I'm running it on XBMC Eden on my Mint 10 (ubuntu 10.04 version) laptop without any problem. (and I didn't make any changes to the script)
I guess that you can select a tv station but the stream is not running?
Check if you have all codecs installed on your Ubuntu. I know that Mint is initially installed with minimal codecs so you have to manually install them with your Software center. Or maybe you can try to reduce the stream quality in the ustvnow config? Did you try to watch directly on the ustvnow website? Does it work?
Cheers
Adobe flash crashes.
I wen through synaptic and tried to find more codecs. And I already have the ubunt restricted package installed.
It's so weird, cuz futubox and every other streaming site seam to be working just fine.
Here's the debug, if any of you are able to figure this one out.
22:33:59 T:139702210631424 DEBUG: Process - Setting the Python path to /home/chris/.xbmc/addons/plugin.video.ustvnow:/home/chris/.xbmc/addons/script.module.pyamf/lib:/home/chris/.xbmc/addons/script.module.demjson/lib:/home/chris/.xbmc/addons/script.module.dmd-czech.common/lib:/home/chris/.xbmc/addons/script.module.myconnpy/lib:/home/chris/.xbmc/addons/script.module.beautifulsoup/lib:/home/chris/.xbmc/addons/script.common.plugin.cache/lib:/home/chris/.xbmc/addons/script.module.coveapi/lib:/home/chris/.xbmc/addons/script.module.free.cable.database/lib:/home/chris/.xbmc/addons/script.module.mechanize/lib:/home/chris/.xbmc/addons/script.module.xbmcswift2/lib:/home/chris/.xbmc/addons/script.module.xbmcswift/lib:/home/chris/.xbmc/addons/script.module.t0mm0.common/lib:/home/chris/.xbmc/addons/script.module.cryptopy/lib:/usr/share/xbmc/addons/script.module.simplejson/lib:/home/chris/.xbmc/addons/script.module.torrent.ts/lib:/home/chris/.xbmc/addons/script.module.turtle/lib:/usr/share/xbmc/addons/script.module.pil/lib:/home/chris/.xbmc/addons/script.video.parentalcontrols/resources/lib:/home/chris/.xbmc/addons/script.module.simple.downloader/lib:/home/chris/.xbmc/addons/script.module.requests/lib:/home/chris/.xbmc/addons/script.module.urlresolver/lib:/home/chris/.xbmc/addons/script.module.parsedom/lib:/home/chris/.xbmc/addons/script.module.elementtree/lib:/usr/share/xbmc/addons/script.module.pysqlite/lib:/home/chris/.xbmc/addons/script.module.metahandler/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PIL:/usr/lib/python2.7/dist-packages/gst-0.10:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:/usr/lib/python2.7/dist-packages/ubuntu-sso-client:/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode:
22:33:59 T:139702210631424 DEBUG: Process - Entering source directory /home/chris/.xbmc/addons/plugin.video.ustvnow
22:33:59 T:139702210631424 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.ustvnow" dependent on version 1.0 of the xbmc.python api
22:33:59 T:139702210631424 DEBUG: ustvnow: plugin url: plugin://plugin.video.ustvnow/
22:33:59 T:139702210631424 DEBUG: ustvnow: plugin queries: {'play': '', 'mode': 'main'}
22:33:59 T:139702210631424 DEBUG: ustvnow: plugin handle: 0
22:33:59 T:139702210631424 DEBUG: ustvnow: main
22:33:59 T:139702210631424 DEBUG: ustvnow: adding dir: Live - plugin://plugin.video.ustvnow/?mode=live
22:33:59 T:139702210631424 DEBUG: ustvnow: adding dir: Recordings - plugin://plugin.video.ustvnow/?mode=recordings
22:33:59 T:139702210631424 INFO: Scriptresult: Success
22:33:59 T:139701897897728 DEBUG: WaitOnScriptResult- plugin returned successfully
22:33:59 T:139702210631424 INFO: Python script stopped
22:33:59 T:139702210631424 DEBUG: Thread XBPyThread 139702210631424 terminating
22:33:59 T:139701260384000 DEBUG: Thread Background Loader start, auto delete: 0
22:33:59 T:139701260384000 DEBUG: Thread Background Loader 139701260384000 terminating
22:33:59 T:139702656456576 DEBUG: waiting for python thread 8 to stop
22:33:59 T:139702656456576 DEBUG: python thread 8 destructed
22:34:01 T:139702656456576 INFO: LIRC Initialize: using: /dev/lircd
22:34:01 T:139702656456576 DEBUG: Failed to connect to LIRC. Retry in 20s.
22:34:01 T:139702656456576 DEBUG: SDLKeyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 1000
22:34:01 T:139702656456576 DEBUG: OnKey: down (f081) pressed, action is Down
22:34:01 T:139701881112320 DEBUG: GetImageHash - unable to stat url /home/chris/.xbmc/addons/plugin.video.ustvnow/fanart.jpg
22:34:01 T:139702656456576 DEBUG: SDLKeyboard: scancode: 68, sym: 010f, unicode: 000d, modifier: 1000
22:34:01 T:139702656456576 DEBUG: OnKey: enter (f065) pressed, action is Select
22:34:01 T:139702656456576 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.ustvnow/?mode=live)
22:34:01 T:139702656456576 DEBUG: ParentPath = [plugin://plugin.video.ustvnow]
22:34:01 T:139701897897728 DEBUG: StartScript - calling plugin ustvnow('plugin://plugin.video.ustvnow/','0','?mode=live')
22:34:01 T:139701897897728 INFO: initializing python engine.
22:34:01 T:139701897897728 DEBUG: new python thread created. id=9
22:34:01 T:139701897897728 DEBUG: WaitOnScriptResult - waiting on the ustvnow plugin...
22:34:01 T:139702210631424 DEBUG: Thread XBPyThread start, auto delete: 0
22:34:01 T:139702210631424 DEBUG: Python thread: start processing
22:34:01 T:139702210631424 NOTICE: -->Python Interpreter Initialized<--
22:34:01 T:139702210631424 DEBUG: Process - The source file to load is /home/chris/.xbmc/addons/plugin.video.ustvnow/default.py
22:34:01 T:139702210631424 DEBUG: Process - Setting the Python path to /home/chris/.xbmc/addons/plugin.video.ustvnow:/home/chris/.xbmc/addons/script.module.pyamf/lib:/home/chris/.xbmc/addons/script.module.demjson/lib:/home/chris/.xbmc/addons/script.module.dmd-czech.common/lib:/home/chris/.xbmc/addons/script.module.myconnpy/lib:/home/chris/.xbmc/addons/script.module.beautifulsoup/lib:/home/chris/.xbmc/addons/script.common.plugin.cache/lib:/home/chris/.xbmc/addons/script.module.coveapi/lib:/home/chris/.xbmc/addons/script.module.free.cable.database/lib:/home/chris/.xbmc/addons/script.module.mechanize/lib:/home/chris/.xbmc/addons/script.module.xbmcswift2/lib:/home/chris/.xbmc/addons/script.module.xbmcswift/lib:/home/chris/.xbmc/addons/script.module.t0mm0.common/lib:/home/chris/.xbmc/addons/script.module.cryptopy/lib:/usr/share/xbmc/addons/script.module.simplejson/lib:/home/chris/.xbmc/addons/script.module.torrent.ts/lib:/home/chris/.xbmc/addons/script.module.turtle/lib:/usr/share/xbmc/addons/script.module.pil/lib:/home/chris/.xbmc/addons/script.video.parentalcontrols/resources/lib:/home/chris/.xbmc/addons/script.module.simple.downloader/lib:/home/chris/.xbmc/addons/script.module.requests/lib:/home/chris/.xbmc/addons/script.module.urlresolver/lib:/home/chris/.xbmc/addons/script.module.parsedom/lib:/home/chris/.xbmc/addons/script.module.elementtree/lib:/usr/share/xbmc/addons/script.module.pysqlite/lib:/home/chris/.xbmc/addons/script.module.metahandler/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PIL:/usr/lib/python2.7/dist-packages/gst-0.10:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:/usr/lib/python2.7/dist-packages/ubuntu-sso-client:/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode:
Thanks in advance
(2012-11-15, 17:07)Gull Wrote: [ -> ]Hey there is synchronization problem with the addon and I am facing with. The audio does not match the video quality and and the audio runs faster then its video. How to solve this problem.Thanks.
I'm getting the same audio sync issues - and I don't get them with LiveStreams, which is odd. I've messed around with the A/V sync method setting in System, and with the Audio sync slider while streaming a source - every channels seems to have a different audio sync interval! I've tried it on multipel systems (Android on Pivos Xios DS and Windows XP) with the same results - does anyone know which A/V sync method and offset will work?
Script failed on xbmc frodo final
Os windows 7
Hey,
I recently jailbroke my apple tv 2 , and tried this new addon ustvnow configured my free account and all.
ustvnow loads all the channel options how ever i keep getting "playback failed" one or more items failed to play.
check the log files for details. i also did the whole /private/var/mobile/Library/Preferences/XBMC/addons/plugin.video.ustvnow/resources/lib/Addon.py
Chnge xbmc.output to xbmc.log
Dunno what to do out of ideas.
anyone
(2013-02-06, 01:59)newgod Wrote: [ -> ]Hey,
anyone??
try reinstalling ustvnow from zip file not from the repositories part in xbmc make sure you reeboot in between it worked for me
Hi
Sorry i create my account, re-install, re-start and the plugin still give me a error.
I'm on mac osx with frodon12
Any fix for this addon to wotrk with frodo yet ?
Thanks for this great addon. Can it please be fixed up for Frodo? It works great on Eden.
Here is the xbmc.log output for the error.
22:21:52 T:12512 NOTICE: Previous line repeats 2 times.
22:21:52 T:12512 NOTICE: Thread XBPyThread start, auto delete: false
22:21:52 T:12512 NOTICE: -->Python Interpreter Initialized<--
22:21:52 T:12512 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'module' object has no attribute 'output'
File "C:\Users\XXXX\AppData\Roaming\XBMC\addons\plugin.video.ustvnow\default.py", line 32, in <module>
Addon.log('plugin url: ' + Addon.plugin_url)
File "C:\Users\XXXX\AppData\Roaming\XBMC\addons\plugin.video.ustvnow\resources\lib\Addon.py", line 39, in log
xbmc.output(addon.getAddonInfo('name') + ': ' + msg.encode('utf-8'),
AttributeError: 'module' object has no attribute 'output'
22:21:52 T:7056 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.ustvnow/
22:21:52 T:7056 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.ustvnow/) failed
This version works on Frodo for those of you who are having problems.
(2013-02-11, 07:42)XeroKool Wrote: [ -> ]This version works on Frodo for those of you who are having problems.
thank you very much ,you r the man
But, is this addon not being actively updated by the original author anymore? It's no fun chasing the next zip file to fix an issue.
Regards.
Thanks man that's awesome
This is an a fantastic idea. Thanks for putting effort for creating this repo.
I have installed this repo on raspberri pi but I cannot be able to make it work. I tried everything including changing Addon.py file, installing the new one posted few links above but nothing is working for me. I do see the channels list but when I click them then either it gives error message or "opening media stream" window comes and disappear immediately and does't give any error message. I don't know what to do next to make it work. Please help.
Try choosing a 720 resolution instead of 1008 on the options screen
