I noticed that there is a difference in how TVHeadend web interface and XBMX handles the EPG:
webinterface:
Title, Start Duration
'Zender verstrekt geen informatie', 14:00, 4 hrs
'Droomhuis op het platteland', 15:00, 3 hrs (scheduled for recording)
'De grote verbouwing', 16:00, 1 hrs (scheduled for recording)
'Verbouwen en Verkopen', 17:00, 1 hrs
'De grote verhuizing', 18:00, 4 hrs(scheduled for recording)
TV Guide, timeline:
14:00, 'Zender verstrekt geen informatie' >18:00 hrs (with scheduled recording indicator)
18:00, 'De grote verhuizing' > 22:00 hrs (with scheduled recording indicator)
so seperate from the bug / issue mentioned
> here <, the XBMC TV guide handles the epg data different and therefore it cannot be used to schedule the programs 'below' the overlapping (and faulty) programs.
'Droomhuis op het Platteland' cannot be scheduled for recording in XBMC as it is not visible in the timeline, in the tvheadend web application it can be scheduled.
hope this is clear and makes sense (it's very early this Sunday morning
regards,
Ruud
known issue. fixed in the development tree.
wanted to use this with a new htpc,
now i have the following questions:
1. Is it possible to use Timeshift?
2. Is there a way to start the pc for sheduled recordings or have it to run 24/7 ?
regards
ffreak
1. no, not at the moment.
2. it has to be on when the recording starts. perhaps you could do something with acpi wakeup, but you'll have to figure out how to do that yourself.
dushmaniac Wrote:known issue. fixed in the development tree.
hummm I almost feel disappointed
, but do not despair... I will find something that wasn't known
Any change of an updated master with some of these resolved bugs (and maybe some other 'goodies')...
thanks for all of everybodies hard work!
regards,
Ruud.
ffreak
2. got it working. I'll post a few steps when I back home.
Regards
Janusz
janumix
oh , thank you
, i was really desperate because of this
regards
ffreak
Edit: One little further question: Is it possible to mod skins like Aeon nox to work with the frontend?
Can anybody tell me how to "right mouse click" with Asrock 330ht remote ? So i can see channel list with out have to stop video (live-tv)
ffreak
It works with HTS TVheadend.
Try this:
1. Make sure you motherboard supports ACPI Wakeup
2. Make sure you have correctly working suspend script. In my case it was important to suspend system - not to shutdown it. Here is one I use (/etc/pm/sleep.d/99_htpc.sh):
#!/bin/sh
# This script uses curl. Install curl using the following command from your terminal apt-get install curl
# This script will restart lirc drivers, Lirc, and XBMC's lirc interperater upon resume.
case "$1" in
suspend|hibernate)
#curl "http://xbmc:[email protected]:8080/xbmcCmds/xbmcHttp?command=ExecBuiltIn¶meter=LIRC.Stop"
service xbmc-live stop
/etc/init.d/tvheadend stop
/etc/init.d/lirc stop
rmmod mantis
rmmod ivtv
rmmod nvidia
resume|thaw)
modprobe nvidia
modprobe mantis
modprobe ivtv
sleep 1
/etc/init.d/lirc start
/etc/init.d/tvheadend start
#remove the comment if the computer automatically sleeps after resume
#irw & sleep 1; killall irw
sleep 2
service xbmc-live start
#curl "http://xbmc:[email protected]:8080/xbmcCmds/xbmcHttp?command=ExecBuiltIn¶meter=LIRC.Start"
echo "lirc resume script completed!!!" >>/tmp/script.log
esac
3. Create new script - the same path i.e. /etc/pm/sleep.d/95_timer.sh
#!/bin/bash
# set ACPI Wakeup alarm
# safe_margin - minutes to start up system before the earliest timer
# script does not check if recording is in progress
echo 1 > /timer
# bootup system 60 sec. before timer
safe_margin=60
# modyfy if different location for tvheadend dvr/log path
cd ~hts/.hts/tvheadend/dvr/log
start_date=0
stop_date=0
current_date=`date +%s`
for i in $( ls ); do
tmp_start=`cat $i | grep '"start":' | cut -f 2 -d " " | cut -f 1 -d ","`
tmp_stop=`cat $i | grep '"stop":' | cut -f 2 -d " " | cut -f 1 -d ","`
# check for outdated timer
if [ $((tmp_stop)) -gt $((current_date)) -a $((tmp_start)) -gt $((current_date)) ]; then
# take lower value (tmp_start or start_date)
if [ $((start_date)) -eq 0 -o $((tmp_start)) -lt $((start_date)) ]; then
start_date=$tmp_start
stop_date=$tmp_stop
fi
fi
done
wake_date=$((start_date-safe_margin))
echo $start_date >> /timer
echo $wake_date >> /timer
# set up waleup alarm
if [ $((start_date)) -ne 0 ]; then
echo 2 >> /timer
echo 0 > /sys/class/rtc/rtc0/wakealarm
echo $wake_date > /sys/class/rtc/rtc0/wakealarm
fi
4. Modify/make sure all paths in script below are set up correctly.
Note: I havn't finished it and system does not automaticly shutdown after recording has been finished.
Hope this helps you - regards
Janusz
Did you ever know that you're my heeeeerooooooooohhhh... You're everything I would like to beeee-ee-eee!
Damn you, I love you so much! This is the most awesome addition to the most awesome media application in existence. THANK YOU!!!!!
Hi there,
I'm in the process of writing an addon to manage uptime, so that the machine stays on when there is a recording scheduled, and starts up to record.
It's early days, and this is my first python effort... be nice...
It uses the status.xml page, parses the current recordings, and determines when to shutdown/stay awake...
I'd appreciate any feedback...
import sys
import os
import time, datetime
import commands
#import xbmc
#import xbmcaddon
#import xbmcgui
import urllib2
from xml.dom import minidom
#get actioncodes from keymap.xml
ACTION_PREVIOUS_MENU = 10
ACTION_SELECT_ITEM = 7
TVHEADEND_URL = 'http://localhost:9981/status.xml'
#TVHEADEND_FILE = 'C:\python25\scripts\status-norecording.xml'
WAITBEFORESHUTDOWN = 300
WAKEBEFORERECORDING = 240 #30
hostStatus = 1;
#try:
while True:
hostStatus = 1
closestRecordingDateTimeStart = None
closestRecordingDateTimeEnd = None
closestRecordingTitle = None
currentlyRecording = "False"
difference = None
UTCTimeDelta = datetime.timedelta(hours=8)
currentTime = datetime.datetime.now()
password_mgr = urllib2.HTTPPasswordMgrWithDefaultRealm()
password_mgr.add_password(None, TVHEADEND_URL, 'xbmc', 'xbmc')
handler = urllib2.HTTPBasicAuthHandler(password_mgr)
opener = urllib2.build_opener(handler)
opener.open(TVHEADEND_URL)
urllib2.install_opener(opener)
f = urllib2.urlopen(TVHEADEND_URL)
link = f.read()
xmldoc = minidom.parseString(link)
f.close()
#xmldoc = minidom.parse(TVHEADEND_FILE)
subscriptionnode = xmldoc.getElementsByTagName('subscriptions')[0]
numsubscriptions = subscriptionnode.childNodes[0].data
if numsubscriptions == "0":
minutesUntilNextRecording = int(xmldoc.getElementsByTagName('next')[0].childNodes[0].data) - 5
closestRecordingDateTimeStart = currentTime + datetime.timedelta(minutes=minutesUntilNextRecording)
elif numsubscriptions != "0":
for recordingnode in xmldoc.getElementsByTagName('recording'):
nextRecordingDateTimeStart = datetime.datetime.fromtimestamp(float(recordingnode.getElementsByTagName('start')[0].getElementsByTagName('unixtime')[0].childNodes[0].data)) - datetime.timedelta(minutes=5)
nextRecordingDateTimeStartUTC = nextRecordingDateTimeStart
nextRecordingDateTimeEnd = datetime.datetime.fromtimestamp(float(recordingnode.getElementsByTagName('stop')[0].getElementsByTagName('unixtime')[0].childNodes[0].data)) + datetime.timedelta(minutes=15)
nextRecordingDateTimeEndUTC = nextRecordingDateTimeEnd
nextRecordingTitle = recordingnode.getElementsByTagName('title')[0].childNodes[0].data
if nextRecordingDateTimeStartUTC < nextRecordingDateTimeEndUTC:
if nextRecordingDateTimeStartUTC > currentTime:
if currentlyRecording == "False":
#print "future recording",nextRecordingTitle
if closestRecordingDateTimeStart is None:
closestRecordingDateTimeStart = nextRecordingDateTimeStartUTC
closestRecordingDateTimeEnd = nextRecordingDateTimeEndUTC
closestRecordingTitle = nextRecordingTitle
else:
if closestRecordingDateTimeStart > nextRecordingDateTimeStartUTC:
#else:
#print "Ignoring", nextRecordingTitle, "as there is a current recording", closestRecordingTitle
else:
if nextRecordingDateTimeEndUTC > currentTime:
currentlyRecording = "True"
else:
closestRecordingTitle = closestRecordingTitle + "," + nextRecordingTitle
if nextRecordingDateTimeEndUTC > closestRecordingDateTimeEnd:
else:
print "completed recording", nextRecordingTitle
closestRecordingDateTimeStart = currentTime + datetime.timedelta(hours=4)
difference = closestRecordingDateTimeStart - currentTime
print "There are", difference.seconds/60, "minutes until next recording"
# determine if the next recording is > 10 minutes away
if difference.seconds > WAITBEFORESHUTDOWN:
wakeupDateTimeUTC = closestRecordingDateTimeStart - datetime.timedelta(seconds=WAKEBEFORERECORDING)
print "Next recording more than", WAITBEFORESHUTDOWN/60, "minutes away, shutting down with restart in", difference.seconds/60, "minutes, at", wakeupDateTimeUTC + UTCTimeDelta
wakeupCommand = 'echo 0 > /sys/class/rtc/rtc0/wakealarm'
commands.getstatusoutput(wakeupCommand)
print wakeupCommand
wakeupCommand = 'echo \'' + str(time.mktime(wakeupDateTimeUTC.timetuple())) + '\' > /sys/class/rtc/rtc0/wakealarm'
print wakeupCommand
wakeupCommand = '/usr/sbin/pm-suspend'
#commands.getstatusoutput(wakeupCommand)
print wakeupCommand
#hostStatus = 0
else:
difference = closestRecordingDateTimeEnd - currentTime
print "Currently recording", closestRecordingTitle, "for another", difference.seconds/60, "minutes, until", closestRecordingDateTimeEnd + UTCTimeDelta
time.sleep(60)
if hostStatus == 0:
break
#except Exception, e:
# print 'failed', e, sys.exc_info()[0]
nmcaullay
please create a separate thread for that script in the PVR section.
Is there a way to view the timeline based on created channel groups instead of all the channels?
Also, is there a way of sorting the channels by name or setting numbers?
afaik that's not implemented in the dialogs yet. there is a sort method in the data structures to sort channels by number.
