phileas50 Wrote:Unfortunatelly it stopped working on my atv2.here is the log: http://pastebin.com/hWpd7hC0
Any help would be greatly appreciated.
my guess is that there was a glitch with the streaming servers. it's working fine here, and your log (please turn on debugging in future!) shows that the correct stream url was passed to xbmc so the plugin was doing it's job.
thanks,
t0mm0.
hello, having problem watching live streams i live in the us if that helps... anyone else have this problem. it just says player failed to play.....
Thank you.. in Advance
Ferdnand Wrote:hello, having problem watching live streams i live in the us if that helps... anyone else have this problem. it just says player failed to play.....
Add-on only works outside the US...
Tested; definitely back up - working great!
the quality of the live streams seams to be a bit better now. nearer to tv quality
bladeds Wrote:the quality of the live streams seams to be a bit better now. nearer to tv quality
recording are working fine for me now, it would be good if when playing recordings , the skipping was a bitter faster. when do a 30 second fast fowards takes like 5 seconds to continue. so skipping breaks takes a while
yes it has definitely got a lot better.
bladeds Wrote:recording are working fine for me now, it would be good if when playing recordings , the skipping was a bitter faster. when do a 30 second fast fowards takes like 5 seconds to continue. so skipping breaks takes a while
nothing i can do about that i'm afraid, it is all handled by xbmc and the plugin has nothing to do with it.
hope to get some epg features released this weekend....
thanks,
t0mm0.
super newb here
just installed it, added account, and can't get the video to work.
I can see the channels.
here is my pastelog, if you can look at it and offer a suggestion, that would be great!
http://pastebin.com/pkv8gby0
im hoping I can get this to work!
dirtyserby Wrote:super newb here
all looks fine as far as the plugin goes.
my only suggestion would be to get a newer build of xbmc as it looks pretty old.
Seems that ustvnow changed their services. The 5 networks that were offered free(fox,abc, etc...) show for a min. than the ustvnow commercial appears on repeat.
Are you trying to watch from the US dlinao23?
The same thing just started happening to me.
I assumed it was because I was watching from the US.
I'm watching from Canada.
Watching from Uk and not experienced any such issues yet.
Would be really great if as a free user you could select to only show the free channels to avoid confusion for those less savvy with the service....
nikc0069 Wrote:Watching from Uk and not experienced any such issues yet.
yes, there is support for this in git at the moment, and i hope to add some rudimentary epg/pvr support (not very clean or easy as the way the data is available on the site doesn't really lend itself to xbmc).
hope to make a new release soon(ish!)
t0mm0
