Niceguy Wrote:not sure what you mean with git version, however it worked just fine Friday morning, so something was changed since then.
Also recently ABC and CBS have a "cropped' image, like as if someone has cut off the borders on all sides (I watched ABC's GMA on Friday and the newsticker was partly off screen.) I have this when watching in a browser as well, so it's probably a UStvnow issue not related to XBMC. Anybody else have this problem too?
yes the cropping is at their end.
just looking at releasing the git version as 0.3.0 - seems to be woking ok. will post again when it is in the repo.
hunkyn Wrote:Tommo,
When we watch online we have the option to choose the resolution. Is it possible to have this option in the add-in too?
ummmm, you already can - the option is on the same page you have to enter your username/password so you must have seen it?
t0mm0
0.3.0 released to fix the site changes, see first post for info. shout if there are still problems as this is just a work in progress rewrite i last updated in june so i might have broken some things and not remembered where i got to and i haven't had much time to test today
t0mm0
t0mm0 Wrote:yes the cropping is at their end.
t0mm0
yep i just looked in there. Totally forgot about the settings.
thank you t0mm0 for fixing this plugin!
It's working again.
Niceguy Wrote:thank you t0mm0 for fixing this plugin!
It's working again.
no problem! let me know if it breaks again as it isn't one i use myself
t0mm0.
T0mm0, it is working great. Is there any chance we can increase the stream quality and make it full screen? Other than that everything seems to be great.
hunkyn Wrote:T0mm0, it is working great. Is there any chance we can increase the stream quality and make it full screen? Other than that everything seems to be great.
well, already pointed you to the quality settings, and you can't receive the stream at better quality than it is being transmitted at
as for 'full screen' - i have no idea what you mean as it is already full screen
t0mm0.
t0mm0:
Thanks for all the great plugins! Unfurtunately, I run into problems every time you update. Your repo doesn't update properly for me. This is the error message I get:
19:40:44 T:6396 ERROR: XFILE::CFileCache::Open - failed to open source <http://github.com/t0mm0/t0mm0-xbmc-plugins/raw/master/addons.xml.md5>
19:40:44 T:6396 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 22
19:40:44 T:6396 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
19:40:44 T:6396 ERROR: XFILE::CFileCache::Open - failed to open source <http://github.com/t0mm0/t0mm0-xbmc-plugins/raw/master/addons.xml>
19:40:44 T:6396 ERROR: Repository t0mm0's XBMC Addons returned no add-ons, listing may have failed
Anyone else having this problem? Any ideas on how to fix?
Icarus3000 Wrote:t0mm0:
looks like you have a network problem. can you open the urls in your browser on the same machine? have you set a proxy in xbmc and if so are the settings correct? if that's no good posting a full debug log to pastebin might also help.
t0mm0
Had the exact same issues; tried deleting and using the Unofficial Repository Installer; as well as downloading the Repo .zip file - neither helped... Other Repos update OK.
Using nightly 11-08-06 under Win32; but also noticed it under iOS...
Strangely, if I open the URL from a browser it seems to open correctly.
Solved by just doing a 'Download Zip' from
https://github.com/t0mm0/t0mm0-xbmc-plugins (using the 'Downloads' button) and extracting the latest USTVNow folder into my XBMC Addons folder.
Working great now! Love the fact that I don't see non-available channels anymore!
Thanks, t0mm0!
t0mm0 Wrote:looks like you have a network problem. can you open the urls in your browser on the same machine? have you set a proxy in xbmc and if so are the settings correct? if that's no good posting a full debug log to pastebin might also help.
t0mm0
My Log is here:
http://pastebin.com/rRZwGWqQ
I can open urls in browser just fine, and no proxy set in xbmc
Any ideas?
Anyone know who the partners are for this site?
... I tried Cox but it did not seem to work since I never got an email verification of my registering.
Icarus3000 Wrote:My Log is here: http://pastebin.com/rRZwGWqQ
Any ideas?
nothing obvious there that i can see. the curl error code (22) apparently means "This is returned if CURLOPT_FAILONERROR is set TRUE and the HTTP server returns an error code that is >= 400." but the server should return a 302 and be diverted to the real url which returns 200. do you have trouble with mortstars repo? (that one uses exactly the same method and host as this one). i assume the problem is specific to your installation as it works for me and lots of others
Livin Wrote:Anyone know who the partners are for this site?
no idea what this means or what Cox is, but check out their
faq.
t0mm0
t0mm0 Wrote:no idea what this means or what Cox is, but check out their faq.
t0mm0
Cox is a Cable service provider... when you register it asks what service you have.
I signed up but never receive an email - it does not ask you to submit a pw so how do you log in?
I like this addon, but would like to own a premium subscription. Can't we share a premium subscription with 169 people..
