I'm sorry to say this, but I won't buy the league pass this season, I don't have time to watch it. I'm asking for your help, I'll use all the money just to buy the league pass and continue maintaining the add on, as I've done in the past 2 years
thank you:
https://pledgie.com/campaigns/32667
All other archived games working.
Maybe because of it's not a regular NBA Team included
(2016-10-04, 08:21)maxgalbu Wrote: [ -> ]I'm sorry to say this, but I won't buy the league pass this season, I don't have time to watch it. I'm asking for your help, I'll use all the money just to buy the league pass and continue maintaining the add on, as I've done in the past 2 years thank you: https://pledgie.com/campaigns/32667
Thank you for your efforts. I will personally help you, hope others do.
There is a problem with the add on at the moment. The games are loading fine now, but there is a visible frame skipping/hitching and the action is not completely smooth as it used to be last year. Is it an add on problem or simply the NBA's usual shitty start in streaming?
I think its a NBA Problem, bevause on ATV4 i ve sometimes green pixels.
I have also made a donation and I hope you will continue your great work.
I did the same. My boyfriend is a huge fan of NBA and durin the season your addon worked much better than the website version that he is normally using.
I've donated as well, thanks for the work!
Sent from my SM-G920P
donated in appreciation too
Thank you to all! I'm trying to fix the issue of the "failed to get video url..." error, please follow the issue here and comment:
https://github.com/maxgalbu/xbmc.plugin..../issues/20
Quote:There is a problem with the add on at the moment. The games are loading fine now, but there is a visible frame skipping/hitching and the action is not completely smooth as it used to be last year. Is it an add on problem or simply the NBA's usual shitty start in streaming?
Which game, please?
Donated as well. $90 more to go. Come on guys, let's do this!
Quote: There is a problem with the add on at the moment. The games are loading fine now, but there is a visible frame skipping/hitching and the action is not completely smooth as it used to be last year. Is it an add on problem or simply the NBA's usual shitty start in streaming?
Exactly. Kodi states 60fps but this ain't no 60fps at all. It feels more like 30fps. Compared to archived games from last season where the action/motion is completely smooth, this year's stream sucks bigtime. Assuming Massimo's addon (which btw was just updated, check
https://github.com/maxgalbu/xbmc.plugin....a/releases) is not at fault and it's sourcing the correct 4500Kbps@60fps stream, it must be an NBA thing.
On my Backup ATV4 the NBA streams look also not like 60fps. It must be a NBA / Neutlino issue in that point.
But its Preseason, so maybe testing or something else. Lastyear in the Preseason btw the conseded Version was 60fps, but as the reg season started only 30fps again.
Donated, as well. Cheers, Max !
Does this add-on work in conjunction with a VPN?
I there a version that works with the USA League pass?
