient --dtvtransfermode=iso -d /dev/dvb/adapter0/frontend0
and then pull and replug the card...
/J
jenkins Wrote:Hi!
I am having trubel installing: xbmc-eventclients-xbmc-send
with latest Larsop builds...
it wants to uninstall xbmc when i try...
ubuntu Lucid and Maverik 64bits...
Does someone know anything about this... is xbmc-send broken??
I've just finished setting up TVHeadend and entered my Username and Pasword during the install.
When going to
http://xbmclive:9981 it asks for it. I enter it, but it does not accept it?
DejaVu Wrote:I've just finished setting up TVHeadend and entered my Username and Pasword during the install.
When going to http://xbmclive:9981 it asks for it. I enter it, but it does not accept it?
You could manualy create the desired accesscontrol file.
Do:
mkdir -p /home/hts/.hts/tvheadend/accesscontrol
nano /home/hts/.hts/tvheadend/accesscontrol/1
and fill it with this:
(Adjust network string to match your network and you may want to use a real username and password).
"enabled": 1,
"username": "*",
"password": "*",
"comment": "New entry",
"prefix": "192.168.1.0/24",
"streaming": 1,
"dvr": 1,
"webui": 1,
"admin": 1,
"id": "1"
Save the file
Now do:
cd /home/hts
chown -R hts.video .hts
chown hts.hts /home/hts
/etc/init.d/tvheadend restart
Done.
Bas.
Hi i followed the instruction:
my card :STB0899 Multistandard
add dvb network by location: i select Astra 19.2 and set network id to 1: i don't know if this is right.
there are 78 Muxes and after a while the status is: Muxes awaiting initial scan:0
after that i clicked on: Map DVB Services to channels
no tvheadend seems to tune the channels..
this is the log..:
Quote:Jul 10 09:42:59 (none) daemon.debug tvheadend[798]: PSI: Transport "STB0899 Multistandard/12,669,500 kHz Vertical (No satconf)" PMT (version 18) updated, Composition ID changed, Ancillary ID changed, PIDs reordered
Jul 10 09:42:59 (none) daemon.debug tvheadend[798]: PSI: Transport "STB0899 Multistandard/12,669,500 kHz Vertical (No satconf)" PMT (version 31) updated, Composition ID changed, Ancillary ID changed, PIDs reordered
Jul 10 09:43:00 (none) daemon.debug tvheadend[798]: PSI: Transport "STB0899 Multistandard/12,669,500 kHz Vertical (No satconf)" PMT (version 18) updated, Composition ID changed, Ancillary ID changed, PIDs reordered
Jul 10 09:43:00 (none) daemon.debug tvheadend[798]: PSI: Transport "STB0899 Multistandard/12,669,500 kHz Vertical (No satconf)" PMT (version 31) updated, Composition ID changed, Ancillary ID changed, PIDs reordered
Jul 10 09:43:01 (none) daemon.debug tvheadend[798]: PSI: Transport "STB0899 Multistandard/12,669,500 kHz Vertical (No satconf)" PMT (version 31) updated, Composition ID changed, Ancillary ID changed, PIDs reordered
Jul 10 09:43:01 (none) daemon.debug tvheadend[798]: dvb: "/dev/dvb/adapter0" tuning via s2api to "12,441,000 kHz Vertical (No satconf)" (1841000, 29700000 Baud, 2/3, SYS_DVBS2, PSK_8)
Jul 10 09:43:22 (none) daemon.debug tvheadend[798]: dvb: "/dev/dvb/adapter0" tuning via s2api to "11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))" (1611750, 22000000 Baud, 2/3, SYS_DVBS2, PSK_8)
Jul 10 09:43:42 (none) daemon.debug tvheadend[798]: dvb: "/dev/dvb/adapter0" tuning via s2api to "12,522,000 kHz Vertical (No satconf)" (1922000, 22000000 Baud, 5/6, SYS_DVBS, QPSK)
Jul 10 09:43:48 (none) daemon.err nmbd[1028]: [2011/07/10 09:43:48.050181, 0] nmbd/nmbd_browsesync.c:350(find_domain_master_name_query_fail)
Jul 10 09:43:48 (none) daemon.err nmbd[1028]: find_domain_master_name_query_fail:
Jul 10 09:43:48 (none) daemon.err nmbd[1028]: Unable to find the Domain Master Browser name WORKGROUP<1b> for the workgroup WORKGROUP.
Jul 10 09:43:48 (none) daemon.err nmbd[1028]: Unable to sync browse lists in this workgroup.
Jul 10 09:44:02 (none) daemon.debug tvheadend[798]: dvb: "/dev/dvb/adapter0" tuning via s2api to "12,265,500 kHz Horizontal (No satconf)" (1665500, 27500000 Baud, 3/4, SYS_DVBS, QPSK)
Jul 10 09:44:22 (none) daemon.debug tvheadend[798]: dvb: "/dev/dvb/adapter0" tuning via s2api to "10,979,000 kHz Vertical (No satconf)" (1229000, 22000000 Baud, 5/6, SYS_DVBS, QPSK)
Jul 10 09:44:42 (none) daemon.debug tvheadend[798]: dvb: "/dev/dvb/adapter0" tuning via s2api to "12,721,750 kHz Horizontal (Default (Port 0, Universal LNB))" (2121750, 22000000 Baud, 5/6, SYS_DVBS, QPSK)
Jul 10 09:45:03 (none) daemon.debug tvheadend[798]: dvb: "/dev/dvb/adapter0" tuning via s2api to "11,302,750 kHz Horizontal (No satconf)" (1552750, 22000000 Baud, 2/3, SYS_DVBS2, PSK_8)
it runs the whole night.. but no channels appear in the channels tab..
whats wrong?
thanks in advance
dd
