2012-09-20, 19:12
Mine is working. I think they "refreshed" everything. You will most likely have to contact them and have your account reset. Then re-enter your password.
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'module' object has no attribute 'output'
File "C:\Users\TV\AppData\Roaming\XBMC\addons\plugin.video.ustvnow\default.py", line 32, in <module>
Addon.log('plugin url: ' + Addon.plugin_url)
File "C:\Users\TV\AppData\Roaming\XBMC\addons\plugin.video.ustvnow\resources\lib\Addon.py", line 39, in log
xbmc.output(addon.getAddonInfo('name') + ': ' + msg.encode('utf-8'),
AttributeError: 'module' object has no attribute 'output'
(2012-10-14, 05:15)brampower Wrote: [ -> ]Mine was working fine all day today, but just now all the channels stopped working. Anyone else has this issue?
(2012-10-14, 07:18)riinzler Wrote: [ -> ](2012-10-14, 05:15)brampower Wrote: [ -> ]Mine was working fine all day today, but just now all the channels stopped working. Anyone else has this issue?
I'm having same prob, I have AppleTv 2 and have been useing USTVNOW. For some reason when I try channels it gives a playback failed message. Any ideas?
(2012-10-09, 02:19)alexsim2004 Wrote: [ -> ]I am running Raspbmc RC5 and am having the same error as Icarus3000:I'm getting the exact same problem sadly.
Code:- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
I am a paid USTVnow member and this same addon is working ok on Apple TV 2 (XBMC Eden)
Any help would be much appreciated
