Thanks for the reply lmyllari
I totally agree with the drive to a simple switch (or no settings at all) to achieve the desired result (I can't imagine anyone would not want correct colours and black levels so I expect the only switch needed would be regarding hardware or software decoding).
I'm a bit lost when it comes to building versions and patching etc (in linux, I'm a windows developer by day) so I'm most likely going to wait until there is a simple update or version, with all fixes in place, that I can simply install, that is unless someone is kind enough to document their process and I'll happily follow that.
Just out of interest, if the same result could be achieved by hardware decoding, would there be any benefit to software decoding? I suppose for those who have a platform with sufficient CPU power but no suitable GPU decoding I guess?
Thanks again, I'll stay glued to the thread for updates.
And thanks to all involved for keeping this rolling at such a pace, it's impressive to see 'open-source' in effect.
I'm on 3.13-git which includes those patches and they don't solve the HD audio problems.
(2013-11-25, 23:29)Alchete Wrote: [ -> ]Good news -- fritsch and the OpenELEC team just pulled Intel's patch into the OpenELEC main branch.
The next OpenELEC nightly should have it: https://github.com/OpenELEC/OpenELEC.tv/commits/master
Outstanding work on all fronts. Hopefully this fixes things.
So will this fix correct black levels with hardware decode? Any other outstanding issues after this goes in or can I take the plunge?
Thanks to lmyllari and Selene especially for really dogging this thing as well as lmyllari creating a patch to deal with this.
(2013-11-26, 00:10)voip-ninja Wrote: [ -> ]So will this fix correct black levels with hardware decode? Any other outstanding issues after this goes in or can I take the plunge?
Yes, this is the black levels fix for HW decoding. Won't know what other issues exist until we all try it.
VC-1's are still causing me grief running the OE fixes. Not sure what's going on. Going to grab the crashlog a bit later.
(2013-11-26, 00:58)Selene Wrote: [ -> ]VC-1's are still causing me grief running the OE fixes. Not sure what's going on. Going to grab the crashlog a bit later.
Strange you are having these problems, especially as we are on the same hardware. I have just finished watching a VC1 mkv movie again 1 hour ago, with no issues.
I am currently on the lmyllari build (which includes the color fixes
), but the other nightlies were working as well.
(2013-11-26, 01:36)Selene Wrote: [ -> ]try plz (vaapi enabled)
Selene, I see you or someone removed the link.
Are test files not allowed to be posted? Just curious, as I almost posted a DTS-MA test file at one point.
(2013-11-26, 02:58)Alchete Wrote: [ -> ] (2013-11-26, 01:36)Selene Wrote: [ -> ]try plz (vaapi enabled)
I removed the link, if you want to test it shoot me a PM. I wasn't sure, myself, even though it's 1 minute sample, just wanted to be on the safe side? Not sure.
(2013-11-26, 01:36)Selene Wrote: [ -> ] (2013-11-26, 01:20)Mangoes Wrote: [ -> ] (2013-11-26, 00:58)Selene Wrote: [ -> ]VC-1's are still causing me grief running the OE fixes. Not sure what's going on. Going to grab the crashlog a bit later.
I am currently on the lmyllari build (which includes the color fixes ), but the other nightlies were working as well.
Yes, your VC1 + DTS-HDMA crashes xbmc.
To test, I have converted the DTS-HDMA to lossless FLAC. With FLAC, it works fine.
I am sending you the file in PM.
(2013-11-26, 04:34)Mangoes Wrote: [ -> ]Yes, your VC1 + DTS-HDMA crashes xbmc.
Sounds like a bug. If you can, turn on Debugging and capture the log file.
http://wiki.xbmc.org/index.php?title=log_file
